Hey, Chiel.....
It might look ungreatfull, but the project is still not finished
It was a huge disapointment that frame did not work here because of the described problem.
Even a self made solution from 1 mm aluminum did not do the trick...
I thaught aluminium would not have the same impact as the rvs would have.
Silly enough i found out after that one about the coil effect that these frames seem to have. Shame on me i did not read that before.
But it looks deamned good on the wall. Hard to see on a picture, but you are invited as mentioned.
I am going to invest some time if an other type of overlay screen does not have these problems and else i just give up and make something from mdf and Formica
http://www.formica.eu.com/publish/site/ ... /home.html
The aluminium is very easy to handle and can be folded quite easy. The haakse slijper eats it like cake and could be dremeld to with out any problems. Could be a good alternative for the mimo screen.
( like in the second picture )
I bought a plate of 50x50cm at a samen kopen aktie with acryan stuff to mod pc enclosures.
Oh and it might be good to mention that some screens can get quite hot and then it might be wise to have some ventilation or space for a bit of air circulation.
