Toon app: PiHoleStats
Joskep
Blacklist button?!
Post by Joskep »
Hi guys, an question:
I have blocked Youtube by adding a whole list of domains in the PiHole...
(For who wants to know :)
(youtube.com
www.youtube.com
m.youtube.com
ytimg.com
s.ytimg.com
ytimg.l.google.com
youtube.l.google.com
i.google.com
googlevideo.com
youtu.be)
What i was wondering...
Is it possible that there will be a 'button' in the menu of the PiHole-app where you can turn the blacklist ON / OFF ?
It would be nice if that will be, then i can use the Toon to simply turn on/off the blacklist.
Greetz
Joskep
TerrorSource
Re: Toon app: PiHoleStats
Post by TerrorSource »
Joskep wrote:Hi guys, an question:
(youtube.com
http://www.youtube.com
m.youtube.com
ytimg.com
s.ytimg.com
ytimg.l.google.com
i.google.com
googlevideo.com
youtu.be)
Greetz
Joskep
I will take a look but I’m pretty sure that can only be done correctly via the webinterface of Pi-Hole self.
Joskep
Post by Joskep »
Thanks!
I can imagine that it only works with the standard commands, but it would be nice.
Greetz
Tebogo
Post by Tebogo »
Thanks for this useful Toon-App! Nice to see when you walk by your thermostat you see the status of Pi-Hole :P
One thing, I try to switch off Pi-Hole-icon in systray, but although its switched off, it stays in systray, even after restart.
Can you solve that?
Thanks!
This is a bug in the app.
Can be fixed by changing row 8 in /qmf/qml/apps/piholestats/PiholestatsTray.qml to:
	visible: app.showAppIcon
I will update the app in the ToonStore in the coming days.
Kind regards,
Hi ll,
version 0.1.7 is available in the ToonStore with the fix for the tray icon.
Kind regardz,
version 0.1.13 is available in the ToonStore.
Changelog:
- the tile has been redesigned to show a bit more user friendly message.
- the background color of the tile is orange if PiHole is disabled or red when PiHole is unreachable
in dim state you will see a corresponding status message in orange or red when PiHole is not active
Kind regardz,
EchoNL
Post by EchoNL »
Since update: Pi-hole v5.14.2 FTL v5.20 Web Interface v5.18, i'm getting only a message "undefined % " and everything else is blank.
Removed app, reinstalled, rebooted Toon 2, no luck.
I am not using Pi-Hole anymore myself.
The Toon Pi-Hole app is using this http call to retrieve the statistics: http://"+connectionPath+"/admin/api.php
What is the response if you retrieve this via your browser?
EchoNL
Post by EchoNL »
http://192.xxx.xxx.xx/admin/api.php
Only works when i fill in this link above, then i getting all the info in my browser.
flamingbob
Post by flamingbob »
Had the same problem with my toon.
Trick is the auth token and changing the URL in the qml to this:
xmlhttp.open("GET", "http://"+connectionPath+"/admin/api.php?summary&auth="+authtoken+"", true);
Then it all works perfecty.
Need to see how to detect an empty auth token though since pihole also works without a password and so without a token.
EchoNL
Post by EchoNL »
flamingbob wrote: Wed Jan 11, 2023 2:26 pm Had the same problem with my toon.
Thank you very much! :) :)
Instead of using the password (which always worked in the past) i used the API token to login and changed the url in the qml file.
flamingbob
Happy to help,
let me check the code also for the non auth way to push it back to github and more happy users.
Bastelopa
Post by Bastelopa »
Hello, Im still struggeling to get my pi-hole statistics running. I don't know how to change the url in the qml. Will there be an update for the pi-hole app in the toon to correct this?
Thanks in advance for your support.
Kind regards.
EchoNL
Post by EchoNL »
Login Winscp
Change URL in folder:
qmf - qml- apps - piholestats-0.1.13 - PiholestatsApp.qml
to
Open folder
mnt - data - tsc - piholestats.userSettings.json
Enter Auth code + pihole adres. The API token, you can find at your local Pihole adres:
Open Settings - API - Click show API Token
