Toon App: solarPanel ---> solar data without hardware
oepi-loepi
Re: Toon App: solarPanel ---> solar data without hardware
Post by oepi-loepi »
Maybe you can share your credentials by sending me an email? Then i can have a look.
oepi-loepi
You could share your credentials by email to me. Then i can have a look.
You could alsso try in a browser by fillimg the fields:
https://api.enphaseenergy.com/api/v2/systems/" + siteid+ "/summary?key=" + apiKey + "&user_id=" + userName
Xavier
Post by Xavier »
Thanks oepi-loepi,
So I used this in browser:
https://api.enphaseenergy.com/api/v2/systems/siteID/summary?key=APIkey&user_id=userID
(from the API setup under "mijn account" in "mijn toegangscontrole on https://enlighten.enphaseenergy.com/)
Is this correct?
If so I get:
{"reason":"401","message":["Not authorized to access requested resource.","User not found."]}
So I doubt about the UserID (26 characters long??)
Oh and btw I use APIv4 not v2.... meaning I created an account on https://developer-v4.enphase.com/
Using this in Postman with I get, I get:
https://api.enphaseenergy.com/api/v4/sy ... _id=UserID
with output in json:
{"system_id":XXXXX,"
current_power":210,"
energy_lifetime":20667,"
energy_today":336,
"last_interval_end_at":1675758000,
"last_report_at":1675757985,
"modules":14,
"operational_at":1675333431,
"size_w":5120,
"source":"microinverters",
"status":"normal",
"summary_date":"2023-02-07"}
With status 200 "OK"
Xavier
Post by Xavier »
Still no luck, used different configs/setups.
I think there is an issue with API v4 code in this app....
On the website of Enphase I read:
Announcement: Effective April 1, 2023, Enphase API will only support TLS 1.2 and will not accept any applications on older TLS versions
Announcement: The end of life for Enphase API v2 has been extended from August 15, 2022 to March 31, 2023. For more details, visit About API v4
Following manuals there is a lot changed since v2.....
@Oepi-loepie, just checking out your github https://github.com/ToonSoftwareCollecti ... plugin.txt
the code:
/////////             <version>1.0.3</version>
/////////                     ENPHASE2                     /////////////
/////////  Plugin to extract Enphase Solar data for Toon ///////////////
/////////                   By Oepi-Loepi                  ///////////////
	function getSolarData(passWord,userName,apiKey,siteid,urlString,totalValue){
		if (debugOutput) console.log("*********SolarPanel Start getEnphaseData")
		var http = new XMLHttpRequest();
		var url = "https://api.enphaseenergy.com/api/v2/systems/" + siteid+ "/summary?key=" + apiKey + "&user_id=" + userName
		http.open("GET", url, true)
		http.onreadystatechange = function() {
			if (http.readyState == XMLHttpRequest.DONE) {
				if (http.status === 200 || http.status === 300  || http.status === 302) {
					try {
						var JsonString = http.responseText
						var JsonObject= JSON.parse(JsonString)
						var today2
						currentPower = parseInt(JsonObject.current_power)
                        today2 = parseInt(JsonObject.energy_today)
                        totalValue = parseInt(JsonObject.energy_lifetime)
						parseReturnData(currentPower,totalValue,today2,0,0,0,0,http.status,"succes")
					catch (e){
						currentPower = 0
						parseReturnData(0,totalValue,0,0,0,0,0, http.status,"error")
				} else {
					if (debugOutput) console.log("*********SolarPanel error: " + http.status)
		http.send();
This should be for APIv4:
		var url = "https://api.enphaseenergy.com/api/v4/systems/" + siteid+ "/summary?key=" + apiKey + "&user_id=" + userName
					try {
						var today2
					catch (e){
						currentPower = 0
				} else {
		http.send();
API v2 can't be registered anymore according the site https://developer.enphase.com/signup, I get this error:
"Signup disabled"
On Github I did a commit.....
BenToon
Post by BenToon »
I have 2 Solis inverter. In the app i must select "user" and "password".
Result is only the first inverter-system on both.
How i can select the right inverter or plant-system?
oepi-loepi
looks like Github hase troubles now.. Is changing V2 into V4 the only thing you did and then it is working?
Xavier
Post by Xavier »
Yes, I tested with postman, when using v2 then I get the autorization error, when using v4 I get the output as posted e few posts back with a 200 status code.
ohhh btw. I think the userguide has to be updated on page 5 of this thread.....
BenToon
Re: Toon App: solarPanel ---> solar data without hardware LIVE
Post by BenToon »
oepi-loepi wrote: Tue Jan 26, 2021 7:12 pm
Alxwin wrote:Goedemorgen,
Super deze app! Ben gelijk gaan testen met mijn twee Omnik omvormers. Ik krijg netjes data te zien, echter het lijkt erop alsof hij maar van 1 omvormer de data toont. Ik heb echter twee Omnik omvormers, die dus op hetzelfde Omnik account zitten. Heb het palletje in de instellingen op 2 gezet en bij beide dezelfde logingegevens gezet voor de Omnikportal. Wat doe ik verkeerd?
Groeten, Arjen
Ik haal voor de Omnik alleen de eerste omvormer binnen, niet de tweede. Als je een speciale plugin wilt (omnik-dubbel) dan kan ik die wel toevoegen maar dan moet je mij even helpen door het sturen van je accountnaam en (tijdelijk aangepaste) wachtwoord per pm om te testen
Dit geldt voor mij hetzelfde, alleen dan voor "solis" inverters. Zie ook mijn vorige vraag.
Micha_123
Post by Micha_123 »
hi, i have today an problem
for now no sun is produced, toon says 0W from solar (thats right) but
{"result":"ok","solar": {"current":0, "total":24108678, "today":1766, "production":894, "usage_net":704, "usage_own":-190}}
why it is saying that 894W are going to the net ?
ok found it
in /mnt/data/tsc/appData/solarPanel_fiveminuteValuesProd.txt
deleted the values in that file (the file self i leave) now it is showing the right values. strange i have it the first time like this
georon
Post by georon »
The growatt servers keep blocking user agents.
My Toon Solar keeps locking my account and my Toon stops reporting solar information.
The homeassistant growatt maintainer solved this by implementing dynamic user agents at startup, instead of hard-coded ShinePhone user agent
More info can be found at:
- https://community.home-assistant.io/t/g ... xing/48385
- https://community.home-assistant.io/t/a ... /60430/271
oepi-loepi
BenToon wrote: Wed Feb 08, 2023 9:50 pm
Groeten, Arjen
Ook hier hetzelfde antwoord. Ik kan en ga niet helpen als ik geen inloggegevns kan gebruiken om het programma aan te passen. Ik wil best ernaar kijken maar stuur dan even je inloggegevens per mail of per pm
oepi-loepi
Xavier wrote: Wed Feb 08, 2023 8:25 pm Yes, I tested with postman, when using v2 then I get the autorization error, when using v4 I get the output as posted e few posts back with a 200 status code.
[/quote
Ik kan niet helpen als ik geen inloggegevns kan gebruiken om het programma aan te passen. Ik wil best ernaar kijken maar stuur dan even je inloggegevens per mail of per pm
Laat svp ook even wweten wat precies je oplossing was.
De handleiding heb ik niet geschreven. Ik heb totaal geen ervaring met enPhase daarin. Kun jij wellicht de handleiding herschrijven en hier posten? Dan maak ik de verwijzing naar die van jou.
oepi-loepi
In het algemeen: ik krijg veel vragen per mail, pm, marktplaatsaccount, via de toonWater pagina en ook via andere forums of een omvormer in de lijst zit en of ik even een omvormer wil toevoegen. Mijn antwoord is altijd gelijk… ik kan alleen iets maken als ik ook inloggegevens heb. Als ik daar dan om vraag dan blijft het stil… jammer.
Gelukkig zijn er ook mensen die wel eillen delen en zo de community steunen.
oepi-loepi
georon wrote: Sun Feb 12, 2023 9:22 pm The growatt servers keep blocking user agents.
Ik heb de twee stukken doorgelezen maar misschien lees ik er overheen. Kun je aangeven hoe hij dat heeft gedaan met die dynamic user-agent?
Probeer ook niet te vaak de data op te halen. Daarmee blokt de server de api toegang, tenminste daar lijkt het op.
Xavier
Post by Xavier »
oepi-loepi wrote: Sun Feb 12, 2023 10:33 pm In het algemeen: ik krijg veel vragen per mail, pm, marktplaatsaccount, via de toonWater pagina en ook via andere forums of een omvormer in de lijst zit en of ik even een omvormer wil toevoegen. Mijn antwoord is altijd gelijk… ik kan alleen iets maken als ik ook inloggegevens heb. Als ik daar dan om vraag dan blijft het stil… jammer.
PM sent.
