Page 3 of 4
Re: MetdeZon Zonnepanelen voor Bwired
Posted: Mon Aug 22, 2011 9:07 pm
by nico_gh2
Panels are looking good!
As for the meter I thought only the ones with the spinning disc will turn backward.
http://www.solar-net.nl/zonnepanelen/Meters-sp-7.html (dutch link) shows a few types but probably not the one you are using.
Posted: Mon Aug 22, 2011 9:14 pm
Then its likely that i have a new problem!
Posted: Tue Aug 23, 2011 12:51 pm
by Jeroen Bartels
Is it an idea that everybody with a PV System monthly posts the yield of their system in Kwh/Kwp so we can compare the systems.
We can do this on the Domoticaworld Page (The one with google maps)
Posted: Tue Aug 23, 2011 1:10 pm
by Harry
i have the Enermet Ty120i, do's this meter go back.
i can't find any info about that topic.
are there more who have this meter, and perhaps now if it runs back??
Posted: Tue Aug 23, 2011 2:46 pm
by Niels
You can have a look at this document:
kema.com/Images/Uitgegeven%20metercodes ... zicht).pdf
You can also just try after installing the panels. Just shut down all groups except the one for the solarpanels.
If it doesn't turn back, call your energysupplier and tell them you have installed solarpanels. Probably they will offer you to change your meter for one with "teruglevertelwerken" for free (they don't like old feraris-meters because they can't measure how much you "saldeert" ).
If you only call them asking to change the meter they will probably charge you for that.
Posted: Tue Aug 23, 2011 7:07 pm
My meter needs to be replaced and looks a bit the same as harry's meter
Enexis will do this free of costs, they will call me within 10 days, and it can be the following model
- Ampy 5527C
- Actaris ACE3000
- Iskra ME171
- Kamstrup
enexis.nl/zelfenergieproduceren/mediath ... rmeter.jsp
Now i need to be sure that i can hook it up again to rfxcom or use a pulsecounter
Measuring the benefits of the sunpanels
Posted: Tue Aug 23, 2011 7:31 pm
by Verkenner
Hi Peter, strongly recommended:
Ask Enexis for a smart meter that can be interfaced with Plugwise
Ask Plugwise what Smart meter (with P1-port) can be interfaced with Plugwise systems
The new products from Plugwise can read the P1-port from the Smart meters.
Plugwise energymanagementsystem is comming.
Posted: Tue Aug 23, 2011 8:21 pm
by mhn
Posted: Tue Aug 23, 2011 10:42 pm
Yes, i'm analyzing the smartmeters.
Enexis is telling me what I get depends on what is in stock with the engineer.
So i will talk to the engineer, would be nice to have an extra P1 port.
The minimal requirement is that it has a blinking LED
But it would be better to read via P1 or other connector and get all the counters (day/night and solar)
Measuring the sun
Posted: Tue Aug 23, 2011 11:39 pm
by Verkenner
Sorry OFF TOPIC: Smart meters are not all smart.
You need a smart meter with DSMR 3.0 P1-port (specs are in the NTA 8130), and the the deployment proces was succesful (Enexis does).
A smart meter also can transmit the gas-usage over the P1-port (the gasmeter is connected to the electrictymeter and sends data once an hour, not realtime).
The smart meter has 4 counters ("telwerken").
Of course your back feeding (to the public netwerk from Enexis) from the sun-panels is recorded.
But realise that
depending of your sun-panel-capacity on your roof and your own electricity-consumption normaly you do not feed-back very much.
That's frustating in the beginning.
Posted: Wed Aug 24, 2011 7:53 pm
by John
I have a feedback op approx. 40%
Posted: Thu Aug 25, 2011 12:33 am
tuesday my new meter will be installed, i have to get friends with the engineer
Best thing is an interface where i can read the packets for every counter with rs232 or rs485
Posted: Sat Sep 03, 2011 11:42 am
by John
This month (august 2011) the yield of my PV system was 99.9 kWh / kWp
Posted: Sun Sep 04, 2011 10:52 am
by AshaiRey
i have one without a disc, but with a mechanic counter
I expect it to run backwards......
Can anybody tell more about this
I have an old ferraris meter and i can confirm that it will turn backward during the day. There isn't a more statisfying thing to watch then this. I don't make use of any feed-in agreement or such because my feed-in is very small and i don't want to loose my good old ferraris meter and paying each year more for a so called 'smart' meter.
Btw, Ferraris meters can be bought from Conrad
Posted: Tue Sep 06, 2011 9:03 pm
by PietjeNL
If your old meter did run backwards, then u should not have replaced it.
Energie suppliers say u have to but there is no need to other that they make more money.
This is cause the running backwards meters give u the full kWh price back (with tax and network costs), the smart meter only gives the clean kWh price.
