@mhn.
How did you open the z stick? After first doing some testing (see how zwave works and how the stick works) i'm planning on creating a rs232 connection to the stick. The idea is to open the stick and make a flatwire connection to a rj45 plug and then close the stick again so it will look neat and gives me also the posibilitie to connect and disconnect nodes.
Aeon Labs controle module via RS32 possible
Re: Aeon Labs controle module via RS32 possible
** edwin **
@Edwin2008
Just press a nail or small flat screwdriver along the joint at the sides. Mine has been opened a couple of times, and still look nice.
But be careful, the clasps are fragile.
Regards
Morten
Regards
Morten
got it, that was pretty easy if you now where to press. Thanks!
** edwin **
