I will send you a pm.Edgar wrote:I have put an USB (male-female) extension cable and that works. The only problem I still have is the right positioning of the sensor
Toon App: Water
Re: Toon App: Water
Re: Toon App: Water
New version 1.2.0:
different way to send data to domoticz, better webportal with info screen, fixe for back button on update screen, differtent AutoConnectAp, Logo and many other small fixes.
let op het betreft een freeware uitgave, software is niet bestemd voor verkoop
free release can be found here:
github.com/oepi-loepi/water_ESP_part/re ... 1_mini.bin
Re: Toon App: Water
can this update be done via the update button?oepi-loepi wrote:New version 1.2.0:
https://github.com/oepi-loepi/water_ESP ... 1_mini.bin
in the online environment
Re: Toon App: Water
Ik zie de update nog niet terug in de Toonstore. Kan dat even duren?
I don't see the update in the Toonstore. Does this take some days?
Verstuurd vanaf mijn SM-G950F met Tapatalk
Re: Toon App: Water
Probably is the wemos firmware not the Toon app because that doesn't send it to domoticzBruce the boss wrote:Ik zie de update nog niet terug in de Toonstore. Kan dat even duren?
Re: Toon App: Water
Indeed this is the wemos firmware. To update:
Use the online update function (download the .bin and use the update button on the wemos webpage)
OR
Reflash the wemos using usb cable.
OR
Re: Toon App: Water
After updating to the new Wemos firmware, the network settings have disappeared.
Wemos now has a wrong IP address (192.168.10.137) whereas my LAN has 192.168.2.X.
What is the quickest way to re-enter the right network settings? I cannot access Wemos via the network...
I flashed the unit again via cable connection, but no AutoConnectAP.
After flashing first with the blank_4MB file and then the ToonWater it works.
I cannot remember I lost the network settings during the previous update...
Re: Toon App: Water
Problem solved, was a defect cable…oepi-loepi wrote:Ok, i will check that.Tebogo wrote:By the way, found a "bug" in the portal, version 1.1.11
When you go to "update" and than choose "terug" you get the following: "http://10.187.1.121/%22//%22"
Re: Toon App: Water
Let me do a quick check...... i tried a couple of times to update the firmware but they were all without problems. I even tried updating from 1.1.10 to 1.2.0 . I could not get to the same errors. Anyone else expriencing update errors? Please let me know the old firmware version.Arnout2000 wrote:After updating to the new Wemos firmware, the network settings have disappeared.
Re: Toon App: Water
Trying to update from 1.1.11 to 1.2.0 via de update function.oepi-loepi wrote:Indeed this is the wemos firmware. To update:
OR
Selected the downloaded bin, ToonWater2_version_1.2.0.ino.d1_mini.bin, but the update button does not response.
I'll try tomorrow to do a refresh...
Re: Toon App: Water
Please give the upload some time. It wil take ab. 20 seconds for the upload.Tebogo wrote:Trying to update from 1.1.11 to 1.2.0 via de update function.oepi-loepi wrote:Indeed this is the wemos firmware. To update:
OR
Re: Toon App: Water
Same here. Update via the "update botton" does not work. Tried both Chrome and Edge browser.oepi-loepi wrote:Please give the upload some time. It wil take ab. 20 seconds for the upload.Tebogo wrote:Trying to update from 1.1.11 to 1.2.0 via de update function.oepi-loepi wrote:Indeed this is the wemos firmware. To update:
OR
Re: Toon App: Water
I had the same, but I haven't checked the IP address and flashed it new, the 4 MB blank was necessary. I came from version 1.1.10Arnout2000 wrote:After updating to the new Wemos firmware, the network settings have disappeared.
Re: Toon App: Water
I understand now. Some new parameters are stored in flash memory. The cannot be found in the old firmware. Simply because they are not there. If you cannot reach the wemos with usb cable do not update. Also for updating you first have to flash the empty 4mb to fully clear the flash memory.
Re: Toon App: Water
Thanks. That explains my experience.oepi-loepi wrote:I understand now. Some new parameters are stored in flash memory. The cannot be found in the old firmware. Simply because they are not there. If you cannot reach the wemos with usb cable do not update. Also for updating you first have to flash the empty 4mb to fully clear the flash memory.
Keep up the good work!
