Page 19 of 22
Re: Toon app: Buienradar
Posted: Tue Sep 08, 2020 6:56 pm
by edwinth
Hello Toonz,
It was me. I thought that clicking on the icon gave me the weather but it's the radar.(feature request maybe ?)
The screen for adding the widgets made me confused because the text overlaps.
Keep up the good work!
Thanks,
Edwin
Posted: Wed Sep 23, 2020 11:53 pm
by Toonz
A new version (8.5.8) is available in the ToonStore now. The input file from buienradar has a non-standard format sometimes which has been reported to but not fixed by buienradar.
This version handles it properly now.
Changelog:
- fix for the 'regenverwachting' tile, handling bad input correctly now, thanks glsf91
Posted: Thu Sep 24, 2020 10:05 am
by whizzz63
Thanks for the update. Would you please be so kind to look at the map in the Buienradar app. (Actuele Temperatuur, Motregenradar, Pollenradar enz). Zuid_Limburg isn't visible. Could you fix this?
Posted: Thu Sep 24, 2020 1:44 pm
by Toonz
whizzz63 wrote:Thanks for the update. Would you please be so kind to look at the map in the Buienradar app. (Actuele Temperatuur, Motregenradar, Pollenradar enz). Zuid_Limburg isn't visible. Could you fix this?
can be fixed, probably caused by a new size of the maps. Will have a look.
Posted: Fri Sep 25, 2020 9:00 am
by Toonz
Hi all, a next maintenance release is available in the ToonStore:
Changelog version 8.5.9
- resized the radarimages on a Toon 2 so that the most southern part of Limburg is visible as well :-)
- renamed label of the Regenverwachting tile so it doesn't overlap anymore
- fixed +3h radarimages on a Toon 2 (nobody noticed it didn't work anymore?)
Posted: Fri Sep 25, 2020 9:26 am
by whizzz63
Thanks a lot for the update! It looks great and the 3 hours forecast works fine!
Posted: Wed Dec 23, 2020 1:36 pm
by Toonz
version 8.5.11 is available in the ToonStore with a small cosmetic change.
Changelog:
- on the Rain prediction tile, the Y-axis label font size has been increased
Posted: Sun Feb 14, 2021 2:00 pm
by Toonz
version 8.5.12 is available in the ToonStore.
Changelog:
- functionality to enter lon/lat coordinates via scanning a QR code has been removed
No need to update for existing users but be aware that that piece of functionality will not work anymore in the future
Tiles missing
Posted: Thu Feb 25, 2021 9:01 pm
by markismus
The tiles for buienrader are missing.
Installed version TSC 5.39.7, update-rooted.sh 4.42, buienradar 8.5.12, toonstore 5.1.0.
I ran `sh update-rooted.sh -f`, `reboot` , `shutdown -r now`, but to no avail.
I switched native weather to on, since the weather info is missing from the clock tile*, too. No result, though.
______________________________
* Wasn't it at the clock tile? Or was it a separate tile. If so, that one is missing, too.
Posted: Fri Feb 26, 2021 10:09 pm
by Blacky's Boss
I think Buienradar is broken?
Last update on my Toon was 15:40, my dads at 14:20 and a neighbours one at 14:50. Time is now 20:45.
Posted: Fri Feb 26, 2021 10:12 pm
by Toonz
nothing wrong with the app, just an issue with the Buienradar data feed. Usually they fix it within a day but not sure in the weekend.... patience.....
website gives an error that the url is invalid, let me check if something has changed
Posted: Fri Feb 26, 2021 10:23 pm
by Toonz
the URL used in the app (https://xml.buienradar.nl) is discontinued and should be replaced by https://data.buienradar.nl/1.0/feed/xml.
New version is ready and will be in the ToonStore very very soon :-)
Posted: Fri Feb 26, 2021 10:24 pm
by Blacky's Boss
Thanx :D Supersnelle service :mrgreen:
Posted: Fri Feb 26, 2021 10:44 pm
by Toonz
version 8.5.13 is ready to be published in the ToonStore fixing the buienradar data feed URL.
Will be visible when the change has been approved.
Toonz.
Posted: Sat Feb 27, 2021 10:24 am
by Toonz
Buienradar 8.5.13 is now available in the ToonStore.
No new functionality, just fixing the source URL.
