Toon App: Onkyo Network Receiver Controller
Xavier
Re: Toon App: Onkyo Network Receiver Controller
Post by Xavier »
Great work, I really like the app to control my Onkyo receiver.
At this moment the Toon(2) is a central located point in our house from which we can control almost anything!
Lights, blinds, agenda, traffic check, weather check, audio control (Onkyo and Sonos), Venetian blinds, thermostat (heating), doorcamera, security, etc. The only thing I miss is an app to control our Daikin airco which can be combined with the thermostat.
For example of colder then 20 degrees then set heating to 20 degrees, or if warmer then 24 set Daikin airco to 21 degrees.
To all, keep up the good work, wonderfull support!
Thanks!!
Daikin is supported by Domoticz out of the box I believe.
Should be a simple script in Domoticz to achieve this?
Your Daikin must have a wifi module btw for this to work.
oepi-loepi
Post by oepi-loepi »
Yes, Daikin with LAN interface is supported out of the box by Domoticz. You can get and set Domoticz vars from Toon. Or only send the thermostat from Toom and let Domoticz scrip regulate the airco.
Xavier
Post by Xavier »
Thanks, good suggestions!
Rudolf
Post by Rudolf »
I installed this app a while ago thinking I could control my Onkyo-receiver natively from my Toon, only to find out that I need Domoticz.
I'm a happy user of Home Assistant, so I won't be going back anytime soon :)
It would be nice if the requirement for Domoticz was clearly visible in the description in the Toon-store.
Rudolf wrote:It would be nice if the requirement for Domoticz was clearly visible in the description in the Toon-store.
That makes sense and it valid for some other apps as well. Will update the descriptions in the ToonStore repo today......
oepi-loepi
I also made another version to control the onkyo receiver but that version needs an esp8266 as native controller between the Onkyo And the Toon. Could that be of any help? (Needs esp8266 board like Wemos mini D1 and Toon Websockets). All tested on Toon 2 but i can also test on Toon 1:if you wish.
