Page 2 of 2
Re: New RFXtrx433E USB transciever
Posted: Thu Jul 31, 2014 10:06 pm
by Dylantje
Thanks...
Posted: Wed Aug 13, 2014 11:19 pm
by Mai Pensato
I also bought three of the Imagintronix soil sensors and a base station (at plantcaretools.com).
My first experiences are not good:
The range is very limited: even outside with no walls and glass in between the distance between the sensor and the base station can be max 15 m1 (the manual states range = 100 m1 in open field..)
Also after a while some of the sensors don't give results any more: both "temperature out" and "wet soil %" give "--" in the display of the base station.
And I cannot get the data of the sensors in my Vera controller via RFXcom. RFXcom cannot find the sensors even though I flashed the latest firmware (v78) enabled protocol Lacrosse and put 1 sensor right next to the RCXcom (within 1 m1 distance).
I read in this topic that more people have bought these sensors. What are your experiences with the range and the strange readings sometimes ("--"). And how can I get the sensors connected to the RFXcom?
Posted: Thu Aug 14, 2014 8:41 am
by Bastiaan
Same bad experience. Even At 10 meter I can hardly get any signal. Planning to extend de USB somehow to bring them closer. ( Garden inside The house). I have extended all antenna's of the sensors too but it hardly made a difference. Pity since it seemed a nice solution. I have dedicated that single rfxcom receiver to this setup so I expect it to have max reception too.
Posted: Thu Aug 14, 2014 10:31 am
by b_weijenberg
You can extend the transmit range of the soil sensor.
Remove the coil antenna inside the sensor and replace it by a 17,3cm wire. Drill a small hole in the top of the enclosure for the antenna wire. Make the sensor water tight again with some silicon sealant.
with this solution I have a distance of about 15 meter with 2 walls in between.
Posted: Thu Aug 14, 2014 10:33 am
by Bastiaan
Bert, I did that already but no luck, 2/3 of the time, no reception.
Posted: Thu Aug 14, 2014 11:09 am
by b_weijenberg
Posted: Thu Aug 14, 2014 11:44 am
by Bastiaan
466Mhz would it work as good on 433?
Worth the try. I see three options:
Better antenna (already using the older dipool?)
Longer antenna cable to bring the rfxcom closer. As far as I understand, this options is not a good one since extending the cable also looses power.
Bringing the USB device closer to the transmitters. Could be costly.
Posted: Thu Aug 14, 2014 12:26 pm
by b_weijenberg
tuned to 446MHz but 434 will also be possible.
Is it an option to connect the RFXtrx on LAN:
for 1 USB device
http://www.conrad.nl/nl/conrad-netwerk- ... 72161.html
for up to 4 USB devices using an additional USB hub:
http://www.conrad.nl/nl/conrad-1-poorts ... f=Homepage
Posted: Thu Aug 14, 2014 12:31 pm
by Bastiaan
Ordered the USB extension. Should also help my VM setup
Thanks Bert. Will report back if a distance of a few meters fixes the issue.
Funny enough channel 1 seems to have better reception compared to the other 2.
Guess the antenna is the only option if you need to reach an outside garden.
Posted: Sat Aug 16, 2014 3:25 pm
by Bastiaan
As promised: Got the USB server today and got it working in 5 minutes. Reception is is good and all sensors report values. Lets see in the next 24 hours but it all looks great.
Posted: Sun Aug 17, 2014 2:00 pm
by nico_gh2
Conrad site shows it's not working using win8 !
Any recommendations for that or using Linux (Raspbian)?
Posted: Sun Aug 17, 2014 3:09 pm
by Bastiaan
It's working here with Win 8.1. I got the version where you can use a hub. Not very clear with model numbers.....
Lost one sensor last night that came back online today. Not even a meter away from the antenna. Only enabled protocol is LAC. Should be optimum, Bert?
Posted: Sun Aug 17, 2014 7:31 pm
by Rene
Do you require a different version when you want to connect using a usb hub? I noticed using a powered hub the rfxtrx433e disconnects after a short time.
Posted: Sun Aug 17, 2014 8:30 pm
by Bastiaan
Rene, it seems so. Conrad has one for single USB use and the one I bought (
conrad.nl/nl/conrad-1-poorts-met-hub-ne ... f=Homepage )
Still got only one USB poort but it mentioned as being able to support a USB hub.
With my next order I will also try the single USB version.
