Toon App: Water
Pieterraxis
Re: Toon App: Water
Post by Pieterraxis »
The Ali product is on longer able to be shipped to the Netherlands
https://nl.aliexpress.com/item/4000037046508.html
I'm not 100% sure which other one is exactly the same. I don't want to wait 3 weeks and after that wait again for 3 weeks :-)
Could somebody check the best replacement on Ali?
Thanks for your project oempie
oepi-loepi
Re: Toon App: Water
Post by oepi-loepi »
Just search for wemos d1 mini.
Do NOT buy a pro or something. Just the standard.
htca
Re: Toon App: Water
Post by htca »
HA 2022.11 allows to to add the watermeter to the energy configuration. If you use this watermeter of oepi-loepi, adjust your configuration.yaml:
- platform: rest
resource: http://192.168.1.10/water.html
value_template: "{{ value_json.waterquantity | float / 1000 }}"
unit_of_measurement: "m³"
device_class: water
icon: mdi:pulse
state_class: total_increasing
And solve the problems in "statistics" (if applicable)
oepi-loepi
Re: Toon App: Water
Also the commercial toonWater (see toonwater.nl) has been updated. It also supports the new energy dashboard from the MQTT discovery.
Mooby83
Re: Toon App: Water
Post by Mooby83 »
I'm using the commercial toonWater for about a month, and in general am very happy with it. Setup was easy and integrating into Home Assistant through mqtt works well and stable.
However, sometimes the sensor has a strange hickup and my meter readings are off by 10s or sometimes 100+ liter. Looking into the waterflow history in Home Assistant, I notice that the sensor reports a flow of more than 30 L a minute, sometimes even 50+ L a minute and during that period the meter readings are increasing abnormally. In reality, my waterflow is always less than 20 liters a minute.
Could this be a software or hardware issue?
oepi-loepi
Re: Toon App: Water
This is hardware. The sensor is above a point of the metal on your meter and the meter or sensor is vibrating causing jitter.
Fix the sensor to meter better to reduce vibration and set the damping to 2000 and pulselength to 700. Therse two filters will help reduce jitter
Mooby83
Re: Toon App: Water
Post by Mooby83 »
Thanks, have set them both to your suggested value and will keep an eye on the readings.
Mooby83
Re: Toon App: Water
Post by Mooby83 »
Just had another overshoot of 10l.
Should I increase the values?
oepi-loepi
Re: Toon App: Water
Ye, set pulselength to 750. Please also contact me by mail or by marktplaats app. Better than by this forum.
oepi-loepi
Re: Toon App: Water
New free software release! Only for the free versions (Wemos D1 mini). This version will be the new standard for future releases and i will phase out the first releases.
You can download version 1.4.35 here: https://github.com/oepi-loepi/water_ESP ... 1_mini.bin
Flashing from the menu will not be possible. Update instructions:
[*]Reset the module to factory defaults.
[*]Connect the module to USB and start your favourite flashing utility
If the module will not start after flashing, flash the blank 4MB.bin file first : https://github.com/oepi-loepi/water_ESP ... nk_4MB.bin.
This version has most of the commercial improvements on stability and counter but is limited to beasic features. If you want the full features, please visit Marktplaats : https://www.marktplaats.nl/u/oepi-loepi/43013407/
Krisrock
Re: Toon App: Water
Post by Krisrock »
Thanks for the update!
good job!
rleunk
Re: Toon App: Water
Post by rleunk »
oepi-loepi wrote: Fri Dec 30, 2022 6:20 pm New free software release! Only for the free versions (Wemos D1 mini). This version will be the new standard for future releases and i will phase out the first releases.
Heey oepi-loepi
Thnx for the update, will give it a try, can you tell what the difference between basic and full features is? Installed a water meter with pulse contact recently when placing my water softener, so no need for a extra sensor.
But curious what full features means.
Thanks and keep up the good work!
oepi-loepi
Re: Toon App: Water
De gratis demo versie is beperkt in gebruik echter voldoende om te werken met toon. De volledige module heeft de volgende opties extra:
Ondersteuning bij installatie via de Marktplaats app
Resetknopje om de unit naar fabrieksinstellingen te zetten
Weergave van gebeurtenisen in de webpagina (tijdgerelateerd)
Weergave van daggrafiek in de webpagina (tijdgerelateerd)
Ondersteuning voor Homey
Ondersteuning voor Fibaro
Uitgebreidere informatie voor Home Assistant
MQTT auto discovery voor Home Assistant
Gebeurtenissen weergeven in Domoticz
Lekdetectie weergeven in Domoticz
Breukdetectie weergeven in Domoticz
Etc.
rleunk
Re: Toon App: Water
Post by rleunk »
oepi-loepi wrote: Mon Jan 02, 2023 1:36 pm De gratis demo versie is beperkt in gebruik echter voldoende om te werken met toon. De volledige module heeft de volgende opties extra:
Etc.
Thnx voor de uitleg, zal de nieuwe versie een op een verse D1 mini blazen.
Doerakker
Re: Toon App: Water
Post by Doerakker »
het blijft nog wat rommelig en onduidelijk imho. Zo is er op toonwater nou niet echt een gioed beeld te krijgen over welke versie nou eigenlijk te laatste is, wat precies de verschillen zijn tussen het een of het ander.
is het mogelijk hier eens de koppen serieus voor bij elkaar te steken en te zoeken naar een oplossing?
