You need to have a cable to the lock, which is possible using different routes. I`have seen doosr where there is a hole drilled from the top of the door to the position of the lock. There are also doors where the kabel comes out on the inside right behind the lock and goes true a cablecondutor
U can also use a electric (slot kom) to open and close the door (this is normlay done on doors located inside a building)
These locks are arround 700 euro`s i think, in that case an Nemef Radaris lock is not that expensive after all
(Because it it battery operated as far is i can tell)
