TSU9600 Tips & Tricks
Done.
ddgiel
Post by ddgiel »
Can you sent me the XCF file?
Many Thanks
Done.
lombrano
Post by lombrano »
May I receive the file too ?
Thanks a lot
Snelvuur
Post by Snelvuur »
maybe handy to place it on the files section?
Fischi
Re: TSU9600 Tips & Tricks
Post by Fischi »
Hi, Digit,
Can you send me your xcf too ??
Best regards and have a good evening
Fischi
Well, a lot has changed since 2009, it's all XMLRPC now. I extended the standard HttpLibrary and now it's even simpler as you can read here:
http://blog.hekkers.net/2010/01/02/new- ... -firmware/
Remember that you'll also need XMLRPC @ the other end (your domotica system) !
I'll have a look (in the next couple of days) to see if I can put something together to get you started with.
I kept someone waiting :oops:
The archive contains 2 files, which should be copied to C:\ProgramData\Philips\ProntoEdit Professional 2\Libraries\
Keep a backup of the original files, just in case. Edit the xmlrpc.js and change the ip address to the one of your own XMLRPC server.
Once you've done that, you can add the libraries to your Pronto project and have fun :)
Pronto_XMLRPC.rar
(10.42 KiB) Downloaded 1216 times
kriz83
Post by kriz83 »
Thanks for sharing !
DmitryChulkov
Post by DmitryChulkov »
Return to “Philips Pronto (TSU9600), IRtrans and other remotes”
