Page 2 of 4
RSS integration with HS works
Posted: Tue Dec 02, 2008 4:36 pm
by Noel
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">The error message doesn't really show specific error messages.. Many error messages I received were HUGE and I found 'red' strings that provided a lot of information. Could you PM these to me?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
That is the red string what is shown in the Homeseer log file.
Posted: Tue Dec 02, 2008 10:06 pm
by TANE
DJ
I have installed and have done some tests.
When running your script I'm getting the same error as Wifi
When running the original script from Jon script will run okay and read some plugwise date in the devices.
but not not usable..hope you can correct the script
Posted: Tue Dec 02, 2008 10:19 pm
by TANE
DJ found what is going wrong at my side.
You are skipping the device creation part..when the device don't exits...then there will be the error.
Can you please also add the device name...or don't overwrite it in Homeseer
Why is my output not looking nice..:(
[img]uploaded/Chak/2008122211935_plugrss.gif[/img]
Posted: Tue Dec 02, 2008 10:29 pm
by TANE
okay...found the problem again...there was a new version of the script online on your page..
now device 52 is not updated and the usage is 0..
find out that Q42 in is device 4 in real
high numbers is now not working..:(
[img]uploaded/Chak/2008122212852_plugrss2.gif[/img]
Posted: Tue Dec 02, 2008 10:39 pm
by TANE
okay my last spam message...
with low device numbers it's working.
- Dim level at the end is the usage (found it...correct device type will solve the problem)
- Device name will be replaced with rss data.just ignore the name or display the Plugwise name here
[img]uploaded/Chak/200812221380_plugrss3.gif[/img]
Posted: Tue Dec 02, 2008 11:13 pm
by Noel
Chak.
Where did you find the new script?
When I try to download it it's asking for a username / password.
Link that I use is: http://www.nldj.com/wiki/Domotica/ProjectPlugwise
Posted: Tue Dec 02, 2008 11:22 pm
by TANE
hahah I'm not going to tell you here how I found it...will send you the script
DJ my first look at it.
your error will be solved if your first create the device in Homeseer.
Posted: Wed Dec 03, 2008 12:37 am
by Noel
Okay.. Got it 1/2 working.
Showing the data from the plugs is working.
Turning the plugs on / off does not work (at the moment)
Posted: Wed Dec 03, 2008 1:01 am
by DJF3
Site pwd is fixed now! Going to do some more work on it tomorrow.. Running into time issues because of unexpected events. Will try to support you and apply fixes as soon as possible.
Thanks for the feedback!
Posted: Wed Dec 03, 2008 1:07 am
by TANE
Thank you for your work..:)
Posted: Wed Dec 03, 2008 1:21 am
by TANE
Tip:
If you don't want the auto update just create a extra device like Q99.
Let the RSS event be triggered by Q99 any status change to run..
just click on/off for a update
You can use the ON/OFF of the other devices for triggering the Homeseer events for on/off of the plugs.
for more info see the other topic
http://www.domoticaforum.eu/topic.asp?TOPIC_ID=1768
Posted: Wed Dec 03, 2008 12:57 pm
by Noel
One more thing that I noticed is that when everytime the event has been called, the "Name" will change back to "Plugwise" again.
Posted: Wed Dec 03, 2008 1:41 pm
by DJF3
Updated version: 0.4
- (FOUND:0.2, FIXED:0.4) It only works with Plugwise device-codes < 10 (only 1-character-number)
- (FOUND:0.3, FIXED:0.4) Device name in HS is overwritten by the current code.
- (FOUND:0.2, FIXED:0.4) Script crashes if device from .ini doesn't exist in HS. It now checks and puts error message in HS log.
- (FOUND:0.3, FIXED:0.4) Script overwrites devicename with RSS Title (Plugwise)
Download: http://www.domoticaworld.com/scripts/plugwise/
Cheers
DJ
Posted: Wed Dec 03, 2008 2:06 pm
by TANE
DJ,
Thanks for the latest update.
How can I disable the logging to log file?
Last Change field is not always updating see Q6 compare to other screenshots (old time form yesterday) total usage is changed.
Hope you can also support devices >10
all my other devices have higher numbers.
[img]uploaded/Chak/200812313531_ScreenShot001.gif[/img]
Posted: Wed Dec 03, 2008 4:26 pm
by DJF3
- PW device-id's >10 should be supported now, even though I can't test it myself. There was an error in grabbing the device-code from the .ini file (I only grabbed the first character after the Q (so with Q25 it would take '2' instead of '25').
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">LAST CHANGE - If a device was modified externally (not directly by HomeSeer) then this column - and this screen - may not display those changes or the device's new status. To update the screen, click the Poll Device button at the top of the screen (if visible) to go to the Poll Device screen and have HomeSeer communicate with each device to get its current status. When you come back to this screen, the "Status" and "Last Change" columns will display the most up-to-date information about each device.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
- When I click 'poll devices' it looks like it actually picks up on the last change for the PW devices..
- The next release (0.5) which is not available yet has a parameter that allows you to set the trace level (0=off, 1=on, 2=DETAILED).
Cheers
DJ
