Page 3 of 4
Chromoflex RGB controller (Lite DMX Alternative)
Posted: Wed Apr 08, 2009 11:35 pm
Esteban is it possible to get the source code?
I still have my chromoflex on the shelf, its about time to do something with it
thanks
Posted: Thu Apr 09, 2009 12:31 am
by Esteban
@r_255: Good to hear it works with all of them!
@niknik: Well the important thing is that you're back. There has been a lot of cool stuff happening on the forum lately, as you've probably noticed. Good luck with your kitchen.
@Bwired: Hehe, check your mail.
Ciao,
Esteban
Posted: Thu Apr 09, 2009 12:58 am
by r_255
Works fine on 4 of them and still got 2 to connect and they are waiting on the shelf till i find out how to connect them to my 3watt rgb leds.
Thanx again for your time and efforts.!
Robin
Posted: Sat Jul 25, 2009 1:36 pm
by Killerawft
hi
I read that Topic cause i want to controll my Chromoflex with my Keyboard or mayby with my iPhone. But i dont know where i have to tipe in the Codes from the manual. when i click on the exe file, a command line windows opens very short.
I hope you could help me
Posted: Sat Jul 25, 2009 3:27 pm
by Esteban
Hi Killerawft,
This program is not ment to be double-clicked. CCCP is a command-line tool, so it needs to be run from inside a DOS-prompt (aka DOS box) or via an external program of your choice (like Homeseer) that can do that for you. And you need to type in 'the codes' (aka arguments) BEFORE running te program.
-To open a DOS window go to:
START/Run...
-Type:
cmd
-Press ENTER
Now, in the DOS box go to the folder where CCCP is located. And run the program with the 'codes' (aka arguments) of your choice as described in the manual.
Ciao,
Esteban
Posted: Sat Jul 25, 2009 6:52 pm
by Killerawft
ok thanks it works.
great job dude
Posted: Sun Jul 26, 2009 9:57 pm
by ybjlus
Esteban,
First ofall nice done!
Is it possible to save the userdifined program into the cf? so it doesn't need to be connected to the pc all the time...
Posted: Mon Jul 27, 2009 2:36 am
by Killerawft
Hey Esterban i tried the Tool the last days out and programmed my keyboard to controll my controller, but i cannot turn on the first program on the second button. i used the argument cccp 3 0 0 0 21 203 and its also decribed in your manual like that. All the other programms and keys and everything works great but not that.
Posted: Wed Jul 29, 2009 6:14 pm
by Esteban
<b>@ybjlus:</b> Not with CCCP, but using the app (CF_edit) supplied by the manufacturer you can change some of the preset slot settings and save them back to one of the preset slots on the Chromoflex. Keep in mind though that it is all fairly limited.
There is another (more obscure) way of scripting some more what kind of effect you want, but this isn't really documented by the manufacturer. Have a look at the other app bundled with CF_edit named CF_Composer. The .eff files it uses are some kind of scripting language giving more flexibility in what you can store in the preset slots. I have no further info on that though as I never really researched this too extensively.
<b>@Killerawft:</b> No idea why it isn't working for you. Maybe re-check if you're in the right 'mode' aka not in 'custom mode' or put it under another button just to be sure. But the command works fine over here, I re-checked it, to be sure.
Ciao,
Esteban
Posted: Thu Jul 30, 2009 7:19 pm
by Killerawft
i tipped cccp 3 0 0 0 21 203 and then nothing happen. All the other arguments works. but in that time i wrote a batch file, with that i dont ahve to write all the arguments and everithing works too but not that slot
Posted: Fri Jul 31, 2009 12:07 am
by Esteban
Maybe, for some reason your 'slot 2' is empty or corrupt on the Chromoflex? Can you start 'slot 2' with the remote or directly on the chromoflex via the wires on which you can connect buttons?
Ciao,
Esteban
Posted: Sun Aug 02, 2009 12:34 am
by Killerawft
i am in the right mode and i tiped it in by hand and it dosent work
Posted: Sun Aug 02, 2009 1:03 am
by Esteban
But can you manually activate slot2? (without using cccp)
Re: Chromoflex RGB controller (Lite DMX Alternative)
Posted: Tue Jan 19, 2010 12:17 pm
Esteban,
Is there a seperate code to turn the chromoflex off?
I do it now by putting all the values to 0
With the IR remote its possible to turn the Chromoflex off....
Posted: Tue Jan 19, 2010 4:55 pm
by Esteban
Hi Pieter,
To my knowledge there isn't, so no. Myself, I turn it off using a z-wave module.
