why power Toon with 24v since 24v is only a standard for HVAC?
Dunno, 24V is an industry standard level for signaling. We weren't around when toon was first designed, it might be that the original plan was to control the boiler directly from toon, drawing power from the boiler, as most thermostats do, without the module in between.
I am not sure whether it's ok to say something about something that took place somewhere someplace
I don't see how that could be of interest to the domoticaforum visitors at large.
As for the serial dump, I will check your script and try if I can get something out of it. Keep you posted!
It's not really serial, it's just generating output from the boiler controller code. Quby made their interfacing software quite verbose, which is good, and quite nifty for debugging. In the production code, all output is suppressed (redirected to /dev/null), by switching the redirection off, you can actually see what's going on.
grtz,
