Merten Connect
Merten Connect
not 100% sure...there was a option for associations with homeseer devices
Later this week I will receive some more zwave devices ..will check that also.
Willem4ever
Merten Connect
Post by Willem4ever »
Because of some problems caused by z-seer en repositioning of the USB stick I had to restart homeseer, guess what local changes on the switch are now reflected in homeseer. I assume we hit another bug.
@Enver what have you ordered ?
Merten Connect
Willem,
I read something about problems by relocating Z-wave devices after adding them to the network. You should add a device to the network while it is at it's final location.
Merten Connect
good to hear that it's working..:)
What is the Homeseer version that you are using?
I have the build 2.3.0.82
I ordered 3 extra screen controllers and one popp plugin switch.
Willem4ever
Merten Connect
HomeSeer Version: Standard Edition 2.3.0.19 (Service)
Willem4ever
Merten Connect
<br />Willem,
Merten Connect
O yeah, i forgot :-)
Willem4ever
Merten Connect
I'm going to look for some more devices and see how it really works !
Bastiaan
Merten Connect
Post by Bastiaan »
My one reported the status back properly but got unrealiable when almost out of reach (about 10 meters).
Willem4ever
Merten Connect
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by zebrafilm</i>
<br />My one reported the status back properly but got unrealiable when almost out of reach (about 10 meters).
i can't imagine to reach 30m inside my house ...
Merten Connect
Willem you can better upgrade
there are lot of bug fixes in the latest betas for zwave...see the list on HS forum.
latest official beta is 2.3.60
I have two devices
- Danfoss distance +/- 5 meter 1 wall
- Screen control distance +/- 10 meter on the second floor.
I'm happy with the reach and this will be much better when there are more devices.
30 meter must not be big problem when you ghave more devices.
Willem4ever
Merten Connect
thanks Chak, will look into that. Although I do not really like HS beta's .... you version proves to be stable ?
William.abbo
Merten Connect
Post by William.abbo »
Currently I'am testing with some Z-Wave stuff. I'am using the ZCS201 as secundary controller and the ZTH200 as prim. controller. I'am a bit disappointed about the range I can get. I wonder if routing between the nodes is automatic or do I have to set parameters somewhere? It looks like that routing is not optimum or not working at all. HS has something they call: Network Health Options. When I buy the zwave stick from Aeaon labs can Network Health Options be used then? Or did I miss something about routing? Currently testing with a Merten RF-receiver 507001 and a ZRP200 appl. module.
EzHome
Merten Connect
Post by EzHome »
Willem,
not all devices work as a router, normaly all z-wave switches work as a router.
I'll check what HS does with the Aeon Labs with health check for you.
William.abbo
Merten Connect
O.k. Willem, I'll wait for your answere, thanks.
Return to “Z-Wave Forum”
