my ipad hst interface
Re: my ipad hst interface
Hi Ralph,
I draw my work in xaradraw, a vector program after that i export te stuff to photoshop for easy and pixel perfect processing.
I will post a .psd file where the empty button, text and a icon will be on seperate layers so people could modify them to personal demands.
Allong with that ill post a action that makes the button in a red pressed state with one simple click. It is nothing more than a small macro in photoshop that colours the button red.
The used font is one out of the Futura font family.
Ill post them as soon i find some time...
Thanks for the fast reply,
it will be nice to give this all to the public.
I have made some buttons clean with no text and try to place them in HStouch and see how it looks like when I just place a text over the button.
it is already good to know the Font.
Ralph
- Snelvuur
nice work, i think i might use yours too. I once started with something and although it looked nice at the beginning it still didn't grasp me.. but now that i had a ipad2 for my birthday from my gf, i really need to make some effort into it
Anyway, not stealing your thread just showing and uploading the icons i had if someone finds them usefull.
- pictures.zip
- (149.69 KiB) Downloaded 840 times
Okay on request the empty bottom and top button as .psd file. layered.
and a few more buttons with icons.
The used font is futura lt book ( lt=light font weigth and means thin )
included is a .atn file wich needs to be copied in the photoshop/presests/photoshop actions/ folder
Its a small macro that will make the red version with a simple click and is really handy when you need to do complete folders.
So the easiest way is to make your own buttons and save them as a .png file and copy the complete folder before you start making the red versions.
Now we have all the original buttons in a save place we can start making the red ones.
- Go to photoshop open the File menu and choose automate and then menu item batch
- Now under play you should see default action. Change that to red
- Select the correct folder and if you are sure you have a copy press okay
- Photoshop now will start a small macro that changes all images to red ones in the selected folder.
- Now find your self a rename tool that can change the file name from *-normal.png to *.-pressed.png
- Copy the backed up original -normal buttons allong with the red -pressed ones and you are set.
The action is nothing more than a recorded simple macro in photoshop
and contains the menu option : Image >> adjustments >> Hue/Saturation
have a play with this option to make them blue or a color that matches your personal taste. Its a simple as opening up the actions panel, press record ... now do your tricks in photoshop like resize, change color etc... and press stop when finished. Now save the action and you are ready to let it loose on a bunch of gfx in a folder like described above.
Empty buttons
Empty buttons
- iz_button_bottom_phone-norm.png (5.4 KiB) Viewed 170672 times
- iz_button_bottom_home-norm.png (5.58 KiB) Viewed 170672 times
- iz_button_bottom_graph-norm.png (5.25 KiB) Viewed 170672 times
- iz_button_bottom_email-norm.png (5.55 KiB) Viewed 170672 times
- iz_button_bottom_agenda-norm.png (6.14 KiB) Viewed 170672 times
it didn't fit in one
also will add external download link.
Enjoy !
Empty buttons on mediafire
http://www.mediafire.com/?dkgidq5mzqxrq9h
Addon1
http://www.mediafire.com/?6l9gwq0u0kzt2n9
@ Snelvuur, feel free ! I started out in color but wasnt sadisfied about the amount of attention the took. Its like all these colorfull icons in the iphone/pad i sometimes get lost.....
Enjoy !
Addon1
- but_addon1.rar
- (64.37 KiB) Downloaded 857 times
- iz_button_bottom_internet-norm.png (5.45 KiB) Viewed 170675 times
- Snelvuur
Some more icons that i bumped into today which actually might look nice too.. http://www.foldersenkranten.nl/ (the menu bar icons) i still need to make a few extra, like closet room, laundry room, hallway, lobby? (entree) and outside
Hi Robin,
Just wanted to let you know how greatfull i am for your skin
Started using it (Although some areas are way to advanced for me) and i love it. So does the wife!
My biggest problem with building screens was that i have no clue how to design my own buttons. And most buttons found on the internet aren't nearly as complete.
Further to make the interface look nice, coherent and calm...you've done a wonderfull job!
Only using a few screens so far. Made a new remote for MCE viewing for my xbmc and bios setup. Found a vbs somewhere to use the http api to control xbmc and have expanded this alot.
Working awesome i must say.
Still making improvements over some events. For example when using the bios and play pause, it automaticly turns on the lights etc.
And now starting with the home view wich is a bit more challenging. (How do you show the last event run ?)
Anyways, just wanted to let you know im greatfull and thanks for all the hard work.
Michiel
Michiel
- Snelvuur
DrDoo: do share the xbmc stuff in the end too, i have xbmc too but since there is still so many changes in the api calls with xbmc i have not ventured further.
Sure
Credit go to Talisman from the Homeseer forum (http://board.homeseer.com/showthread.php?t=142187)
I just expanded a little on his script for some extra controls. Mind you though....i can copy paste and alter some simple things...i'm no scripter what so ever but is works perfectly for me.
' help for XBMC HTTP calls http://www.xbmc.org/wiki/?title=WebServerHTTP-API
' Button mappings http://xbmc.svn.sourceforge.net/viewvc/xbmc/tags/XBMC_2_0_1/XBMC/guilib/Key.h?view=markup
' No Script Procedure requires element input except volume, for the rest fill in any element into parameter 1.
' Uses a virtual device "X1" to store the IP and toggles in case of multiple XBMC machines on the network
Sub ToggleServerIP(parm as object)
' ----------------------- Toggle To Other Server IP ------------------------
Dim XBMCCurrentIP As String = hs.DeviceString("X1")
Dim XBMCBedroomIP As String = "10.255.1.31"
Dim XBMCLivingRoomIP As String = "10.255.1.30"
if XBMCCurrentIP = XBMCBedroomIP Then
hs.SetDeviceString("X1", XBMCLivingRoomIP)
hs.SetDeviceString("X2", "Living Room")
hs.writelog("XBMC", "Controlled XBMC is now " & hs.DeviceString("X2"))
End If
if XBMCCurrentIP = XBMCLivingRoomIP Then
hs.SetDeviceString("X1", XBMCBedroomIP)
hs.SetDeviceString("X2", "Bedroom")
End If
if XBMCCurrentIP <> XBMCLivingRoomIP and XBMCCurrentIP <> XBMCBedroomIP Then
hs.writelog("XBMC", "No IP was assigned, assigning to LivingRoom ..")
End If
End Sub
Sub Volume(parm as object)
' ------------------------ VOLUME Slider --------------------------
dim XBMCIPAdress As String = hs.DeviceString("X1")
dim XBMCVolumeValue = Val (parm(0))
dim XBMCVolumeCurrentValue As String
dim XBMCVolumeURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=setvolume(80)"
'Get Current Volume
XBMCVolumeCurrentValue = hs.URLAction ("http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=GetVolume", "GET", "", "")
'Compose new URL
XBMCVolumeURL = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=setvolume(" & XBMCVolumeValue & ")"
'Send command to XBMC web interface
hs.URLAction (XBMCVolumeURL, "GET", "", "")
hs.writelog("HSTouch", "XBMC Volume Changed to " & XBMCVolumeValue)
End Sub
Sub ToggleMute(parm as object)
' ----------------------- VOLUME Mute Toggle ------------------------
'Compose URL
dim XBMCMuteURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Mute()"
hs.URLAction (XBMCMuteURL, "GET", "", "")
hs.writelog("XBMC", "Toggled Mute")
End Sub
Sub TogglePause(parm as object)
' ----------------------- Pause / Play Toggle ------------------------
'Compose URL
dim XBMCPauseURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Pause()"
hs.URLAction (XBMCPauseURL, "GET", "", "")
hs.writelog("XBMC", "Pause/Play")
End Sub
Sub Play(parm as object)
' ----------------------- Play ------------------------
'Compose URL
dim XBMCPlayURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Sendkey(0xF050)"
hs.URLAction (XBMCPlayURL, "GET", "", "")
hs.writelog("XBMC", "Play")
End Sub
Sub StopPlayback(ByVal parm As Object)
' ----------------------- Stop Playback ------------------------
Dim XBMCIPAdress As String = hs.DeviceString("X1")
'Compose URL
Dim XBMCStopPlaybackURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Sendkey(0xF058)"
hs.URLAction(XBMCStopPlaybackURL, "GET", "", "")
hs.writelog("XBMC", "Stop")
End Sub
Sub Queue(ByVal parm As Object)
' ----------------------- Queue ------------------------
'Compose URL
Dim XBMCQueueURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Sendkey(0xF051)"
hs.URLAction(XBMCQueueURL, "GET", "", "")
hs.writelog("XBMC", "Added Media To Queue")
End Sub
Sub FastForward(ByVal parm As Object)
' ----------------------- FastForward ------------------------
'Compose URL
Dim XBMCFastForwardURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Sendkey(0xF046)"
hs.URLAction(XBMCFastForwardURL, "GET", "", "")
hs.writelog("XBMC", "FastForward")
End Sub
Sub Rewind(ByVal parm As Object)
' ----------------------- Rewind ------------------------
'Compose URL
Dim XBMCRewindURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Sendkey(0xF052)"
hs.URLAction(XBMCRewindURL, "GET", "", "")
hs.writelog("XBMC", "Rewind")
End Sub
Sub PlayBackNext(parm as object)
' ----------------------- PlayBack Next ------------------------
'Compose URL
dim XBMCNextURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=PlayNext()"
hs.URLAction (XBMCNextURL, "GET", "", "")
hs.writelog("XBMC", "Next")
End Sub
Sub PlayBackPrev(parm as object)
' ----------------------- PlayBack Previous ------------------------
'Compose URL
dim XBMCPrevURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=PlayPrev()"
hs.URLAction (XBMCPrevURL, "GET", "", "")
hs.writelog("XBMC", "Previous")
End Sub
Sub Guide(ByVal parm As Object)
' ----------------------- Guide ------------------------
'Compose URL
Dim XBMCGuideURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Sendkey(0xF04D)"
hs.URLAction(XBMCGuideURL, "GET", "", "")
hs.writelog("XBMC", "Guide")
End Sub
Sub ToggleWatched(ByVal parm As Object)
' ----------------------- Toggle Watched Status ------------------------
'Compose URL
Dim XBMCToggleWatchedURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Sendkey(0xF057)"
hs.URLAction(XBMCToggleWatchedURL, "GET", "", "")
hs.writelog("XBMC", "Toggle Watched")
End Sub
Sub NowPlaying(parm as object)
' ----------------------- Now Playing ------------------------
'Compose URL
dim XBMCNowPlayingURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=getcurrentlyplaying"
hs.URLAction (XBMCNowPlayingURL, "GET", "", "")
hs.writelog("XBMC", "Now Playing")
End Sub
' ------------------- Navigation Keys ---------------------
Sub NavBack(ByVal parm As Object)
' ----------------------- Navigate Back Button ------------------------
'Compose URL
Dim XBMCNavBackURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=SendKey(257)"
hs.URLAction(XBMCNavBackURL, "GET", "", "")
hs.writelog("XBMC", "Back")
End Sub
Sub Escape(ByVal parm As Object)
' ----------------------- ESC Button ------------------------
'Compose URL
Dim XBMCEscapeURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=SendKey(0xF01B)"
hs.URLAction(XBMCEscapeURL, "GET", "", "")
hs.writelog("XBMC", "Cancel")
End Sub
Sub NavConfirm(parm as object)
' ----------------------- Navigate Confirm Button ------------------------
'Compose URL
dim XBMCNavConfirmURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=SendKey(256)"
hs.URLAction (XBMCNavConfirmURL, "GET", "", "")
hs.writelog("XBMC", "Confirm")
End Sub
Sub NavUp(parm as object)
' ----------------------- Navigate Up Button ------------------------
'Compose URL
dim XBMCNavUpURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=SendKey(270)"
hs.URLAction (XBMCNavUpURL, "GET", "", "")
End Sub
Sub NavDown(parm as object)
' ----------------------- Navigate Down Button ------------------------
'Compose URL
dim XBMCNavDownURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=SendKey(271)"
hs.URLAction (XBMCNavDownURL, "GET", "", "")
End Sub
Sub NavLeft(parm as object)
' ----------------------- Navigate Left Button ------------------------
'Compose URL
dim XBMCNavLeftURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=SendKey(272)"
hs.URLAction (XBMCNavLeftURL, "GET", "", "")
End Sub
Sub NavRight(ByVal parm As Object)
' ----------------------- Navigate Right Button ------------------------
'Compose URL
Dim XBMCNavRightURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=SendKey(273)"
hs.URLAction(XBMCNavRightURL, "GET", "", "")
End Sub
Sub Info(ByVal parm As Object)
' ----------------------- Info Button ------------------------
'Compose URL
Dim XBMCInfoURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=SendKey(0xF049)"
hs.URLAction(XBMCInfoURL, "GET", "", "")
End Sub
Sub Menu(ByVal parm As Object)
' ----------------------- Menu Button ------------------------
'Compose URL
Dim XBMCMenuURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=SendKey(0xF043)"
hs.URLAction(XBMCMenuURL, "GET", "", "")
End Sub
Sub TAB(ByVal parm As Object)
' ----------------------- TAB Button ------------------------
'Compose URL
Dim XBMCTABURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=SendKey(0xF009)"
hs.URLAction(XBMCTABURL, "GET", "", "")
End Sub
Sub SubtitleDelay(ByVal parm As Object)
' ----------------------- Subtitle Delay ------------------------
'Compose URL
Dim XBMCSubtitleDelayURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(52)"
hs.URLAction(XBMCSubtitleDelayURL, "GET", "", "")
End Sub
Sub SubtitleDelayPlus(ByVal parm As Object)
' ----------------------- Subtitle Delay Forward ------------------------
'Compose URL
Dim XBMCSubtitleDelayPlusURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(53)"
hs.URLAction(XBMCSubtitleDelayPlusURL, "GET", "", "")
End Sub
Sub NextLanguage(ByVal parm As Object)
' ----------------------- Next Language ------------------------
'Compose URL
Dim XBMCNextLanguageURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(56)"
hs.URLAction(XBMCNextLanguageURL, "GET", "", "")
End Sub
Sub ScanItem(ByVal parm As Object)
' ----------------------- Scan Item ------------------------
'Compose URL
Dim XBMCScanItemURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(201)"
hs.URLAction(XBMCScanItemURL, "GET", "", "")
End Sub
Sub ShowSubtitle(ByVal parm As Object)
'Compose URL
Dim XBMCShowSubtitleURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(25)"
hs.URLAction(XBMCShowSubtitleURL, "GET", "", "")
End Sub
Sub NextSubtitle(ByVal parm As Object)
'Compose URL
Dim XBMCNextSubtitleURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(26)"
hs.URLAction(XBMCNextSubtitleURL, "GET", "", "")
End Sub
Sub CurrentPlaylist(ByVal parm As Object)
'Compose URL
Dim XBMCCurrentPlaylistURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=ExecBuiltIn(ActivateWindow(musicplaylist))"
hs.URLAction(XBMCCurrentPlaylistURL, "GET", "", "")
End Sub
' ---------------- Navigate Directly To Pages ----------------
Sub NavPageHome(ByVal parm As Object)
' ----------------------- Navigate to HomePage ------------------------
'Compose URL
Dim XBMCNavHomeURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=ExecBuiltIn(ActivateWindow(Home))"
hs.URLAction(XBMCNavHomeURL, "GET", "", "")
hs.writelog("XBMC", "Navigating to Home Page")
End Sub
Sub NavPageVideos(ByVal parm As Object)
' ----------------------- Navigate to Videos ------------------------
'Compose URL
Dim XBMCNavPageVideosURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=ExecBuiltIn(ActivateWindow(Videos,Files,return))"
hs.URLAction(XBMCNavPageVideosURL, "GET", "", "")
hs.writelog("XBMC", "Navigating to Video Page")
End Sub
Sub NavPageMusic(ByVal parm As Object)
'Compose URL
Dim XBMCNavPageMusicURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=ExecBuiltIn(ActivateWindow(musicfiles,Muziek,return))"
hs.URLAction(XBMCNavPageMusicURL, "GET", "", "")
hs.writelog("XBMC", "Navigating to Music Page")
End Sub
Sub ShutDown(ByVal parm As Object)
' ----------------------- Shutdown the Machine ------------------------
'Compose URL
Dim XBMCShutDownURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Shutdown()"
hs.URLAction(XBMCShutDownURL, "GET", "", "")
hs.writelog("XBMC", "Shutting down " & XBMCIPAdress)
End Sub
Sub Restart(ByVal parm As Object)
' ----------------------- Restart HTPC ------------------------
'Compose URL
Dim XBMCRestartURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Restart()"
hs.URLAction(XBMCRestartURL, "GET", "", "")
hs.writelog("XBMC", "Restarting HTPC " & XBMCIPAdress)
End Sub
Sub FileDelete(ByVal parm As Object)
' ----------------------- DeleteFile ------------------------
'Compose URL
Dim XBMCFileDeleteURL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(80)"
hs.URLAction(XBMCFileDeleteURL, "GET", "", "")
hs.writelog("XBMC", "Delete File")
End Sub
Very good to read you are enjoying my interface!
It could be that the light problem is due to stacked buttons. Just try to move the piece by piece to see if there is any...
Keep in mind that a button it's state can be invisible ! so mainly you only see a rectangle that is selected.
A real beginners question, but could someone help me on my way in how to use the above script in hstouch?
groeten,
Hi Harry,
Im asuming you are talking about the xbmc script.
Its pretty easy really.
1) Copy paste the code below (Little Update for more functions) in a new text document and save this document as XBMC.vb
2) Place this script in your HSpro\Scripts Directory
3) Change the IP adresses in the script to reflect your own XBMC box.
3) In Homeseer on the Status tab
4) Add Device - Device Name: XBMCip - Device Type: Status Only - Lettercode: X1
5) Add Device - Device Name: XBMCLocation - Device Type: Status Only - Lettercode: X2
6) Create a button in HStouch, for example Play.
7) ActionWhenReleased - Homeseer:Run a Homeseer script ... - Script: XBMC.vb - ScriptProcedure: Play
Do this for every function you want to use.
Almost forgot...you have to run the ToggleServerIP first for the script to work. This sets the IP adress to use in the StatusDevice X1.
You can off course also use the functions from an event. Make an event that runs the script with the specific funtion(s). Make button that runs a homeseer event.
Again, credit go to Talisman from the Homeseer forum (http://board.homeseer.com/showthread.php?t=142187)
End If
End If
End If
End Sub
'Get Current Volume
'Compose new URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
Sub SMS2(ByVal parm As Object)
' ----------------------- Navigate to titles A/B/C ------------------------
'Compose URL
Dim SMS2URL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(142)"
hs.URLAction(SMS2URL, "GET", "", "")
End Sub
Sub SMS3(ByVal parm As Object)
' ----------------------- Navigate to titles D/E/F ------------------------
'Compose URL
Dim SMS3URL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(143)"
hs.URLAction(SMS3URL, "GET", "", "")
End Sub
Sub SMS4(ByVal parm As Object)
' ----------------------- Navigate to titles G/H/I ------------------------
'Compose URL
Dim SMS4URL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(144)"
hs.URLAction(SMS4URL, "GET", "", "")
End Sub
Sub SMS5(ByVal parm As Object)
' ----------------------- Navigate to titles J/K/L ------------------------
'Compose URL
Dim SMS5URL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(145)"
hs.URLAction(SMS5URL, "GET", "", "")
End Sub
Sub SMS6(ByVal parm As Object)
' ----------------------- Navigate to titles M/N/O ------------------------
'Compose URL
Dim SMS6URL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(146)"
hs.URLAction(SMS6URL, "GET", "", "")
End Sub
Sub SMS7(ByVal parm As Object)
' ----------------------- Navigate to titles P/Q/R ------------------------
'Compose URL
Dim SMS7URL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(147)"
hs.URLAction(SMS7URL, "GET", "", "")
End Sub
Sub SMS8(ByVal parm As Object)
' ----------------------- Navigate to titles S/T/U ------------------------
'Compose URL
Dim SMS8URL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(148)"
hs.URLAction(SMS8URL, "GET", "", "")
End Sub
Sub SMS9(ByVal parm As Object)
' ----------------------- Navigate to titles V/W/X/Y/Z ------------------------
'Compose URL
Dim SMS9URL As String = "http://" & XBMCIPAdress & "/xbmcCmds/xbmcHttp?command=Action(149)"
hs.URLAction(SMS9URL, "GET", "", "")
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
'Compose URL
End Sub
With this explanation even I should be able to do this. Thanks, I really appreciate it!
*** Update *** It's working so far!
groeten,
Great! Glad to be of help.
Robin (of iemand anders),
Ik zie dat je een batterystatus percentage op je pagina weergeeft? Kun je mij vertellen hoe ik dit moet doen? Kan het nergens terugvinden namelijk.
Groet,
Kees
Groet,
Kees
