Toon app: DomoticzBoard
Re: Toon app: DomoticzBoard
can't you reconfigure Domoticz and make them 'Type' = 'Light' and 'SwitchType' = 'Dimmer'?
Then they will show up I think
Xavier
Post by Xavier »
In Domoticz the Shelly Dimmer is auto discovered, I'm not able to change the type into Light:
Domoticz switch shelly dimmer (Aangepast).png (37.87 KiB) Viewed 12548 times
can you send me a PM with the block for this dimmer from your json file (http://yourdomoticz_ip/json.htm?type=devices&filter=all&used=true&order=Name)?
Xavier
Post by Xavier »
PM sent
PM returned with a possible solution (for testing) ;-). Let me know if this worked, I can include it in a next release.
Xavier
Post by Xavier »
Yes it Works great now, thanks for this quick solution!
version 1.1.9 is available in the ToonStore.
Changelog:
- support added for Shelly dimmers
Kind regardz,
Xavier
Post by Xavier »
Thanks again Toonz, great work!
Havym
Post by Havym »
Thank you for the update! It works :D
Xavier
Post by Xavier »
Toonz,
Can the same be done for rollershutter in the app?
Rollershutter is done on Shelly 2.5.
Within Domoticz I use blinds percentage to open or close blinds for example on 50%...
Domoticz switch shelly 25.png (10.21 KiB) Viewed 12394 times
Xavier wrote:Toonz,
can you send me a PM with the json block for this shutter?
Xavier
Post by Xavier »
Toonz wrote:
Xavier wrote:Toonz,
Done
Xavier wrote:Toonz,
can you replace the file DomoticzboardApp.qml with this one and see if that works (keep a copy of the original just in case):
DomoticzboardApp.zip
(2.85 KiB) Downloaded 405 times
Xavier
Post by Xavier »
Tested and works, thank you Toonz.
Just wondering for 1 thing.
Now I can adjust blinds in steps of 10% with "+" or "-".
But is it possible to manually enter a percentage instead of starting from 0 to 60% to close in 6 steps and tapping the "+"?
An other thing is that there is an On and Off slide button. But when pressing this slide button to "active/on" the button becomes green and blinds close completely.
When again pressing the slide the blinds do not open.
Can this be fixed?
entering the percentage manually is doable.
The on/off thing is a bit more challenging. Need to know more about the control of the blinds.
It now follows the logic of a standard light dimmer.
When you change the percentage when the blinds are closed, will they open? Normally a dimmer switches on automatically in that case.
All a bit difficult to judge properly as I don't have any dimmer myself :-(
