Page 3 of 4
Alphatronics Visonic Wireless PC Interface
Posted: Tue Jul 21, 2009 7:56 pm
The Alphatronics receiver is available at waakzaamwonen including RS232 cable and powersadapter.
http://www.waakzaamwonen.nl/catalog/pro ... v-homeseer
Posted: Wed Jul 22, 2009 7:19 pm
by Ruud
<font size="6">Watch out </font id="size6"> don't buy this interface on "Marktplaats"
<s>It look's the same but it's a device to put 8 wireless group's tot a Alphatronics wired alarm and there is no support for Keyfobs!!!!! </s>
It's a very old version, i hope that it will work with the hs interface.
Gr Ruud
2 victims already :-(
But we're waiting for an answer from the seller
Posted: Wed Jul 22, 2009 8:33 pm
Ruud,
My interface can also connect some wireless devices but is an option we don't use.
We connect by rs232, the device has more functions though.
Can you post an image og the print
and is the article number in de manual 004318
Posted: Wed Jul 22, 2009 11:23 pm
by Ruud
Strange the code is the same.
@ Pieter ihave a problem with te picture.
I sent it by mail. Maybe you can attach this to this item.
Gr Ruud
Posted: Wed Jul 22, 2009 11:51 pm
Well I think it's the same device but a very old version!
Did you try the RS232 connector, or was there no RS232 Cable included.
Try to run Roberts plugin if possible.
Or better try to send it back and order a new version at www.waakzaamwonen.nl
Posted: Wed Jul 22, 2009 11:57 pm
by Ruud
I hope i can give it back :-(
gr Ruud
Posted: Thu Jul 23, 2009 12:04 am
I can put the Visonic Homeseer plugin online now if you want. Then you can test it this night.
Posted: Thu Jul 23, 2009 7:33 am
by Ruud
@ Robert,
Somewhere today will be fine.
And let us know wat type of serial cable we must use.
Gr Ruud
Posted: Thu Jul 23, 2009 8:07 am
by Ruud
Dus anybody now what the pinout is on the rs232 connector?
I'm looking for pin 1
Posted: Thu Jul 23, 2009 8:31 am
You need a cable like this:
This one was used between motherboard COM connection and bracket. I found one in a box with all kinds of old stuff i kept. I don't know the pinout, cause it worked instantly with this cable, so i didn't look any further.
Posted: Thu Jul 23, 2009 8:33 am
by Ruud
@robert
I have the same, but there are to ways to put it in the connector.
There is no sign on the interface and no notch on the cable ;-(
If you can give me the positioning of the redlead against the gap in the connector. :-)
gr Ruud
Posted: Thu Jul 23, 2009 8:43 am
When i get home i will :-)
Or look at the first picture in the first post?
Opening in the connetor is at the top!
Posted: Sun Jul 26, 2009 11:49 pm
by Ruud
Great News.
I am beta-testing the Hs-plug-in for this interface and it looked promising.
The first release was a little buggy, after a fix from digit it's steady now .But very beta!!!!!!!!
There is enough work to do and i have a lot of wishes.
@ Pieter maybe its time to open a new Stickey topic in the homeseer Plugin section. (bugs/wishes)
gr Ruud
Posted: Sun Jul 26, 2009 11:59 pm
Good work Ruud, I will open the Plugin Forum for the Alphatronics Visonic Reciever from Digit :-)
Re: Alphatronics Visonic Wireless PC Interface
Posted: Thu May 13, 2010 2:55 pm
by Snelvuur
So i ordered one of those since i would like my keyfobs to be working from outside the house ;-)
Now i got this one:
Logically i would believe that i have to insert the cable for the rs232, but is it correct that the power needs to come from usb? Is the reception so good i can place this thing wherever i want, because i wanted to place it in the midlle of the house for the best reception of everything. Otherwise i have to get power/usb in there too..
