What motion sensors?
DMB
Post by DMB »
Wifi,
You can check the version of the receiver with the RFXCOM receiver test programme.
Stop homeseer, connect to your serial port with the test programme and push the "Get receiver version" button.
RFXCOM updated some weeks ago my receiver, I think because it was necessary for the new KAKU modules.
My version is
DMB
[Updated: Chak and Wifi, you're both typing faster than I do.]
@DMB you have the latest version...we don't...lol
DMB
Post by DMB »
Chak,
I had a meeting some weeks ago with Pieter and Bert.
That's why I've the latest version, I think.
DMB
Noel
Post by Noel »
I guess I'm stuck with an old receiver.
I only ordered it around the beginning of March.
DMB. Did you have to send the receiver back to get it updated, or is it only a 'flash' type of update, and did you do this yourself?
<h6>Anyone interested in time travel meet me here last Thursday!!</h6>
DMB
Post by DMB »
Wifi,
I am not sure what is the regular procedure for updating the receiver.
Normally, the receiver must be sent retour to RFXCOM and they will send the updated one back to you.
DMB
Noel
Post by Noel »
Thank you for the info.
I'll email 'RFXcom sails', and see what the procedure is for this.
DMB
Post by DMB »
I think the RFXCOM support will be answering this topic very soon.
DMB
Noel
Post by Noel »
Okay. Got my receiver back today (it was only gone for 2 days), but it's still not seeing the AWST-6000 (tested in RFXcom receiver & HomeSeer itself)
The version in the receiver is now:
<b>Version request to receiver => F020
4D26 Version Master=26</b>
I'll go and get a new AWST-6000 today, and see if that one will work.
Noel
Post by Noel »
Okay.. Got a new unit, and still no data!
Let me make sure I've got things correct here.
1) I've got a RFXCom RECEIVER with firmware <b>4D26 Version Master=26</b>
2) I've got 2 KlikAanKlikUit AWST-6000 (with new AAA battery's)
I stop HomeSeer, and start the RFXcom receiver software, select the com port three, and click on [OK]
I click on 32 bit mode and than click on the "Enable ALL RF" button.
I do get a lot of data in RFXcom receiver (but none are from any units that I own. So RFXcom is working.
I put the battery's in the AWST-6000 (+ to + and - to -) and slide the LEARN button from DEL to SET.
Now I see NO NEW data in the RFXcom receiver. Also when I move the LEARN button back to DEL, I still do not receive any data.
I've tested this with both AWST-6000 units. Same results. No data is received from the AWST-6000.
Am I missing something here?
what is the version of your Rfxcom receiver software?
you can check this in the right down corner of the window.
Is Homeseer seeing any new input device?
Noel
Post by Noel »
Hi Chak
The version number of RFXcom receiver is: version 26.0.0.0
HomeSeer has seen today 17 other active 'wireless' units.
Two are from me (Oregon THC 138)
This means your KAKU devices are working?
Noel
Post by Noel »
They should work (I got a new one today with new AAA batterys), but I'm NOT seeing the units in HomeSeer and RFXcom recever.
So two options here. (1) BOTH KAKU's are dead OR (2) RFXcom does not see the KAKU's
I'm sending the RFXcom receiver back tomorrow to see what is wrong with it.
I have just installed new Kaku devices
They work fine.
Sending PM
Noel
Post by Noel »
<br />I have just installed new Kaku devices
They work fine.
Sending PM
