Bwired Googlemaps upload data webservice
- appie
- Starting Member
Re: Bwired Googlemaps upload data webservice
I like to add my data to the web service but I have no idea how to get the data out of my system into a XML file.
I’m using xComfort with IP-Symcon.
Someone a idea or better, already a script to do this?
Thanks,
Albert
Thanks,
Albert
Hi Pieter,
I like to use your domotica map also, see my XML;
I also created a PHP class for posting the data, I'd like to share this with other forum members. When my first data posts are succesfull I will share the code here
<?xml version="1.0" encoding="UTF-8"?>
<BWired>
<Init>
<DateTime>07-08-2012 12:09:35</DateTime>
<UserName>ludom</UserName>
<Password>B3w1r3dW3bs3rv1c3</Password>
<ScreenName>Ludom</ScreenName>
<Gpslat>51.4308</Gpslat>
<Gpslong>5.5399</Gpslong>
<City>Geldrop</City>
<Website/>
<WebCamPicUrl/>
<Title>Ludom's Online Home</Title>
</Init>
<Entry>
<Name>Temperature Outside</Name>
<ID>0</ID>
<Units>C</Units>
<Value>17.5</Value>
</Entry>
<Entry>
<Name>Temperature Inside</Name>
<ID>1</ID>
<Units>C</Units>
<Value>21</Value>
</Entry>
</BWired>
Home-brewed HA system based on Linux, PHP5, MySQL and Beanstalkd
Hi Ludom
i see your googlemaps XML's coming in on my Bwired server
your set to go now!
your set to go now!
Nice, it's working
I tweaked my PHP class a bit and is now ready to use (see attachment).
- Bwired_Webservice PHP Class.zip
- (2.05 KiB) Downloaded 962 times
- appie
- Starting Member
I try to get this working with the script of Ludom but I don’t see the XML file.
See the review echo below from the script, is this enough for sending my XML string upload to the WebService of BWired?
Albert18-08-2012 12:13:56albertshousealbertshouse2012AlbertsHouse51.8442794.968341Gorinchemwww.albertsweb.nlhomeserver.albertsweb.nl:82/data/img.php?imageid=45997MyTitle2Temperature outside:029.1 °CTemperature inside:123.8 °CHumidity outside:250.4 %Humidity inside:346.2 %
Bwired Googlemaps Webservice.
I need to put you in the database also, i will check my server and do this
Appie, should work now, start uploading.
I have seen your XML on my server.
- appie
- Starting Member
Great, it’s working .......
A few questions:
- I had some problem with the little o in the oC, is there a way to put this in the code?
- Is there a way to put a blank line into the sensor data?
Albert
A few questions:
Albert
Hi Albert,appie wrote:Hi,
The echo is just for testing purposes. When you enable the echo and test it in your webbrowser you can press ctrl-U to open the page source, there you will find the full XML structure. When you use the POST function the data will be passed to Bwired.
For using the degrees celsius sign you can use an UTF-8 / ASCII code;
http://tlt.its.psu.edu/suggestions/inte ... chart.html
For degrees celsius you can use;
°C
- appie
- Starting Member
Hi Ludom,
When I put this in the code no XML upload is send to BWired. I don’t see a error, but in the echo I see the °C and not the oC.
Maybe this is because I’m running the code inside IP-Symcon, I’m not sure?
Is there a way to make a blank line, to separate the different sensor groups?
Albert
$bwired->addEntry('Temperature Outside:', 1, '°C', $temp_out);
Albert
Hi Albert,appie wrote:Hi Ludom,
Is there a way to make a blank line, to separate the different sensor groups?Code: Select all
Albert
Thats weird! I am using the same code at my side and that's working fine.
It could be something with charset encoding (UTF-8, etc.), what happens when you place non ASCII version of the sign ? so copy-paste the following;
°C
- appie
- Starting Member
Ludom,
When I put the o in of the oC no data is shown in GoogleMaps. A space is no problem, all uploaded data is shown.
I don’t know if the data is send or not processed by BWired, but I see other location with the o. Maybe BWired is reading this and could tell us if it’s something in my script. Is there code I can put in to do something with the UTF-8?
For the blank line, I tried to use the addEntry for this but can’t find the way to clear all text in it. Is there a way to do this with addEntry? When I put this line in all data below is not presented.
Albert
$bwired->addEntry(' ', 7, ' ', NULL);
Dont know your script that good, did you see this....
http://www.domoticaforum.eu/viewtopic.p ... 120#p17557
Hi Bwired,
No didn't saw that page from this topic, but I have seen it now.
I tested this at my side and the UTF-8 code for degrees celsius "#186;" works. Because i am using PHP i need to parse this as "º" and that works perfectly with the PHP class. The degrees celsius sign is displayed fine on the map.
@appie
Use the following code which should work;
@appie
$bwired->addEntry('Temperature Outside:', 1, 'ºC', $temp_out);
great
i see a lot of unknown xml's coming in, but stil in Error
