Toon App: solarPanel ---> solar data without hardware
Xavier
Re: Toon App: solarPanel ---> solar data without hardware
Post by Xavier »
michel30 wrote: Mon Aug 14, 2023 3:21 pm
Xavier wrote: Wed Apr 19, 2023 1:24 pm Enphase zonnepanelen systeem bestaat uit een aantal onderdelen:
1. Zonnepanelen uiteraard
2. Micro omvormers die onder de zonnepanelen zitten
3. Q-relais (1fase of 3-fase)
4. Enphase Envoy gateway (2 modellen beschikbaar: Enphase Envoy S of Envoy Metered)
In de Enlighten app van Envoy kun je naar Menu gaan, dan naar systeem en dan vervolgens naar apparaten.
Als het goed is zie je groepen apparaten staan namelijk: Gateway en Microinverters.
Kies voor Gateway, je ziet nu welke type gateway je hebt (metered of de S) en daar staat ook de firmware versie (de nieuwste op dit moment is de D7.0.88 firmware).
In het geval van de D7 firmware kies je in de Solarpanel app in de toon voor Enphase-T.
Hi Xavier,
Question does your Enpahse still work with your Toon?
I have 1fase and my gateway model is Enphase Envoy S with firmware D7.6.175
Hi Michel,
I have 2 toons V2 both are still displaying the correct info of my solar panels
I use Enphase T as inverter
Username: e-mail address used to register at Enlighten
Password: used as regsitered at Enlighten
URL: Ip-address of the Envoy
I own a Envoy Metered, so can't tell if behaviour is the same on a Envoy-S.
My Envoy-metered has firmware D7.6.175
What issue do you encounter?
EDIT:
There are 2 ways to get info from solar, I chose for getting data directly from the Envoy, which works for me great!
An other possibility is to get the data from Domoticz/HA, but in that case Domoticz/HA has to be capable to get the correct information/connection.
In Domoticz there is the hardware option "Enphase Envoy with LAN (http) interface" which I never got to work......
So I use the version of Enphase Envoy plugin from https://github.com/H4nsie/EnphaseEnvoy
2nd EDIT:
Not sure but I remembered somehting about the API.
There is a need to setup an API in https://developer-v4.enphase.com/, you need to create an application and give access.
@Oepi-Loepi: not entirely sure how you made the script, we searched for different sollutions and not sure if API is needed or that you made the script too look directly to the Envoy.....
oepi-loepi
Post by oepi-loepi »
The solarPanel script will grant api acces based on the login credientials. So the solarPanel app will do that by itself.
oepi-loepi
@michel30
If you like me to investigate your problem, you need me to grant acces to your envoy (portforward) and to your enphase credentials.
oepi-loepi
Micha_123 wrote: Wed Aug 16, 2023 10:49 am
oepi-loepi wrote: Sun Jul 30, 2023 11:10 am I have made a second plugin (Domoticz (2023.2>)). Can you check if this works?
now im @home, and yes it is working.
but the toonwater app does the same in log. :D
but solarpanel with the setting domoticz 2023.2 is working fine.
Aha, duidelijk. Ik zal het aanpassen.
pdidi
Post by pdidi »
Zou het mogelijk zijn een tegel aan te maken (of een bestaande Tegel uit te breiden) die op basis van de P1 data de Netto teruglevering laat zien? Dus de Huidige levering aan het net minus de Huidige afname van het net. Voor 3 fase gebruikers kunnen beide namelijk tegelijk het geval zijn. Met name interessant nu dat VanDeBron op basis van de Netto teruglevering gaat bepalen hoeveel terugleveringskosten moeten worden betaald (https://vandebron.nl/blog/vaste-terugleveringskosten)
fgerrits
Post by fgerrits »
Hoi,
I have 2 inverters in the solarapp, thirst = growatt, second = huawei.
When i open the configuration in de app i see both inverters, but the app is only counting the solardata from the growatt inverter, not from the huawei.
On the huawei website i made a separate login for the toon solarapp, but must i also use an api in the app to get it working ?
Or is there a log where i can find what is going on ?
Vriesfde
Post by Vriesfde »
App heeft maanden lang perfekt gewerkt, sinds twee weken zie ik regelmatig geen data meer ( zonnetje schijnt)
Eerste troubleshoot sessie waren er issues om via browser https naar growattnte gaan, http ging wel.
Op Toon een keer app verwijderd en opnieuw geregistreerd en toen werkte het weer een aantal dagen.
Nu, ook na verwijderen etc. Krijg ik het niet meer aan de praat.
Any tips?
Vriesfde
Post by Vriesfde »
Wordt voor de Growatt integratie deze url gebruikt om in te loggen: https://server-api.growatt.com/ ?
In HomeAssistant melden gebruikers ook dit probleem, integratie in laten loggen op server.growatt.com werkt wel.
https://github.com/home-assistant/core/issues/100874
oepi-loepi
Helaas werkt die andere server ook niet meer momenteel. Vorige keer was het idd die andere server die ik gevonden had (en ook daarmee domoticz gebruikers kon helpen). Helaas lopen we nu met de servers tegen dezelfde problemen aan.
Ik heb gekeken naar het verkeer van de app en die blocked op het moment dat ik een eigen proxy opzet. Ook het opzetten van dezelfde requests via curl of via postman geven geen resultaat. Helaas dus nog even geen snelle oplossing.
oepi-loepi
Ik heb een oplossing.. Vriesfde, check je pm
arnoakavdb
Post by arnoakavdb »
Hi oepi-oepi,
Ik heb de apps lang geleden installeer maar nu ik krijg niet meer data van productie van mijn sma inverter.alle de parameters zijn goed.de info van de teruglevering zijn ok maar nieks op productie van de dag.kunt jij help mij?
oepi-loepi
What is the output if you type this url in a browser:
http://xxx.xxx.xxx.xxx/dyn/login.json
Where xxx.xxx.xxx.xxx is the ipadress of your sma inverter?
arnoakavdb
I received this :
{"err":404}
Maybe it's because I'm also connected to my sma with home assistant permanently to manage my consumption and it's only possible to connect 1 user?
FreakNL
Post by FreakNL »
I've got a Goodwe 3000-XS since yesterday.
SolarPanel is working if I use the GoodWe plugin (through Sems Portal).. But this has a delay of 5-10 minutes.
In Domoticz, I already have the real-time data (pulled locally from the 3000-XS).. So, let's use Domoticz then in Solarpanel.. Put in my IP and IDX.. Not working.. No data at all.. What kind of domoticz sensor is expected by solarPanel?
Even better, can we have an extra Goodwe variant where the data is pulled locally? Shouldnt be that hard, right?
oepi-loepi
That local plugin is better indeed. Could you send met the local url’s and outputs from that urls? You can send by pm.
Voor gebruik van domoticz kun je het beste gebruik maken van de optie local networks op de installingen pagina. Daar vul je jouw ip reeks in. Alles op dat lokale netwerk wordt dan vertoruwd.
De app solarPanel haalt elke 5 minuten data op. Dat is omdat veel portals meer dan 12 keer per uur niet toestaan. Daarnaast is de database van toon ook gebaseerd op 5 minuten data. Als je echt live wilt zien dan kun je ook gebruikmaken van een extra kwh meter in de groepenkast. Die koppel je niet met de app solarPanel (verwijder die!) maar met de originele zon-op-toon app.
