Homeseer Script to monitor & Control ELV MAX! Thermostats
Bastiaan
Re: Homeseer Script to monitor & Control ELV MAX! Thermostats
Post by Bastiaan »
As far as I know is the current room temperature not available in the radiator valve values. (Strange I agree).
Not sure if it is in the wall thermostat but that item is still not available.
Bastiaan
Fischi
Post by Fischi »
Thanks for your reply, Bastiaan,
What's about the On-Line.gif folder ???
Regards, Fischi
blb
Post by blb »
Hi Fischi,
Good to see the script works for you! About the actual temp: it's very stupid, but it seems the MAX system is not able to present the actual (measured) temperature in the room. If you look on the ELV forum, this issue (IST Temperature) is discussed in many threats, but no solution (yet)....
Bernard
Fischi
Post by Fischi »
Thank you very much, Bernard,
Please tell me about the On-Line gif folder !!!
Regards from Germany
Fischi
Snelvuur
Post by Snelvuur »
blb
Post by blb »
I have installed the new firmware (see domoticaforum.eu/viewtopic.php?t=7334&a ... 021#p55021) and have experienced no problems so far with the script.
Bernard
Snelvuur
Post by Snelvuur »
Actually the system date and time is now green, so its even better for me.
Fischi
Post by Fischi »
Hi, Bernard
I have also installed the firmware 1.3.4 without issues.
The Homeseer thermostat control also works fine with my philips pronto TSU9600 to control 9 thermostats.
I have still a little problem :
The Pronto cannot show The Temperature.gif ("<img src='/images/Temperatures ") , only " Mode/Setpnt/Valve%/EndDateTime" because the string is to long.
Can you change the max_monitor_script for me , so Homeseer (and also the Pronto that shows the string from Homeseer) only shows :
Mode/Setpnt/Valve% ( without EndDateTime and without the Temperature image) ?????
The message box on the Philips Pronto isn't long enough to show your complete DeviceString, and I only need "Mode/Setpnt(Valve%" on Homeseer.
I hope you can help me
Thanks and Best regards from Germany
Fischi
Fischi
Post by Fischi »
Hi, Bernard
I found a solution for the problem by myself.
Thanks
Fischi
Snelvuur
Post by Snelvuur »
Bernard,
I got a strange there here, on the Max it says "kleding kamer" which was missing its link, but on homeseer it said that "baby kamer" was non functnional. So for some reason it has swapped those 2 rooms in homeseer. Any ideas on how to resolve this?
Fischi
Post by Fischi »
Hi, Bernard,
I have installed 7 MAX thermostats now.
There is a big problem : not ever but often in the HS log there comes a message : "Array index out of range".
What is the reason for this ???
How many thermostats may I install ?
Best regards, Fischi
Fischi
Post by Fischi »
I have running the homeseer MAX! script with 9 thermostats, and all works fine for me.
Today I've tried to install a window contact, but ist doesn't work with homeseer.
There is always a message in the log :
Max_debug C10: unknown device: 04
Bernard, do you use the windows contacts from ELV??
Could you change the script to work with homeseer ??
Thanks and have a nice weekend
Fischi
blb
Post by blb »
Fischi,
I have 8 thermostats myself, so 7 should not be a problem (giving array index out of range). Do you still see that message?
I'm not using other devices than the thermostats (and the Cube off course). If the script finds another device ID, it gives this debug message. I can try to implement other devices (like windows contacts and eco-switch), but I will need information like protocol analyser output from wireshark when operating these devices and direct after initial start of web-application (which will give all info from your setup). And no guarantee this is going to work...
Bernard
blb
Post by blb »
Snelvuur,
The script is putting the names in homeseer only with the first run when it creates the devices. Currently It doesn't update the names afterwards. A work-around is to delete all devices in homeseer and to run the script again. It will create all devices with the current names.
Bernard
Fischi
Post by Fischi »
Hi, Bernard,
when I have installed and activated the MAX! door/windows sensor, there comes the message "Array index out of range" after running script and the MAX! cube is not to see in Homeseer anymore
(no serial number, ..., of the cube)
After the MAX! door/windows sensor is deinstalled and deactivated, the system runs perfect and I ca see the informations of the MAX!cube .
Is it possible that Homeseer ignores the MAX! door/windows sensor, this sensor works in stand alone mode without the help of Homeseer ??
I have another question: In our house there are mor than 9 thermostats. Is it also possible tu integrate mor than 9 ??
