No, because there is an overlay window active in dim state covering the whole screen. A press anywhere on screen (that overlay window) will bring you out of the Dim stateLuc_S wrote:Hey all, is there any way to open an app directly from the dim-state window?
Software: modifications and extensions Toon
And we are unable to tweak this overlay in any way? I'm having some trouble finding out where this overlay function is located.Toonz wrote:No, because there is an overlay window active in dim state covering the whole screen. A press anywhere on screen (that overlay window) will bring you out of the Dim stateLuc_S wrote:Hey all, is there any way to open an app directly from the dim-state window?
Look in Canvas.qmlLuc_S wrote:Toonz wrote:And we are unable to tweak this overlay in any way? I'm having some trouble finding out where this overlay function is located.
Does anyone know where the module 'BasicUIControls' comes from?
I can't find it as javascript on the Toon and can't find it anywhere online as cpp (as I could with FileIO).
Are these closed source classes written in cpp by Quby?
Yes, most likely.
Most of the code on Toon is open source, so there's a strong possibility that this particular module is (at least derived from) publicly available code.
I finally decided to mount the Toon in the living room and replace the existing thermostat.
And offcourse the missus had a comment ready right away; the hue/controlpanel-button was too bright in the dimstate.
And I must say that I agree; it's a rather large white-button with tiny black dots and a small arrow.
It's a nifty little button; because it allows you to open the controlpanel right away.
I decided it was better to invert this color scheme, black background, white dots/arrow.
Since the icon has a transparent background; we must edit its parent object.
Replace #ffffff with #000000 as shown below. (6x zeroes, for all black, instead of white)
/qmf/qml/qb/components/SlidePanelButton.qml
I edited the svg using this online editing tool.
http://editor.method.ac/
The file to edit is located here:
I attached both the original and the modified version (in case you mess yours up)
color: canvas.dimState ? "#000000" : (root.parent.panelOpen ? colors.canvas : colors.background)
/qmf/qml/apps/controlPanel/drawables/controlPanelClosed_dim.svg
- controlPanelMod.zip
- (911 Bytes) Downloaded 890 times
To copy this mod to Toon2 I've been messing with drawables.rcc (or its contents)
and found the following svg in plain-text
With this online tool I was able to make some modifications:
https://www.rapidtables.com/web/tools/s ... ditor.html
I used "grey" to maintain visibility on the white background, but white is preferred.
I can't seem to make the background black, but I'm unsure if that's necessary.
Any guidance, will this work?
<svg id="Layer_1" data-name="Layer 1" xmlns="http://www.w3.org/2000/svg" viewBox="0 0 20 20"><title>controlPanelClosed_dim</title><g id="Layer_2" data-name="Layer 2"><g id="control_panel" data-name="control panel"><circle cx="4" cy="4" r="4"/><circle cx="16" cy="4" r="4"/><circle cx="4" cy="16" r="4"/><path d="M19,12a1,1,0,0,0-1,1v3.586L13.414,12A1,1,0,0,0,12,13.414L16.586,18H13a1,1,0,0,0,0,2h6a1,1,0,0,0,1-1V13A1,1,0,0,0,19,12Z"/></g></g></svg>
<svg id="Layer_1" data-name="Layer 1" xmlns="http://www.w3.org/2000/svg" viewBox="0 0 20 20" ><title>controlPanelClosed_dim</title><g id="Layer_2" data-name="Layer 2"><g id="control_panel" data-name="control panel"><circle cx="4" cy="4" r="4" fill="grey"/><circle cx="16" cy="4" r="4" fill="grey"/><circle cx="4" cy="16" r="4" fill="grey"/><path d="M19,12a1,1,0,0,0-1,1v3.586L13.414,12A1,1,0,0,0,12,13.414L16.586,18H13a1,1,0,0,0,0,2h6a1,1,0,0,0,1-1V13A1,1,0,0,0,19,12Z" fill="grey"/></g></g></svg>
Nope, you can't 'text edit' the rcc files. Just leave the drawables.rcc as it is.
If you need that mod I will need to change the resources.rcc and add the new button somewhere. Takes some work though.
Will the existing controlPanel app use the modified button?
I'm trying to take my first babysteps into toon programming. I wanted to start following the basic clock examples given in this thread but I'm stuck before I even began.
The problem is not being able to find the location of the clock tile. I've tried the following to find it.
But as you can see all i find is a (practically) empty directory. What's going on here?
# find / -name clock
/qmf/qml/apps/clock
# /qmf/qml/apps/clock# ls -al
drwxr-xr-x 3 root root 224 Sep 12 17:48 .
drwxrwxr-x 34 root root 2752 Nov 8 11:36 ..
drwxr-xr-x 2 root root 1952 Sep 12 17:54 lang
Since FW 4.16.x all qml code has been packed in what is called a resource file (extension .rcc). These files are binary blobs holding all qml code. To start coding yourself, you can install the modified rcc files from the forum ftp server. Checkout this thread for more info:
viewtopic.php?f=96&t=12071
Then install the toonstore, and checkout the code that's installed through it. Our apps are still plain qml/javascript, so it's easy to read and modify these.
Happy coding!
Happy coding!
Thanks for the information.
cygnusx wrote:Well, almost everything is possible. The language is QML. It's a language to define which widgets go where and define some specifics. But, all the rest in the QML file is actually Javascript.
So, things like x&y coordinates, height, width, opacity etc. is QML, and actions like onclick, loading data on specific intervals, that's all plain javascript.
That makes it kinda easy to program for it. It's mostly basic javascript programming.
I use the original modules to make my own. For instancy, my lights/blinds screen is just a modification from the original one. The difference is that Quby does not do web requests via QML/Javascript but it has it's own daemon on the background where it communicates with. I suppose that has better software application development company performance than my solution, but that part (the daemon) is written in C, in other words, it's compiled and not (easily) modifyable. But if you are smart you can just get away with using javascript.
For instance. I made my own weather script instead of using the default one. It's based on buienradar, so the data is already publicly available. Normally, Toon gets regular weather updates from its backend daemon. This daemon reads the full weather xml and fetches the interesting part (only the weather for your location instead of all weather stations in NL) and sends it to the Toon frontend. In this way, Toon does not have to process all of the data what could make it slow.
I do almost the same. I have a PHP script running on a raspberry pi in my house. This script fetches the buienradar xml. It get's my relevant weather station and sends that part to toon. on my toon i do the rest.
