Eneco Toon Homeseer Script/Plugin
Forum over Homeseer Plugin ontwikkelingen, hierin staan aparte forums voor bijvoorbeeld Plugwise, RFXcom, Fritzbox, Alphatronics etc.
Moderator: Digit
Ierlandfan
Re: Eneco Toon Homeseer Script/Plugin
Post by Ierlandfan »
Hi Bart,
since your script already uses the API from Toon I was wondering whether you can modify it to backup the data from the energy and gas.
Since Toon on Tablet it's possible to show it through the API and with a little fiddling I got the json code. It follows the same structure as your program for as far as I know. You can make yourself immortal by creating a plugin or standalone script to backup this data :-)
Here's an example:
<The usual login string>
https://toonopafstand.eneco.nl/toonMobi ... e-checksum>
Output is json and all the data (months, weeks, days,years) is there.
This is the string for gas
Again data is json ouput, the same as electricity.
jjnj
Post by jjnj »
Does anybody of you know if it is possible to allow somebody external access to the Toon with a different username and password then the original one? Someone is trying to help implement Toon into Domoticz but he needs access to my Toon for this.
Right now if I give my access information he wil also be able to access my Eneco account which has payment info
jjnj
Post by jjnj »
Dear Bart,
I am very interested in helping you get more our of Toon. Can you send me a PM?
Br,
Joost
bartbakels
Post by bartbakels »
Sorry, somehoq i did not get the updates on this forum topic. So sorry for the late response. Ierlandfan, i will look into this but your talking about the historical data am i correct? For the moment i am using bdgraps script for this.
Joost pm send
Reagrds
Bart
(ON ESXI )on NUC
bartbakels
ierlandfan,
I will look into this as soon as possible, how did you find this? How do you want to save this data? to a simple tekst file?
regards
Bart
(ON ESXI )on NUC
bartbakels
Hi ,
I added the function to readout the historical data for gas and elektro, it generates 2 tekstfiles for now. I haveing trouble to understand whats being send in JSON and interpret this. What would you like to do with this info.
btw since the last toon update a lot more data is available from the toon, i will also look into that.
bart
(ON ESXI )on NUC
blueone
Post by blueone »
Do you know if it also possible to read the opentherm messages ID from the toon to get more information like the water temperatures etc?
bartbakels
I can look into this, but unfortunatly i dont have an opentherm cv...
Bart
(ON ESXI )on NUC
CryptomeNL
Post by CryptomeNL »
Hallo mensen, ik zie veel mooie en goede dingen in de voorgaande berichten.
Ikzelf heb Homeseer 2 en ben grafisch technicus, dus scripts etc zijn behoorlijk ingewikkeld voor mij.
Nu heb ik net een nieuwe ketel (opentherm dat wel) en ik zou graag de Toon intergreren in mijn door tablets bediende huis.
Voor grafische dingen zou ik best willen helpen als dat gewenst is. Zou iemand mij (mag ook in engels) uit kunnen leggen hoe ik dit installeer op HS2 systeem?
ewillems
Post by ewillems »
Hi Bart,
I'm willing to help to rewrite the toon plugin and make a better integration with Homeseer (root/child device, HSTouch thermostat compatibility etc.). Can you send me your latest version, so I can use that as base for my rewrite?
ps. As Homeseer 3.0.0.152 has been released, you can release your latest version.
Erwin
bartbakels
Erwin,
Great to hear that, hereby the latest version. I was just thinking about rewriting the script. Let me know if u need additional help. I know that there are some issues with this version regarding the gas usage, didn't had the time to debug
Imports system.io
Sub Main(params as object)
	'Control Eneco Toon Thermostat For Homeseer3 v1.2
	'Made by Bart Bakels/ Promedes.nl
	'Usage Script parameters; SETPOINT|MODE|HISTORICALDATA (UPDATE as string)
	' No setpoint change fill in nothing; |MODE|
	' no mode change fill in nothing SETPOINT||
	' Only Historical Data ||UPDATE
	' only status update  fill in ||
	' modestates; 0=comfort; 1=thuis 2=slapen 3=weg
	'ONLY USE With HS3 v81 and above
	'Enable Debug Messages Level
	'0=None
	'1=Info
	'2=All
	Dim Debug = 0
	'Get parameters
	Dim parameters(3) as String
	parameters = params.Split("|")
	Dim setpoint As String = parameters(0)
	Dim selectedmode As String = parameters(1)
	Dim gethistoricaldata As String = parameters(2)
	'DIM Parameters
	'random needs to be a valid UUID1
	Dim Random = "12344178-1544-5648-1234-567882545662"
	'For file Writing
	dim fso as object
	dim f as object
	Const ForReading = 1, ForWriting = 2, ForAppending = 8
	Dim Username
	Dim Password
	Dim indexstart
	Dim indexend
	Dim loginresponse
	Dim startresponse
	Dim logoutresponse
	Dim stateresponse
	Dim state1response
	Dim state2response
	Dim state3response
	Dim spsetresponse
	Dim modesetresponse
	Dim edataresponse
	Dim gdataresponse
	Dim clientid
	Dim clientidchecksum
	Dim agreementid
	Dim agreementidchecksum
	Dim Street
	Dim Housenumber
	Dim postalcode
	Dim City
	Dim Errorflag = 0
	'homeseer connection Declaring
	Dim dv As Scheduler.Classes.DeviceClass = Nothing
	Dim Value
	Dim DevExists
	Dim GPair = New VGPair
	Dim Ref
	'Get INI Settings
	Username = hs.GetINISetting("LOGIN", "Username", "user", "Toonscript.ini")
	Password = hs.GetINISetting("LOGIN", "Password", "pass", "Toonscript.ini")
	If Username = "user" Then
		hs.WriteLog("ERROR Toon", "No valid  username provided in Toonscript.ini")
		Errorflag = 1
	End If
	If Password = "pass" Then
		hs.WriteLog("ERROR Toon", "No valid password provided in Toonscript.ini")
		Errorflag = 1
	End If
	'Login
	If errorflag = 0 Then 'errorcheck
		loginresponse = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/login?username=" & Username & "&password=" & Password,"GET", "", "")
		indexstart = InStr(loginresponse, """success"": true")
		If indexstart = 0 Then
			hs.WriteLog("Toon Error", "Login Failed, not a Success")
			errorflag = 1
		End If
		If loginresponse = Nothing Then
			hs.WriteLog("Toon Error", "Login Failed, No reponse")
			errorflag = 1
		End If
		If Debug = 2 Then
			hs.WriteLog("Toon response login", loginresponse)
		End If
	End If ' errorcheck
	'find IDS
		'find ClientID
		indexstart = InStr(loginresponse," ""clientId"": ")
		If indexstart >  0 Then
			indexend = InStr(indexstart,loginresponse,",")
			indexstart = indexstart + 13
			indexend = indexend-indexstart
			clientid = Mid(loginresponse,indexstart , indexend )
			clientid = Replace(clientid,"""","")
			If Debug = 2 Then
				hs.WriteLog("Toon ClientID", clientid)
			End If
		Else
			errorflag = 1
			hs.WriteLog("Toon Error", "could not find Client ID")
		End If
		'find ClientID CheckSUM
		indexstart = InStr(loginresponse," ""clientIdChecksum"": ")
			indexstart = indexstart + 21
			clientidchecksum = Mid(loginresponse,indexstart , indexend )
			clientidchecksum = Replace(clientidchecksum,"""","")
			If Debug = 2 Then
				hs.WriteLog("Toon ClientID CheckSUM", clientidchecksum)
			End If
		Else
			errorflag = 1
		End If
		'find AgreementID
		indexstart = InStr(loginresponse," ""agreementId"": ")
			indexstart = indexstart + 16
			agreementid = Mid(loginresponse,indexstart , indexend )
			agreementid = Replace(agreementid,"""","")
			If Debug = 2 Then
				hs.WriteLog("Toon AgreementID", agreementid)
			End If
		Else
			errorflag = 1
			hs.WriteLog("Toon Error", "could not find Agreement ID")
		End If
		'find AgreementID CheckSum
		indexstart = InStr(loginresponse," ""agreementIdChecksum"": ")
			indexstart = indexstart + 24
			agreementidchecksum = Mid(loginresponse,indexstart , indexend )
			agreementidchecksum = Replace(agreementidchecksum,"""","")
			If Debug = 2 Then
				hs.WriteLog("Toon AgreementID CheckSUM", agreementidchecksum)
			End If
		Else
			errorflag = 1
			hs.WriteLog("Toon Error", "could not find Agreement ID CheckSUM")
		End If
		'find street
		indexstart = InStr(loginresponse," ""street"": ")
			indexstart = indexstart + 11
			street = Mid(loginresponse,indexstart , indexend )
			street = Replace(street,"""","")
			If Debug = 2 Then
				hs.WriteLog("Toon Street", street)
			End If
		Else
			errorflag = 1
			hs.WriteLog("Toon Error", "could not find Street")
		End If
		'find Housenumber
		indexstart = InStr(loginresponse," ""houseNumber"": ")
			housenumber = Mid(loginresponse,indexstart , indexend )
			housenumber = Replace(housenumber,"""","")
			If Debug = 2 Then
				hs.WriteLog("Toon HouseNumber", housenumber)
			End If
		Else
			errorflag = 1
			hs.WriteLog("Toon Error", "could not find Housenumber")
		End If
		'find Postalcode
		indexstart = InStr(loginresponse," ""postalCode"": ")
			indexstart = indexstart + 15
			postalcode = Mid(loginresponse,indexstart , indexend )
			postalcode = Replace(postalcode,"""","")
			If Debug = 2 Then
				hs.WriteLog("Toon postalCode", postalcode)
			End If
		Else
			errorflag = 1
			hs.WriteLog("Toon Error", "could not find postalCode")
		End If
		'find City
		indexstart = InStr(loginresponse," ""city"": ")
			indexstart = indexstart + 9
			city = Mid(loginresponse,indexstart , indexend )
			city = Replace(city,"""","")
			If Debug = 2 Then
				hs.WriteLog("Toon City", city)
			End If
		Else
			errorflag = 1
			hs.WriteLog("Toon Error", "could not find City")
		End If
	End If ' errorcheck
	'Start
		startresponse = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/start?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum & "&agreementId=" & agreementid & "&agreementIdChecksum=" & agreementidchecksum & "&random=" & random,"GET", "", "")
		If Debug = 2 Then
			hs.WriteLog("Toon response Start", startresponse)
		End If
		indexstart = InStr(startresponse, """success"": true")
			hs.WriteLog("Toon Error", "Could Not Start Toon Query")
			errorflag = 1
		End If
	End If ' errorcheck
	'Write Manual Setpoint to Toon
		Dim setpointraw
		If Not setpoint = "" Then
			setpointraw = setpoint * 100
			spsetresponse = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/setPoint?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum & "&value=" & setpointraw & "&random=" & random,"GET", "", "")
			If Debug > 1 Then
				hs.WriteLog("Toon SP written","SP set to: " & setpoint & "  response: " & spsetresponse)
				hs.WriteLog("Toon SP written","SP set to: " & setpointraw)
			End If
			indexstart = InStr(spsetresponse, """success"": true")
				hs.WriteLog("Toon Error", "Could Not change Setpoint")
			End If
		End If
	End If ' errorcheck
	'Write Mode to Toon
		If Not selectedMode = "" Then
			modesetresponse = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/schemeState?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum & "&state=2&temperatureState=" & selectedMode & "&random=" & random,"GET", "", "")
			If Debug > 1 Then
				hs.WriteLog("Toon Mode written","Mode set to: " & selectedMode & "  response: " & modesetresponse)
			End If
			indexstart = InStr(modesetresponse, """success"": true")
				hs.WriteLog("Toon Error", "Could Not change Toon Mode")
			End If
		End If
	End If ' errorcheck
	'Retrieve Toon State 1
		state1response = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/retrieveToonState?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum & "&random=" & random,"GET", "", "")
		If Debug = 2 Then
			hs.WriteLog("Toon response status 1 ", state1response)
		End If
	End If ' errorcheck
	'Retrieve Toon State 2
		state2response = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/retrieveToonState?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum & "&random=" & random,"GET", "", "")
		If Debug = 2 Then
			hs.WriteLog("Toon response status 2 ", state2response)
		End If
	End If ' errorcheck
	'Retrieve Toon State 3 DISABLED
		'state3response = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/retrieveToonState?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum & "&random=" & random,"GET", "", "")
		'If Debug = 2 Then
		'hs.WriteLog("Toon response status 3 ", state3response)
		'End If
		stateresponse = state3response & state2response & state1response
		fso = CreateObject("Scripting.FileSystemObject")
		f = fso.OpenTextFile("c:\temp\ToonState.txt", ForWriting, True)
		f.writeline (stateresponse)
		If Debug = 2 Then
			hs.WriteLog("Toon response TOTAL ", stateresponse)
		End If
	End If ' errorcheck
	'Get GAS and Electro Historical DATA
	if gethistoricaldata = "UPDATE" then
	'Get Electro historical data
		edataresponse = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/getElecGraphData?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum,"GET", "", "")
		f = fso.OpenTextFile("c:\temp\ToonElectroData.txt", ForWriting, True)
		f.writeline (edataresponse)
		If Debug = 2 Then
			hs.WriteLog("historical E data response", edataresponse)
		End If
	'Get Gas historical data
		gdataresponse = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/getGasGraphData?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum,"GET", "", "")
		f = fso.OpenTextFile("c:\temp\ToonGasData.txt", ForWriting, True)
		f.writeline (gdataresponse)
		If Debug = 2 Then
			hs.WriteLog("historical G data response", gdataresponse)
		End If
	End If 'check historical data
	End If ' errorcheck
	'Logout
		logoutresponse = hs.URLAction("https://toonopafstand.eneco.nl/toonMobileBackendWeb/client/auth/logout?clientId=" & clientid & "&clientIdChecksum=" & clientidchecksum & "&random=" & random,"GET", "", "")
		If Debug = 2 Then
			hs.WriteLog("Toon response logout", logoutresponse)
		End If
		indexstart = InStr(logoutresponse, "success")
			hs.WriteLog("Toon Error", "Could Not Logout")
			errorflag = 1
		End If
	End If ' errorcheck
	'decode state
		'Current temperature
		Dim currenttemp
		indexstart = InStr(stateresponse," ""currentTemp"": ")
		If indexstart >  1 Then
			indexend = InStr(indexstart,stateresponse,",")
			currenttemp = Mid(stateresponse,indexstart , indexend )
			currenttemp = currenttemp/100
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon CurrentTemp", currenttemp)
		End If
		'Current Setpoint
		Dim currentsetpoint
		indexstart = InStr(stateresponse," ""currentSetpoint"": ")
			indexstart = indexstart + 20
			currentsetpoint = Mid(stateresponse,indexstart , indexend )
			currentsetpoint = currentSetpoint/100
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon CurrentSP", currentsetpoint)
		End If
		'Current Burner status
		Dim burnerstatus
		indexstart = InStr(stateresponse," ""burnerInfo"": ")
			burnerstatus = Mid(stateresponse,indexstart , indexend )
			burnerstatus = Replace(burnerstatus, """", "")
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon burnerStatus", burnerstatus)
		End If
		'Current Modulation status
		Dim modulationstatus
		indexstart = InStr(stateresponse," ""currentModulationLevel"": ")
			indexstart = indexstart + 27
			modulationstatus = Mid(stateresponse,indexstart , indexend )
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon modulationStatus", modulationstatus)
		End If
		'Current Temperature Mode
		Dim currentmode As String
		Dim currentmodetext As String
		indexstart = InStr(stateresponse," ""activeState"": ")
			currentmode = Mid(stateresponse,indexstart , indexend )
			If currentmode = "-1"
				currentmodetext = "Manueel"
			End If
			If currentmode = "0"
				currentmodetext = "Comfort"
			End If
			If currentmode = "1"
				currentmodetext = "Thuis"
			End If
			If currentmode = "2"
				currentmodetext = "Slapen"
			End If
			If currentmode = "3"
				currentmodetext = "Weg"
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon currentmode", "Value: " & currentmode & " text: " & currentmodetext)
		End If
		'Current Gas Usage
		Dim gasusage
		indexstart = InStr(stateresponse, " ""gasUsage"":")
			indexstart = InStr(indexstart,stateresponse," ""value"": ")
				indexstart = indexstart + 10
				gasusage = Mid(stateresponse,indexstart , indexend )
			End If
		else gasusage=0
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Gasmeter Usage", gasusage)
		End If
		'Current Gas Day Cost
		Dim gasdaycosts
			indexstart = InStr(indexstart,stateresponse," ""dayCost"": ")
				indexstart = indexstart + 12
				gasdaycosts = Mid(stateresponse,indexstart , indexend )
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Gasmeter DayCost", gasdaycosts)
		End If
		'Current Gas Day Usage
		Dim gasdayusage
			indexstart = InStr(indexstart,stateresponse," ""dayUsage"": ")
				gasdayusage = Mid(stateresponse,indexstart , indexend )
				gasdayusage = gasdayusage/1000
			End If
		else gasdayusage = 0
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Gasmeter DayUsage", gasdayusage)
		End If
		'Current Gas Average Day Value
		Dim gasavgdayvalue
			indexstart = InStr(indexstart,stateresponse," ""avgDayValue"": ")
				gasavgdayvalue = Mid(stateresponse,indexstart , indexend )
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Gasmeter avg DayValue", gasavgdayvalue)
		End If
		'Current Gas Average Value
		Dim gasavgvalue
			indexstart = InStr(indexstart,stateresponse," ""avgValue"": ")
				gasavgvalue = Mid(stateresponse,indexstart , indexend )
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Gasmeter avg Value", gasavgvalue)
		End If
		'Current Gas Meter value
		Dim gasmeter
			indexstart = InStr(indexstart,stateresponse," ""meterReading"": ")
				indexstart = indexstart + 17
				gasmeter = Mid(stateresponse,indexstart , indexend )
				gasmeter = gasmeter/1000
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Gasmeter Value", gasmeter)
		End If
		'Current E Usage
		Dim powerusage
		indexstart = InStr(stateresponse, " ""powerUsage"":")
				powerusage = Mid(stateresponse,indexstart , indexend )
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Powerusage", powerusage)
		End If
		'Current Power Meter 1 value
		Dim powermeter1
				powermeter1 = Mid(stateresponse,indexstart , indexend )
				powermeter1	= powermeter1/1000
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Powermeter1 Value", powermeter1)
		End If
		'Current Power Meter 2 value
		Dim powermeter2
			indexstart = InStr(indexstart,stateresponse," ""meterReadingLow"": ")
				powermeter2 = Mid(stateresponse,indexstart , indexend )
				powermeter2	= powermeter2/1000
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Powermeter2 Value", powermeter2)
		End If
		'Current Power Meter day costs
		Dim powerdaycosts
				powerdaycosts = Mid(stateresponse,indexstart , indexend )
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Power DayCosts", powerdaycosts)
		End If
		'Current Power Meter day usage High
		Dim powerdayusagehigh
				powerdayusagehigh = Mid(stateresponse, indexstart, indexend)
				powerdayusagehigh = powerdayusagehigh / 1000
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Power DayUsage High", powerdayusagehigh)
		End If
		'Current Power Meter day usage Low
		Dim powerdayusagelow
			indexstart = InStr(indexstart,stateresponse," ""dayLowUsage"": ")
				powerdayusagelow = Mid(stateresponse,indexstart , indexend )
				powerdayusagelow = powerdayusagelow/1000
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Power DayUsage Low", powerdayusagelow)
		End If
		Dim powerdayusage
		powerdayusage = powerdayusagelow + powerdayusagehigh
		If Debug > 0 Then
			hs.WriteLog("Toon Power DayUsage Total", powerdayusage)
		End If
		'Current Power Meter Average Value
		Dim poweravgvalue
				poweravgvalue = Mid(stateresponse,indexstart , indexend )
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Power Average Value", poweravgvalue)
		End If
		'Current Power Meter produced
		Dim powerproducedvalue
			indexstart = InStr(indexstart,stateresponse," ""valueProduced"": ")
				indexstart = indexstart + 18
				powerproducedvalue = Mid(stateresponse,indexstart , indexend )
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Power Produced Value", powerproducedvalue)
		End If
		'Current Power Meter produced costs
		Dim powerproducedcosts
			indexstart = InStr(indexstart,stateresponse," ""dayCostProduced"": ")
				powerproducedcosts = Mid(stateresponse,indexstart , indexend )
			End If
		End If
		If Debug > 0 Then
			hs.WriteLog("Toon Power Produced Costs", powerproducedcosts)
		End If
		'Create/Update HomeseerDevices
		Value = currenttemp
		If Value <> Nothing Then
			DevExists = hs.DeviceExistsAddress("Toon-PV", False)
			If DevExists = -1 Then
				dv = hs.NewDeviceEx("Toon CV Temperatuur")
				dv.Location(hs) = "Toon"
				dv.Location2(hs) = "Status"
				dv.Address(hs) = "Toon-PV"
				dv.Device_Type_String(hs) = "Toon Thermostaat"
				dv.Image(hs) = "/images/toon/toon.png"
				Ref = hs.GetDeviceRef("Toon-PV")
				GPair = New VGPair
				GPair.PairType = VSVGPairType.Range
				GPair.RangeStart = 0
				GPair.RangeEnd = 100
				GPair.Graphic = "/images/toon/Temperature.png"
				hs.DeviceVGP_AddPair(ref, GPair)
			End If
			hs.SetDeviceValueByRef(Ref, Value , False)
			hs.SetDeviceString(Ref, Value & " Graden", True)
		End If
		'Current Setpoint
		Value = currentsetpoint
			DevExists = hs.DeviceExistsAddress("Toon-SP", False)
				dv = hs.NewDeviceEx("Toon CV Setpoint")
				dv.Address(hs) = "Toon-SP"
				dv.MISC_Set(hs, Enums.dvMISC.SHOW_VALUES)
				Ref = hs.GetDeviceRef("Toon-SP")
				GPair = New VGPair
				GPair.Graphic = "/images/toon/TemperatureSP.png"
				hs.DeviceScriptButton_AddButton(ref, " - ","0","toon.vb","ButtonsSP","Min",1,1,0)
				hs.DeviceScriptButton_AddButton(ref, " + ","1","toon.vb","ButtonsSP","Plus",1,2,0)
			End If
		End If
		'Current BurnerState
		Value = burnerstatus
			DevExists = hs.DeviceExistsAddress("Toon-Brander", False)
				dv = hs.NewDeviceEx("Toon CV Status")
				dv.Address(hs) = "Toon-Brander"
				Ref = hs.GetDeviceRef("Toon-Brander")
				GPair = New VGPair
				GPair.PairType = VSVGPairType.SingleValue
				GPair.Set_Value = 0
				GPair.Graphic = "/images/toon/Idle.png"
				GPair = New VGPair
				GPair.Set_Value = 1
				GPair.Graphic = "/images/toon/Heat.png"
			End If
			hs.SetDeviceValueByRef(Ref, Value , True)
			If burnerstatus = 0 Then
				hs.SetDeviceString(Ref, "Idle<BR> <BR>Modulatie: " & modulationstatus & " %", False)
			End If
			If burnerstatus = 1 Then
				hs.SetDeviceString(Ref, "Warmtevraag<BR><BR>Modulatie: " & modulationstatus & " %", False)
			End If
		End If
		'Current Mode
		Value = currentmode
			DevExists = hs.DeviceExistsAddress("Toon-Modus", False)
				dv = hs.NewDeviceEx("Toon CV Modus")
				dv.Address(hs) = "Toon-Modus"
				Ref = hs.GetDeviceRef("Toon-Modus")
				GPair = New VGPair
				GPair.Set_Value = 0
				GPair.Graphic = "/images/toon/Comfort.png"
				GPair = New VGPair
				GPair.Set_Value = 1
				GPair.Graphic = "/images/toon/Home.png"
				GPair = New VGPair
				GPair.Set_Value = 2
				GPair.Graphic = "/images/toon/Sleep.png"
				GPair = New VGPair
				GPair.Set_Value = 3
				GPair.Graphic = "/images/toon/Away.png"
				'Button Test
				hs.DeviceScriptButton_AddButton(ref, "Comfort","0","toon.vb","ButtonsMode","Comfort",1,1,0)
				hs.DeviceScriptButton_AddButton(ref, "Thuis","1","toon.vb","ButtonsMode","Thuis",1,2,0)
				hs.DeviceScriptButton_AddButton(ref, "Slapen","2","toon.vb","ButtonsMode","Slapen",2,1,0)
				hs.DeviceScriptButton_AddButton(ref, "Weg","3","toon.vb","ButtonsMode","Weg",2,2,0)
			End If
			hs.SetDeviceString(Ref, "Modus: " & currentmodetext, False)
		End If
		'Current Gas uSage
		Value = gasusage
			DevExists = hs.DeviceExistsAddress("Toon-GasVerbruik", False)
				dv = hs.NewDeviceEx("Toon Gas Huidig Verbruik")
				dv.Address(hs) = "Toon-GasVerbruik"
				Ref = hs.GetDeviceRef("Toon-GasVerbruik")
				GPair = New VGPair
				GPair.RangeEnd = 100000
				GPair.Graphic = "/images/toon/Gas.png"
			End If
			hs.SetDeviceString(Ref, Value & " l/H", False)
		'Current Power Usage
		Value = powerusage
			DevExists = hs.DeviceExistsAddress("Toon-StroomVerbruik", False)
				dv = hs.NewDeviceEx("Toon Elektra Huidig Verbruik")
				dv.Address(hs) = "Toon-StroomVerbruik"
				Ref = hs.GetDeviceRef("Toon-StroomVerbruik")
				GPair = New VGPair
				GPair.Graphic = "/images/toon/Power.png"
			End If
			hs.SetDeviceString(Ref, Value & " Watt", False)
		End If
		'PowerMeter I
		Value = powermeter1
			DevExists = hs.DeviceExistsAddress("Toon-Telwerk I", False)
				dv = hs.NewDeviceEx("Toon Elektra Telwerk I")
				dv.Address(hs) = "Toon-Telwerk I"
				Ref = hs.GetDeviceRef("Toon-Telwerk I")
				GPair = New VGPair
				GPair.RangeEnd = 100000000
				GPair.Graphic = "/images/toon/Meter.png"
			End If
			hs.SetDeviceString(Ref, Value & " kWh", False)
		End If
		'PowerMeter II
		Value = powermeter2
			DevExists = hs.DeviceExistsAddress("Toon-Telwerk II", False)
				dv = hs.NewDeviceEx("Toon Elektra Telwerk II")
				dv.Address(hs) = "Toon-Telwerk II"
				Ref = hs.GetDeviceRef("Toon-Telwerk II")
				GPair = New VGPair
			End If
		End If
		'Gasmeter
		Value = gasmeter
			DevExists = hs.DeviceExistsAddress("Toon-GasTelwerk", False)
				dv = hs.NewDeviceEx("Toon Gas Telwerk")
				dv.Address(hs) = "Toon-GasTelwerk"
				Ref = hs.GetDeviceRef("Toon-GasTelwerk")
				GPair = New VGPair
			End If
			hs.SetDeviceString(Ref, Value & " m3", False)
		End If
		'Power Daycosts
		Value = powerdaycosts
			DevExists = hs.DeviceExistsAddress("Toon-E Kosten Dag", False)
				dv = hs.NewDeviceEx("Toon Elektra Kosten Dag")
				dv.Address(hs) = "Toon-E Kosten Dag"
				Ref = hs.GetDeviceRef("Toon-E Kosten Dag")
				GPair = New VGPair
				GPair.Graphic = "/images/toon/Costs.png"
			End If
			hs.SetDeviceString(Ref, "€ " & Value , False)
		End If
		'Gas Day Costs
		Value = gasdaycosts
			DevExists = hs.DeviceExistsAddress("Toon-Gas Kosten Dag", False)
				dv = hs.NewDeviceEx("Toon Gas Kosten Dag")
				dv.Address(hs) = "Toon-Gas Kosten Dag"
				Ref = hs.GetDeviceRef("Toon-Gas Kosten Dag")
				GPair = New VGPair
			End If
			hs.SetDeviceString(Ref, "€ " & Value, False)
		End If
		'Gas Day Total Usage
		Value = gasdayusage
			DevExists = hs.DeviceExistsAddress("Toon-Gas Dag Verbruik", False)
				dv = hs.NewDeviceEx("Toon Gas Verbruik Dag")
				dv.Address(hs) = "Toon-Gas Dag Verbruik"
				Ref = hs.GetDeviceRef("Toon-Gas Dag Verbruik")
				GPair = New VGPair
				GPair.Graphic = "/images/toon/Day.png"
			End If
		'E Day Total Low
		Value = powerdayusagelow
		'If Value <> Nothing Then
			DevExists = hs.DeviceExistsAddress("Toon-E Dag Verbruik Laagtarief", False)
				dv = hs.NewDeviceEx("Toon Elektra Verbruik Dag Laagtarief")
				dv.Address(hs) = "Toon-E Dag Verbruik Laagtarief"
				Ref = hs.GetDeviceRef("Toon-E Dag Verbruik Laagtarief")
				GPair = New VGPair
			End If
		'End If
		'E Day Total High
		Value = powerdayusagehigh
			DevExists = hs.DeviceExistsAddress("Toon-E Dag Verbruik Hoogtarief", False)
				dv = hs.NewDeviceEx("Toon Elektra Verbruik Dag Hoogtarief")
				dv.Address(hs) = "Toon-E Dag Verbruik Hoogtarief"
				Ref = hs.GetDeviceRef("Toon-E Dag Verbruik Hoogtarief")
				GPair = New VGPair
			End If
			hs.SetDeviceValueByRef(Ref, Value, True)
		'End If
		'E Day Total High
			DevExists = hs.DeviceExistsAddress("Toon-E Dag Verbruik Totaal", False)
				dv = hs.NewDeviceEx("Toon Elektra Verbruik Dag Totaal")
				dv.Address(hs) = "Toon-E Dag Verbruik Totaal"
				Ref = hs.GetDeviceRef("Toon-E Dag Verbruik Totaal")
				GPair = New VGPair
			End If
		End If
	End If ' errorcheck
	'Info Status device (always updated)
	Value =Now()
	Dim errorstring
	If errorflag = 1 Then
		errorstring = "Status: Error"
	Else
		errorstring = "Status: OK"
	End If
		DevExists = hs.DeviceExistsAddress("Toon-Status", False)
			dv = hs.NewDeviceEx("Toon Info")
			dv.Address(hs) = "Toon-Status"
			Ref = hs.GetDeviceRef("Toon-Status")
			GPair = New VGPair
			GPair.Graphic = "/images/toon/toon.png"
		End If
		hs.SetDeviceString(Ref, errorstring & "<BR>Laatste update: " & Value &  " <BR>Adres: " & Street & " " & Housenumber & "<BR>" & Postalcode & " " & City, True)
		hs.SetDeviceValueByRef(Ref, Errorflag , True)
	End If
	'Finished
		If Debug > 0 Then
			hs.WriteLog("Toon", "Toon Update Completed Successfully")
		End If
	Else
		If Debug > 0 Then
			hs.WriteLog("Toon Error", "Toon Update Completed with Errors")
		End If
	End If 'errorflag End if
End Sub
'Button Press Mode routine
Sub ButtonsMode(modeparams as object)
	Dim DevID As Integer = modeparams(0) 						'Integer - The device reference ID.
	Dim ModeButton As String = modeparams(1)
	hs.WriteLog("Toon", "Mode Change by Button Press to: " & ModeButton)
	If ModeButton = "Comfort" Then
		hs.RunScriptFunc("toon.vb", "Main", "0|0|", True, False)
	End If
	If ModeButton = "Thuis" Then
		hs.RunScriptFunc("toon.vb", "Main", "0|1|", True, False)
	End If
	If ModeButton = "Slapen" Then
		hs.RunScriptFunc("toon.vb", "Main", "0|2|", True, False)
	End If
	If ModeButton = "Weg" Then
		hs.RunScriptFunc("toon.vb", "Main", "0|3|", True, False)
	End If
	hs.RunScriptFunc("toon.vb", "Main", "||", True, False)
End Sub
'Button Press SP routine
Sub ButtonsSP(spparams as object)
	Dim DevID As Integer = spparams(0)
	Dim spButton As String = spparams(1)
	Dim newsp
	Dim oldsp
	oldSP = hs.DeviceValueEx(DevID)
	If spButton = "Plus" Then
		newsp=oldsp+0.5
	End If
	If spButton = "Min" Then
		newsp=oldsp-0.5
	End If
	hs.WriteLog("Toon", "SP Change by Button old sp: " & oldsp)
	hs.WriteLog("Toon", "SP Change by Button Press to: " & newsp)
	hs.RunScriptFunc("toon.vb", "Main", newsp & "||", True, False)
End Sub
Bart
(ON ESXI )on NUC
bartbakels
ewillems wrote:Hi Bart,
Erwin
Erwin,
I am working on my script, especially the deserializing the JSON with the newtonsoft library which works great, however I have an issue with the gasdata. Its not coming in again. Sometimes I get the data and then I don't get any updates for days. Any ideas why? I know do 3 reads with 1 sec interval between them and combining the string.
BTW do you need any help with the plugin and how do you want to set this up?
Thanks
In advance
Bart
(ON ESXI )on NUC
ewillems
Post by ewillems »
Hi Bart,
I'm finally finished my first version of the rewrite. I've not yet worked out the history data.
A few issues I'm working at:
- The Thermostat api (for HSTouch) is not yet working
- Gas data not always in update
Future features:
- Integration Homeseer Energy api
- Implementation of JSON library
- Usage of History data
- More status data (holiday information, next change of mode)
- HS Touch template
It's also not clear to me how to retrieve the data. Not sure why every request results in other data.
Erwin
ToonHS3script1_3.7z
ToonHS3script1_3
(294.93 KiB) Downloaded 959 times
bartbakels
Erwin,
Looking good, simplified the code :D, I was also doing this with my script. The only thing I am missing is are the SP en mode change buttons. so for now I still stay at my script (I have to leave a few days, so do not want to chnage anything to my system in the meanwhile)
Still planning to convert to a Plugin?
Regarding the gasusage. I found out when i open the toonopafstand URL in the browser on my HS3 server, and navigate to the gas usage tab , this is also refreshing in my script. In the Mobile.js, which can be extracted from the toonopafstand url, i see a tabchange function which is guess influences the data that is being send. For the desrialising you can take a look at my roomba thinking cleaner script. This uses the deserialisation from newtonsoft, which simplifies things a lot.
Keep up the good work
regards
Bart
(ON ESXI )on NUC
ewillems
Post by ewillems »
Hi Bart,
The buttons should be created with the devices (find attached a screenshot of my installation). Which version of Homeseer do you have?
Today I discovered another issue with my script: Every time the script ran, the mode was set back to "Comfort". It was a warm welcome this morning :). Hope I can fix this issue soon.
Erwin
Screen Shot 2015-03-05 at 21.46.05.png (200.25 KiB) Viewed 26254 times
Return to “Homeseer Plugins Forum”
