Toon App: Water
Tebogo
Re: Toon App: Water
Post by Tebogo »
I have the new firmware working, but:
When I use water it works like it should do.
But slowly the count goes up without water use and no pulses from the sensor.
How can this be explained.
I use a Wemos, sensor connected on D1, version 1.2.0.
Tried 500 and 2000 for demping. No difference…
Thanks!
oepi-loepi
Re: Toon App: Water
Post by oepi-loepi »
Could you please try pin D2? Also check your wiring and sensor placement. The pulse is triggered falling edge. So it first must be high and get low. Do you use the 5v version of the sensor? Did it work better on the previous version?
I changed the version to 1.3.3 github.com/oepi-loepi/water_ESP_part/re ... 1_mini.bin
it should solve the update issue
mogwai
Re: Toon App: Water
Post by mogwai »
Still no luck with updating via the GUI, also not with the new 1.3.2 version. After selecting the file and pressing "Update Firmware" nothing happens.
oepi-loepi
Re: Toon App: Water
mogwai wrote:Still no luck with updating via the GUI, also not with the new 1.3.2 version. After selecting the file and pressing "Update Firmware" nothing happens.
You are using the wemos version? What version are you on now? It takes ab. 20 seconds to upload before the succes message will show.
mogwai
Re: Toon App: Water
Post by mogwai »
I'm on version 1.1.11. Even after waiting for 1 minute nothing happens....
oepi-loepi
Re: Toon App: Water
Strange, maybe firewall related or something. In that case you can use the usb option.
Edgar
Re: Toon App: Water
Post by Edgar »
Update works without problems by using the update button. Tested in Safari and Firefox, both on Mac.
Tebogo
Re: Toon App: Water
Post by Tebogo »
oepi-loepi wrote:Could you please try pin D2? Also check your wiring and sensor placement. The pulse is triggered falling edge. So it first must be high and get low. Do you use the 5v version of the sensor? Did it work better on the previous version?
Solved the automatic upgoing waterquantity, probably again a faulty connection. Now it works fine, only when using water.
But now I need to calibrate. It’s measuring more water than the watermeter is saying.
Should I go from 500 to 2000 in steps of 100? Thanks for you help
Tebogo
Re: Toon App: Water
Post by Tebogo »
Update from 1.2.0. to 1.3.3. work perfectly!
Arnout2000
Re: Toon App: Water
Post by Arnout2000 »
Successfully updated to 1.3.3 using Safari on iPad.
Is it correct that since the last versions the blue led on Wemos is switched off?
oepi-loepi
Re: Toon App: Water
You should take a good look at the cable and at the sensor position. Also, did you sand a bit of the tip form the sensor? It looks like your sensor is not stabel. Each turn of the metal plate of the meter will let the led of the sensor go on. When it is switched off again, the pulse is counted for. If you see too many pulses, position the sensor more "out-center", increase the damping to 1000, take a bit of the blue tip from the sensor or fix the sensor better
oepi-loepi
Re: Toon App: Water
Arnout2000 wrote:Successfully updated to 1.3.3 using Safari op iPad.
Yes, the led is switches off but is blinking when it is in AutoCaoonetAP mode and it flashes shortly when a pulse from the sensor is received. (same as the module do which i sell at Marktplaats).
Edgar
Re: Toon App: Water
Post by Edgar »
Arnout2000 wrote: Is it correct that since the last versions the blue led on Wemos is switched off?
It only blinks when you use water after the red led on the sensor noticed you have used another liter of water :mrgreen:
Arnout2000
Re: Toon App: Water
In the older version it was constantly On showing that it was connected to Wi-Fi. (Was my impression)
oepi-loepi
Re: Toon App: Water
Arnout2000 wrote:In the older version it was constantly On showing that it was connected to Wi-Fi. (Was my impression)
It is normally on when powered on but i now made use of it to show some status (wifi status, blinking when no network connection and pulse status, short blink when a puls has been received)
