Front door control
Front door control
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by mhwlng</i>
<br />do you keep the button on the keyfob pressed for > 1 second as is mentioned in the manual ?
I also have this 1 second delay between switching the relay on-off
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I haven't timed it yet, but the PGM output from the powermax should keep the relay closed for 2 seconds, while the UM7206 manual says it should take "1.5 to 2.5 seconds". But I'll check it out to be sure..
Front door control
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">rickk Posted - Today : 21:47:18
Btw.. it's also interesting to note that the messages from this keyfob are picked up by the RFXCom Visonic receiver, and look somewhat like Visonic messages.. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Hi Rick,
I have send a mail to Bert, if you really receive the key-fobs on the RFXcom Visonic receiver perhaps he can adapt this protocol in the receiver. Lets see what Bert will say.
Pieter
Pieter
Front door control
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Thanks, but hold your horses, it might just be chatter from one of my neighbors - apparently I have a fellow domotican in my neighborhood, I receive lots of unknown X10 macros, oregon sensors and visonic stuff. He might have been playing around when I was looking at the rfxcom data.
It is on 868 mhz however, and is supposed to use some rolling code.
I'll check it out in more detail soon.
- Snelvuur
Front door control
Anyone ever found those cilinders with a led light build in? they where on display in eindhoven? Btw, i placed a bit on http://wiki.binkey.nl/Doors for it, if you see errors or whatever you know what you can do..
- Snelvuur
Front door control
@pieter: http://www.nemef.nl/i-cms/editor/upload ... 202007.pdf
but i dont really see the domotica interface, or details extra or pricing, do you know?
Front door control
Look over here
http://www.gho-online.nl/nemef-meerpunt ... 71105.html
The picture don't match
mail the shop for exact price for the set.
- Snelvuur
Front door control
Geachte heer/mevrouw,
Hierbij de gevraagde informatie:
Wij hebben alleen de Nemef meerpuntsluiting comforte electronisch 4918.
Kunnen niet zeggen of dit in combi kan met domotica.
Dit kan u vragen aan Nemef zelf.
Hopende u voldoende te hebben genformeerd
Team klantenservice
seems they dont know either.. btw if you search for nemef, it shows that this thread has 2 pages, if you click on page 2 it gives a error..
Team klantenservice
Front door control
See my post above, this lock can combine with the Radaris control, below you see the controller which can be used for domotica.
The "GSM Deurbel" from Waleli is using the Nemef Comforte in there concept. http://www.gsmdeurbel.com
- Snelvuur
Front door control
http://www.nemef.nl/custom/instanties/i ... ONCEPT.pdf
page 2, then the electro magnetic.. thats the complete setup right? but as it seems, the domotica is wired correct?
Front door control
No, look on the above image, the wireless controller (grey device) is telling "Zend unit opening signal"
It's a wireless controller with 10 connectors for connection to domotica etc.
I have the complete set except for the doorlock! But like you I can't find anything on the Internet.
- Snelvuur
Front door control
In dutch:
De NEMEF Comforte meerpuntssluiting is te openen met een afstandsbediening. Openen wil in dit geval zeggen dat de kruk vrijgegeven wordt en het slot eenmalig ontgrendeld kan worden. Degene die de deur wil openen moet dit dus zelf doen; het slot ontgrendelt niet automatisch. Om het slot aan te kunnen sturen heb je het volgende nodig:
Aansturing comforte draadloos i.c.m. domoticasysteem:
- Comforte
- Radaris Ontvanger Inbouw
- connectorkabel van slot naar inbouwradaris
- Zend-Unit om aan te lsuiten op domoticasysteem
Aansturing comforte draadloos middels afstandsbediening:
- Comforte
- Radaris afstandsbediening
- Comforte
- Comforte
Front door control
I got the documentation of Nemef regarding the Radaris and electronic doorlock.
Ik heb de documentatie van het Nemef Comforte slot en de Radaris (voor Nemef 4918 en Nemef 4938)
Handleiding Nemef Radaris:
http://www.bwired.nl/images/how/Handlei ... adaris.pdf
Aansluitschema Comforte 4918/4938met een Inbouw Radaris:
http://www.bwired.nl/images/how/AANSLUI ... is4918.pdf
NEMEF afstandsbediening AB3K:
http://www.bwired.nl/images/how/NEMEFaf ... ng3kan.pdf
Folder Nemef Comforte meerpuntsaansluiting met afstandbediening:
http://www.bwired.nl/images/how/FolderComforteNL.pdf
Front door control
Ter info:
Ik gebruik al jaren een BKS Gemotoriseerde meerpuntsvergrendeling, in 2005 aangeschaft bij Eurolocks.nl (artikel wordt nog gevoerd).
Apparaat sluit zichzelf op 2 van de 3 schoten. Derde schoot evt nog met sleutel te sluiten.
Bediening via Keyfob -> RFXcom ontvanger -> Homeseer -> Eigen brouwsel Plug-in -> phidgets interface -> meerpuntsvergrendeling.
(alternatieven voor traject Keyfob -> RFXcom: internet interface of telefoonmodem, beide met paswoord. Handig als je je sleutel en keyfob vergeet)
Wel is er een kabeltje van deurslot naar interface nodig, tevens voor 24V voeding. (In mijn geval geen probleem, want voordeur naast meterkast met HS-computer)
Werkt sinds 2005 volledig betrouwbaar. Druk op keyfob en deur gaat open (plus alarm er af etc.)
Gerard
Gerard
Front door control
Hallo Alders,
Wil jij misschien de "code" of URL van het product posten?
Ik kan de BSK niet vinden op Eurolocs.nl
- Snelvuur
Front door control
look for Meerpuntsvergrendeling Code 316/1 if you open the PDF (maatvoering) you see it is BSK. I presume its this one.
