Toon app: DomoticzBoard
Xavier
Re: Toon app: DomoticzBoard
Post by Xavier »
Sure,
Here's the code:
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"CustomImage" : 0,
			"Data" : "Open",
			"Description" : "",
			"DimmerType" : "none",
			"Favorite" : 1,
			"HardwareDisabled" : false,
			"HardwareID" : 14,
			"HardwareName" : "MQTT Auto discovery",
			"HardwareType" : "MQTT Auto Discovery Client Gateway with LAN interface",
			"HardwareTypeVal" : 125,
			"HaveDimmer" : true,
			"HaveGroupCmd" : true,
			"HaveTimeout" : false,
			"ID" : "shellyswitch25-XXXXXXX-roller-0",
			"Image" : "blinds",
			"IsSubDevice" : false,
			"LastUpdate" : "2023-12-11 09:32:53",
			"Level" : 100,
			"LevelInt" : 100,
			"MaxDimLevel" : 100,
			"Name" : "Rolluik keuken",
			"Notifications" : "false",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Protected" : false,
			"ReversePosition" : false,
			"ReverseState" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"Status" : "Open",
			"StrParam1" : "",
			"StrParam2" : "",
			"SubType" : "Switch",
			"SwitchType" : "Blinds + Stop",
			"SwitchTypeVal" : 21,
			"Timers" : "true",
			"Type" : "Light/Switch",
			"TypeImg" : "blinds",
			"Unit" : 1,
			"Used" : 1,
			"UsedByCamera" : false,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "621"
got it, will update the app accordingly
Xavier
Post by Xavier »
Great, thanks, please notify me when done, then I can test ;)
hi,
can you test the attached fix please?
Unzip the attachment and put the file DomoticzboardApp.qml file in the folder /qmf/qml/apps/domoticzboard on Toon and restart the gui.
If it works ok I will release it in the ToonStore as well.
Kind regards,
DomoticzboardApp.zip
(2.98 KiB) Downloaded 200 times
Xavier
Post by Xavier »
Thanks Toonz!
Just tested, it works. Blinds are now visible again in DomoticzBoard.
Great! Thanks for the feedback.
Xavier
Post by Xavier »
Hi Toonz,
My wife noticed that the blinds are visible again, the issue that I checked, but she noticed this weekend that the blinds are not responsive.
Pressing the button to open or close doesn't work, the blinds do not react.
Any idea about this issue why they do not react?
Probably a change in the API, will check the documentation.
EDIT: indeed a change in the API : "Open-Close Blinds (changed behavior from stable 2022.2)........"
hi,
Unzip the attachment and put the file DomoticzboardScreen.qml file in the folder /qmf/qml/apps/domoticzboard on Toon and restart the gui.
P.S. This is exactly why I stopped using Domoticz in the past, most upgrades created issues :D
Kind regards,
DomoticzboardScreen.zip
(3.23 KiB) Downloaded 197 times
Xavier
Post by Xavier »
Thanks again for your work.
Using the number field (percentage) works but using the slider/switch doesn't work.
Switch on should be 0%
Switch off should be 100%
try this one.... on/off should work now
(3.28 KiB) Downloaded 170 times
Xavier
Post by Xavier »
just tested but no, still not working.
Ofcourse rebooted Toonv2 after new qml file
Using the numbers/percentage works, on/off button has no reaction.
weird, let me send you a version for debugging this later......
Maybe we can connect via Teamviewer so I can see whats happening at your end.
If that's ok with you, drop me a PM
Xavier
Post by Xavier »
I sent you a PM.
Xavier
Post by Xavier »
@Toonz: Any time to have a look at this issue?
