The new Toon 2 has been rooted!
Re: The new Toon 2 has been rooted!
So to sum.. big disclaimer yada yada yada
Good job
I’m definitely interested in rooted my Toon2
Then check this post and contact one of us: viewtopic.php?f=101&t=12162&start=15#p87542ewshop wrote:Good job
And the first rooted toons are already been delivered back or in transit to the happy forum users! I you are happy clap your hands
*clapclap* Very happy. Toon2 is such an improvement, the gui is very snappy, much more responsive.
- madpatrick
Happy me !! Working great.
Much better responce on the screen.
I've trouble to install the app Boilerstatus.
It will not install the app.
Will check whether the installer of the boiler app is toon2 compliant when I am near my laptop.
Can you check the log file for the error message?
Won't install here either.madpatrick wrote:Happy me !! Working great.
I need to rebuild the package for Toon 2 compatibility indeed.
Will do so next week, will post in the boiler app topic when ready.
Kind regardz,
Ohw yes i see. The package is only for qb2 (toon 1) now
You can easily unpack the package yourself (ar x package.name.ipk) and extract the data.tar.gz from it to install it manually though. That is what I mean. But waiting for Toonz to fix the package to allow it to install on the toon2 also is another option
The TSC team was looking at the Toon2 boot screen and we missed something but it took a while for us the understand what was missing..
Now we found it
The logo, already containing the T and C letters just missed the S from TSC
If you want this on your Toon2 (I'll create a Toon1 version also later), download the zip on your toon2 in /tmp and run this:
Now we found it
cd /
mount /mnt/boot
mv /mnt/boot/splash.bmp /mnt/boot/splash.bmp.toon
unzip /tmp/tsc-splash.zip
umount /mnt/boot
rm -f /usr/bin/psplash
ln -s /usr/bin/psplash-tsc /usr/bin/psplash
killall -9 qt-gui
- tsc-splash.zip
- (36.92 KiB) Downloaded 685 times
- madpatrick
Great !!!TheHogNL wrote:The TSC team was looking at the Toon2 boot screen and we missed something but it took a while for us the understand what was missing..
Now we found itThe logo, already containing the T and C letters just missed the S from TSC
cd / mount /mnt/boot mv /mnt/boot/splash.bmp /mnt/boot/splash.bmp.toon unzip /tmp/tsc-splash.zip umount /mnt/boot rm -f /usr/bin/psplash ln -s /usr/bin/psplash-tsc /usr/bin/psplash killall -9 qt-gui
Is it also possible to change the Toon (text/logo) on the mainscreen topleft ?
That will require a rebuild of the drawables.rcc. There are no plans to do that yet.
You can hide it already using the TSC settings menu. Changing it requires to rebuild the drawables rcc indeed.madpatrick wrote: Great !!!
Great work guys!
For everyone with a rooted Toon2; you have maybe noticed some issue's connecting to the Toon2 from your computer/laptop/whatever. Initial connection takes a while.
I have found this to be related to wifi power management in the toon2. You can turn this off.
Create this file: "/etc/udhcpc.d/90tsc" and put this in it "/sbin/wl PM 0".
Then "chmod +x /etc/udhcpc.d/90tsc" and it will be fixed after a reboot.
Funny thing is that Quby also tried to turn off power management but failed to do so. In their /etc/network/interfaces file there is this statement "post-up iw wlan0 set power_save off" but it doesn't work. They need to change that to use the 'wl' command and not 'iw'
I will add this to the update-script fix part but probably toonstore will add this also. No problem to add this manually yourself.
