Page 2 of 2
CM11usb problems
Posted: Thu Aug 21, 2008 12:18 pm
by MindBender
Hi Lorenzo. I am not a HomeSeer user myself: I have installed a trial version twice but in both times I came to the conclusion that it didn't meet my requirements. So do not have much experience with it and my comments may be wrong, but this is what I have understood:
The CTX35 (and so the PMIX35 X10-interface-part too) uses the same protocol as the ACT TI-103. Since HomeSeer supports this interface, the CTX35 can be used too using the same driver. The ACT TI-213 seems to be an 220 Volt version of the TI-103, but AFAIK the serial protocol is identical.
Does this answer your question?
CM11usb problems
Posted: Thu Aug 21, 2008 1:43 pm
by drmacchi
Hi MinBender, yes!
I alsso confirm that cti213 is EU version. i didn't know that ctx35 uses the same protocol than TI-103, so we have simply to choose the same plugin.
Cheers, Lorenzo
CM11usb problems
Posted: Thu Aug 21, 2008 2:27 pm
Check this topic, lots of info about X10 and A10, I have updated the link today.
http://www.domoticaforum.eu/topic.asp?TOPIC_ID=126
CM11usb problems
Posted: Tue Aug 26, 2008 10:58 pm
by drmacchi
Digit, about your "multiple clients" , could you a pratical example and its adavantages of having multiple clients in HS. what are, what do they do? Isn't more simple to start the web-server in IE to manage everything?
CM11usb problems
Posted: Tue Aug 26, 2008 11:24 pm
Well i wasn't really thinking of HS when talking about multiple clients actually, but more in general. UDP broadcast can be handy when you've got multiple applications running that all need the same data coming from the device and you can't combine the functions of those multiple applications into one (because you didn't make them yourself, for instance and it's not OS).
In my work i once used UDP broadcast to 'control' client applications running on dozens of PC's, like sending out a UDP broadcast telling them to shutdown ASAP in case of maintenance and things like that.
That's why i am curious.
CM11usb problems
Posted: Tue Aug 26, 2008 11:27 pm
by drmacchi
Ok, the post has been moved, we'll meet there ... cheers
