Page 22 of 44
Posted: Sun Dec 16, 2018 5:38 pm
by mAiden
alcomys wrote:When try to use the update script i got this as output on toon.
what is wrong ?
(first try) eneco-xxx-xxxxxx:~# ./update-rooted.sh -f
sh: ./update-rooted.sh: not found
(second try) eneco-xxx-xxxxxx:~# sh update-rooted.sh -f
sh: can't open 'update-rooted.sh'
thanks
That error message means it can't find the file. Are you sure the file is still there, and you typed the name correct?
Posted: Sun Dec 16, 2018 5:44 pm
by TheHogNL
And this is exactly what I mean in the other posts. mAiden is pointing out exactly what is wrong. Even the command line is telling your that the file isn't found. This should tell you that you probably have forgotten the most crucial thing, download the script first.
The update script requires some knowledge of basic linux skills. If you fail you can easily break your just rooted Toon. You have been warned.
Posted: Sun Dec 16, 2018 6:03 pm
by alcomys
TheHogNL wrote:And this is exactly what I mean in the other posts. mAiden is pointing out exactly what is wrong. Even the command line is telling your that the file isn't found. This should tell you that you probably have forgotten the most crucial thing, download the script first.
the file is there but never mind, i will not ask things again.
you totally right i need a linux course before i can root toon.
till that time i put my toon back on the wall and leave it there.
all the docs i read there was not the information i needed, the docs are some outdated for toons with the newer firmware and the other information is wide spread but some of them i cant use.
want to thank for all the help
Posted: Sun Dec 16, 2018 7:13 pm
by marcelr
If the file is there, what's the output of
Posted: Mon Dec 17, 2018 11:18 pm
by maikelvds
Just updated Toon with the script, worked perfectly.
Nice updates! Thanks a lot!
Posted: Thu Jan 03, 2019 12:27 am
by Rudi
- file-1.pdf
- file-1
- (222.17 KiB) Downloaded 411 times
I am trying to update my just rooted toom from firmware version 3.2.18 to firmware version 4.10.6.
Unfortunately this does noet work due to several errors.
When executing the script with: ./updated-rooted.sh
i see the following error:
see file 1...
I have attached the errors that were dumped in the file: /HCBv2/tmp/opkg-cache/upgrade-qb2.sh.log
I hope that someone can help me with this issue
Posted: Thu Jan 03, 2019 10:36 am
by TerrorSource
Rudi wrote:Collected errors.pdf
file-1.pdf
see file 1...
Looks like your Toon cannot connect to the repo. Maybe because network issues or did you had your Toon "touched" by Quby before?
Posted: Thu Jan 03, 2019 11:07 am
by TheHogNL
Did you try to run it again? Could also just be a temporary issue at the eneco servers.
Posted: Thu Jan 03, 2019 11:09 am
by Rudi
I have bought this TOON via Marktplaats. After that i have immdiately rooted the TOON.
The only touch after that was that it was able to ping with QUBY.
Posted: Thu Jan 03, 2019 11:11 am
by Rudi
I have tried it several times. Also with different firmware.
Posted: Thu Jan 03, 2019 1:01 pm
by TheHogNL
I could help you using teamviewer if you send me your 06-number in a private message. I will then whatsapp you.
Posted: Thu Jan 03, 2019 9:39 pm
by TheHogNL
I just finished helping you. Your toon was somewhere in between two old updates (caused by the previous owner during an official eneco update) and it took a bit of a effort to fix that. Now your toon is on 4.22.7
Posted: Mon Jan 21, 2019 8:31 pm
by TheHogNL
During some updates to 5.0.4 a issue in an installed Sonos app was causing a failed upgrade.
In the newest update script the sonos app will be automatically removed before starting the upgrade.
So, if you do a upgrade and find out that your sonos app is missing, please don't blame me. This was necesarry to keep your toon working. Just reinstall the sonos app afterwards.
Posted: Mon Jan 21, 2019 9:28 pm
by Toonz
instead blame me
I made a mistake in the installer file for sonos 1.0.4 which didn't surface earlier.
I just released version 1.0.5 which is clean.
Posted: Thu Jan 24, 2019 11:12 am
by mariusbrouwe
I just rooted a Toon (running version 4.3.20) I bought from Marktplaats successfully. Which was a total breeze with the ToonRooter script! Then I tried to update the Toon to version 4.22.7 since my Toon was urging me on to install this update on the screen. The script prompted me that version 4.10.6 needed to be installed first so it exited and I retried the script with the option to use version 4.10.6. However the script exits again, revealing the following errors in the log:
* opkg_download_pkg: Package tenant-eneco-nl is not available from any configured src.
* opkg_install_pkg: Failed to download tenant-eneco-nl. Perhaps you need to run 'opkg update'?
I ran 'opkg update' resulting in not being able to resolve the hostname feed.hae.or
ig. This is a typo since I can reach the files from feed.hae.org. However after trying to run the update I came across this post:
TheHogNL wrote:No don't use opkg update if you don't know what you are doing
So I decided to stop what I was doing
Any advice as what to do next to be able to update my Toon to version 4.22.7 or if possible to 5.0.4?
opkg update log
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/Packages.gz.
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/Packages.sig.
Signature check failed.
Remove wrong Signature file.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/Packages.gz.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/Packages.sig.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-R10-h27-no6/Packages.gz.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-R10-h27-no6/Packages.sig.
Collected errors:
* opkg_download: Failed to download http://feed.hae.orig/feeds/qb2/ene/4.10.6/Packages.gz: Couldn't resolve host name.
* opkg_download: Failed to download http://feed.hae.orig/feeds/qb2/ene/4.10.6/Packages.sig: Couldn't resolve host name.
/mnt/data/update/upgrade-qb2.sh.log
>> 2019-01-24 07:44:34 +0000 (pid 6328) upgrade-qb2.sh qb2 ene 4.10.6 prepare
>> 2019-01-24 07:44:34 +0000 (pid 6328) prepare
>> 2019-01-24 07:44:34 +0000 (pid 6328) preparing
>> Hotfix for writing System Time to RTC
Hardware Clock before: Thu Jan 24 07:44:33 2019 0.000000 seconds
Hardware Clock after : Thu Jan 24 07:44:35 2019 0.000000 seconds
>> configured opkg feeds:
src/gz base http://feed.hae.orig/feeds/qb2/ene/4.10.6
src/gz oebase http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni
src/gz oekern http://feed.hae.orig/feeds/qb2/oe/2.6.36-R10-h27-no6
>> opkg --download-only update
>> monitoring /mnt/data/update for threshold 5000
Inflating http://feed.hae.orig/feeds/qb2/ene/4.10.6/Packages.gz.
Updated list of available packages in /var/lib/opkg/base.
Signature check passed.
Inflating http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/Packages.gz.
Updated list of available packages in /var/lib/opkg/oebase.
Inflating http://feed.hae.orig/feeds/qb2/oe/2.6.36-R10-h27-no6/Packages.gz.
Updated list of available packages in /var/lib/opkg/oekern.
> Exit code: 0
>> opkg --download-only upgrade
/tmp/update.status.vars: Downloading 0% (1/158)
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-netcon_1.346-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/qmf-tenantize_0.1-r0_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/gettext_0.18-r5_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/libgettextsrc_0.18-r5_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/libgettextlib_0.18-r5_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/libjansson4_2.10-r1.0_qb2.ipk.
/tmp/update.status.vars: Downloading 0% (1/158) hcb-netcon
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-pwrusage_1.674-master_qb2.ipk.
/tmp/update.status.vars: Downloading 0% (2/158) happ-pwrusage
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/boot-logos_1.71_qb2.ipk.
/tmp/update.status.vars: Downloading 1% (4/158) boot-logos
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/busybox-mountall_1.27.2-r1_qb2.ipk.
/tmp/update.status.vars: Downloading 2% (5/158) busybox-mountall
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/busybox-syslog_1.27.2-r1_qb2.ipk.
/tmp/update.status.vars: Downloading 4% (8/158) busybox-syslog
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/busybox_1.27.2-r1_qb2.ipk.
/tmp/update.status.vars: Downloading 8% (14/158) busybox
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/libhcb-drv_1.342-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/libhcb-base_1.293-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/qmf-0_1.19-master-r0_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/libhcb-boxtalk_1.123-master_qb2.ipk.
/tmp/update.status.vars: Downloading 11% (20/158) libhcb-drv
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-kpi_1.406-master_qb2.ipk.
/tmp/update.status.vars: Downloading 13% (22/158) happ-kpi
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-rrd_2.159-master_qb2.ipk.
/tmp/update.status.vars: Downloading 15% (26/158) hcb-rrd
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-comm_1.184-N-master_qb2.ipk.
/tmp/update.status.vars: Downloading 16% (28/158) hcb-comm
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/www-resources_1.35-master_qb2.ipk.
/tmp/update.status.vars: Downloading 20% (34/158) www-resources
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/libhcb-xml_1.111-master_qb2.ipk.
/tmp/update.status.vars: Downloading 23% (38/158) libhcb-xml
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/firmware-ma_1.113-master_qb2.ipk.
/tmp/update.status.vars: Downloading 25% (41/158) firmware-ma
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/qt-gui_1.8075-ene-release-4.10_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-thermstat_1.1919-release-4.10_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-usermsg_1.87-master_qb2.ipk.
/tmp/update.status.vars: Downloading 28% (47/158) qt-gui
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/wpa-supplicant-cli_2.6-r0_qb2.ipk.
/tmp/update.status.vars: Downloading 29% (48/158) wpa-supplicant-cli
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-bxtproxy_1.349-master_qb2.ipk.
/tmp/update.status.vars: Downloading 34% (56/158) hcb-bxtproxy
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hdrv-zwave_1.1284-master_qb2.ipk.
/tmp/update.status.vars: Downloading 38% (62/158) hdrv-zwave
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/base-qb2-ene_4.10.6-1196-0_qb2.ipk.
/tmp/update.status.vars: Downloading 38% (63/158) base-qb2-ene
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-eventmgr_1.212-master_qb2.ipk.
/tmp/update.status.vars: Downloading 41% (67/158) happ-eventmgr
/tmp/update.status.vars: Downloading 43% (71/158) happ-usermsg
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/lighttpd_1.4.33-28_qb2.ipk.
/tmp/update.status.vars: Downloading 45% (73/158) lighttpd
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-weather_1.147-master_qb2.ipk.
/tmp/update.status.vars: Downloading 50% (82/158) happ-weather
/tmp/update.status.vars: Downloading 51% (83/158) libhcb-boxtalk
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/wpa-supplicant_2.6-r0_qb2.ipk.
/tmp/update.status.vars: Downloading 52% (85/158) wpa-supplicant
/tmp/update.status.vars: Downloading 60% (97/158) qmf-0
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-smartplug_1.203-master_qb2.ipk.
/tmp/update.status.vars: Downloading 66% (107/158) happ-smartplug
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-log_1.79-master_qb2.ipk.
/tmp/update.status.vars: Downloading 67% (109/158) hcb-log
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hdrv-p1_1.724-master_qb2.ipk.
/tmp/update.status.vars: Downloading 73% (119/158) hdrv-p1
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hdrv-hue_1.221-master_qb2.ipk.
/tmp/update.status.vars: Downloading 74% (120/158) hdrv-hue
/tmp/update.status.vars: Downloading 83% (135/158) happ-thermstat
/tmp/update.status.vars: Downloading 89% (144/158) libhcb-base
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-scsync_1.267-master_qb2.ipk.
/tmp/update.status.vars: Downloading 91% (147/158) happ-scsync
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/libhcb-com_1.124-N-master_qb2.ipk.
/tmp/update.status.vars: Downloading 92% (148/158) libhcb-com
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/wpa-supplicant-passphrase_2.6-r0_qb2.ipk.
/tmp/update.status.vars: Downloading 93% (150/158) wpa-supplicant-passphrase
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-config_1.331-master_qb2.ipk.
/tmp/update.status.vars: Downloading 96% (155/158) hcb-config
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-watchdog_1.69-master_qb2.ipk.
/tmp/update.status.vars: Downloading 100% (158/158) hcb-watchdog
Collected errors:
> Exit code: 255
>> 2019-01-24 07:46:03 +0000 (pid 6328) prepare-error-opkg-download-download 'opkg failed to download'
>> 2019-01-24 08:05:13 +0000 (pid 7795) upgrade-qb2.sh qb2 ene 4.10.6 prepare
>> 2019-01-24 08:05:13 +0000 (pid 7795) prepare
>> 2019-01-24 08:05:13 +0000 (pid 7795) preparing
Hardware Clock before: Thu Jan 24 08:05:13 2019 0.000000 seconds
Hardware Clock after : Thu Jan 24 08:05:14 2019 0.000000 seconds
> Exit code: 0
Collected errors:
> Exit code: 255
>> 2019-01-24 08:06:45 +0000 (pid 7795) prepare-error-opkg-download-download 'opkg failed to download'
>> 2019-01-24 08:20:04 +0000 (pid 9080) upgrade-qb2.sh qb2 ene 4.10.6 prepare
>> 2019-01-24 08:20:04 +0000 (pid 9080) prepare
>> 2019-01-24 08:20:04 +0000 (pid 9080) preparing
Hardware Clock before: Thu Jan 24 08:20:04 2019 0.000000 seconds
Hardware Clock after : Thu Jan 24 08:20:04 2019 0.000000 seconds
> Exit code: 0
Collected errors:
> Exit code: 255
>> 2019-01-24 08:21:50 +0000 (pid 9080) prepare-error-opkg-download-download 'opkg failed to download'
