OpenTherm Gateway 4.2.8
Re: OpenTherm Gateway 4.2.8
Only otmonitor is on github. Pulling that and customizing it is fine. But the OTGW firmware you need to download from the web site.
Bororo
Post by Bororo »
I've managed it (finally) and can confirm that Reference Voltage setting is working. I'm messing my answers with github otmonitor/gateway.asm as I 'm trying to understand firmware and functions implemented (my goal is to add some custom fields specific for Geminox THRi boilers e.g. No of burner starts).
btw - I've seen Reset entry in your previous log and I'm wondering if there is any command for resetting gateway? I'm using Tasmota powered socket for power cycling, but maybe I'm missing somenthing.
Bororo wrote:I'm wondering if there is any command for resetting gateway? I'm using Tasmota powered socket for power cycling, but maybe I'm missing somenthing.
GW=R
Bororo
Post by Bororo »
Thank you. I feel like I'm ignorant, but found it 30sec later :-) I need to improve my reading with understanding skills.
I also found some new sections in otmonitor.conf file, what is is for?:
view {
  tab graph
  order increasing
  sort name
  bitflags true
firmware {
  hexfile {}
fsdialog {
  duopane 0
  reverse 0
  sort name
  historylist {
  mixed 0
  hidden 0
  details 1
That's just for storing the choices for the file selection dialog, so user don't have to adjust it every time. It only applies to the GUI version. As I understand, you are using the non-GUI version via a web browser. In that case, these settings are irrelevant.
