Software: modifications and extensions Toon
Ierlandfan
Post by Ierlandfan »
@MarcelR, what do you mean exactly because this is my output of opkg (On Toon)
eneco-XXX-XXX:~# opkg list |grep mosq
libmosquitto - 1.4.9-r0 - Mosquitto is an open source (BSD licensed) message broker that implements the MQ Telemetry Transport protocol version 3.1. MQTT provides a lightweight method of carrying out messaging using a publish/subscribe model.
libmosquittopp1 - 1.4.9-r0 - Mosquitto is an open source (BSD licensed) message broker that implements the MQ Telemetry Transport protocol version 3.1. MQTT provides a lightweight method of carrying out messaging using a publish/subscribe model.
mosquitto-clients - 1.4.9-r0 - Mosquitto is an open source (BSD licensed) message broker that implements the MQ Telemetry Transport protocol version 3.1. MQTT provides a lightweight method of carrying out messaging using a publish/subscribe model.
eneco-XXX-XXX:~# opkg list-installed |grep mosq
Hmmm ... doesn't show up on mine. What's your FW version?
Ierlandfan
eneco-XXX-XXX:/etc# opkg update
Downloading http://feed.hae.int/feeds/qb2/ene/4.4.21/Packages.gz.
Inflating http://feed.hae.int/feeds/qb2/ene/4.4.21/Packages.gz.
Updated list of available packages in /var/lib/opkg/base.
Downloading http://feed.hae.int/feeds/qb2/ene/4.4.21/Packages.sig.
Signature check passed.
Downloading http://feed.hae.int/feeds/qb2/oe/2.6.36 ... ackages.gz.
Inflating http://feed.hae.int/feeds/qb2/oe/2.6.36 ... ackages.gz.
Updated list of available packages in /var/lib/opkg/oebase.
Downloading http://feed.hae.int/feeds/qb2/oe/2.6.36 ... ckages.sig.
Updated list of available packages in /var/lib/opkg/oekern.
OK, will give it a shot.
And then what? Any idea how to crank it up?
makkie2002
Post by makkie2002 »
How do I get the original repositories active again so that I can install new packages?
Now the opkg repositories are linked to Toonstore.
makkie2002
opkg remove toonstore
or edit /etc/hosts manually to reflect the contents of /etc/hosts.toonstore_backup
makkie2002
marcelr wrote:opkg remove toonstore
Do I also have to enable the vpn ?
Post by TheHogNL »
Yes. Updating from the original source only works from over the VPN
makkie2002
Changed the hosts file as suggested.
Also enabled ovpn again.
But doing "opkg update" still only lists the domoticaforum repository, not the Quby repository.
I can do a "wget http://feed.hae.int/feeds/qb2/ene/4.4.21/Packages.gz" and look which packages are available, so at least the link is working.
The updater by Quby regenerates the package cache as well. Just running opkg upgrade is not enough for that.
makkie2002
makkie2002 wrote:
Can you make a settings part in the app so I can edit the IP/Port/image url via the Toon itself? Like in the Sonos app
I will have to study some other apps to get this functionality in ... but I will manage :o
Study time is over ... I managed to make a selfsustained app!
As default webcam image there is a livefeed from some village in Austria, but it can be replaced by anything else as long as it is an image (not a stream).
webcam-0.0.5.zip
Webcam app for Toon
(4.92 KiB) Downloaded 574 times
phoenixb
Post by phoenixb »
@makkie2002, nice script! Will it also possible to use the qtwebkit to load simple html pages?
__________________
makkie2002
phoenixb wrote:@makkie2002, nice script! Will it also possible to use the qtwebkit to load simple html pages?
Thanks ... no html pages are retrieved ... the script only downloads plain jpg files every 4 seconds.
No, Toon has no browser functionality. You can retrieve html pages via http (no https) and get the html source as plain text. There is no html rendering.
