Page 29 of 39
Posted: Fri May 19, 2017 10:22 am
by TerrorSource
Toonz wrote:
Thanks BrainHunt, works like a charm from my Raspberry. Opens a new world of opportunities
If you need any help, let me know
Got it working now, can use Siri on my iPhone to control the thermostat of Toon.
Can someone tell me why i get the "Ketelhulp" app in the tray?
Dont have a boiler connected to my Toon now but that wont cause the Tray icon/app to show up.
Also, i cannot disable some apps on my Toon.
Looks like i cannot hide/remove these from the menu, i already removed them from the AppsToLoad in Globals.qml:
Verkeer (traffic)
Weer (weather & weatherInt)
Ketelhulp
Rookmelder (smokeDetector)
Toon Support
Wat is nieuw
Wat is Toon
Posted: Fri May 19, 2017 12:31 pm
by marcelr
Verkeer (traffic)
Ketelhulp
Toon Support
Wat is nieuw
Wat is Toon
I think you switched them on in the main config file:
TerrorSource wrote:
2. "/HCBv2/config/config_happ_scsync.xml" i changed the following value's:
<EndDate>4102444799</EndDate>
<BoilerManagement activated="0">1</BoilerManagement>
<HeatDisplay>1</HeatDisplay>
<SolarDisplay>1</SolarDisplay>
<SolarActivated>1</SolarActivated>
<OtherProviderElec>1</OtherProviderElec>
<OtherProviderGas>1</OtherProviderGas>
<SME>1</SME>
<HeatWinner>1</HeatWinner>
<TelmiEnabled>1</TelmiEnabled>
<doSolarWhatsnew>1</doSolarWhatsnew>
Nothing changed as far as i can tell.
Posted: Fri May 19, 2017 12:42 pm
by TerrorSource
Verkeer (traffic)
Ketelhulp
Toon Support
Wat is nieuw
Wat is Toon
<SME>1</SME>
I've already changed it back to the defaults but apps remain in the home screen
<EndDate>2147483647</EndDate>
<Status>IN_SUPPLY</Status>
<ProductVariant>Toon</ProductVariant>
<activated>1</activated>
<wizardDone>1</wizardDone>
<SoftwareUpdates>1</SoftwareUpdates>
<BoilerManagement activated="0">0</BoilerManagement>
<ElectricityDisplay>1</ElectricityDisplay>
<GasDisplay>1</GasDisplay>
<HeatDisplay>0</HeatDisplay>
<SolarDisplay>0</SolarDisplay>
<SolarActivated>0</SolarActivated>
<SME>0</SME>
<HeatWinner>0</HeatWinner>
<ContentApps>1</ContentApps>
<TelmiEnabled>0</TelmiEnabled>
<mobileAccess>1</mobileAccess>
<supportEnabled>0</supportEnabled>
<supportEnabledStart>0</supportEnabledStart>
<researchEnabled>0</researchEnabled>
<doSolarWhatsnew>0</doSolarWhatsnew>
Posted: Tue Jun 06, 2017 9:42 pm
by dennis071nl
Hi guys,
One more question on HomeAssistant integration..
in HA i get some errors in y log, can't get it to work... Perhaps one of the HA users who can have a look?? I opened 10080 in iptables, but there seems to be a communication issue... although i'm not really a developer myself..! Any help appreciated!
2017-06-06 21:33:08 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform toon
Traceback (most recent call last):
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 155, in _async_setup_platform
entity_platform.schedule_add_entities, discovery_info
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
result = self.fn(*self.args, **self.kwargs)
File "/home/homeassistant/.homeassistant/custom_components/climate/toon.py", line 34, in setup_platform
config.get(CONF_PORT))])
File "/home/homeassistant/.homeassistant/custom_components/climate/toon.py", line 55, in __init__
self.update()
File "/home/homeassistant/.homeassistant/custom_components/climate/toon.py", line 79, in update
'/happ_thermstat?action=getThermostatInfo'))
File "/home/homeassistant/.homeassistant/custom_components/climate/toon.py", line 66, in do_api_request
return json.loads(req.text)
File "/usr/lib/python3.4/json/__init__.py", line 318, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
raise ValueError(errmsg("Expecting value", s, err.value)) from None
ValueError: Expecting value: line 1 column 1 (char 0)
Posted: Mon Jun 19, 2017 9:34 pm
by ericT
Hello all,
Today I've rooted my Toon (v. 4.3.20) without subscription successfully with help of the great manuals on this forum. Unfortunately, I can't get the subscriber apps (like z-wave control) to show up.
I've <activated>1</activated> in the config_happ_scsync.xml end set the <EndDate>. Is there something else I should do?
Posted: Wed Jun 21, 2017 5:42 pm
by marcelr
<ProductVariant>?
Posted: Thu Jun 22, 2017 11:07 am
by ericT
I think I made a mistake with the <EndDate>
It's working now
Posted: Tue Jul 11, 2017 10:04 pm
by DennisD
After successfully rooting a second toon i bought from mp, i am running into some weird problems. After the rooting procedure i started playing with some settings in the .xml files and suddenly my meteradapter didn't recognize my gasmeter anymore (displayed heatingmeter) But the gas tiles on the screen still gave the correct readouts. To fix this issue i tried to undo all the changes i made but without any result (didn't made a backup), so i thought well let's factory reset toon in order to get things working again. Well it fixed the problem that i don't see the heating meter anymore and the gasmeter is recognized. Only thing is the daily use says 0 while the graph says 1.1m3 also
http://xxx.xxx.xxx.xxx/hdrv_zwave?actio ... vices.json gives 110.00 at the CurrentGasQuantity. So i thought let's reinstall the meteradapter, but to my surprise i see that no energymeter is installed but only a repeater (which) i don't have. Tried to uninstall the repeater and install the energiemeter again, and after doing this succesfull the energiemeter is "not installed" and the repeater is. I do get my electricity readings just like normal. I probably screwed up something but i don't know what. Anybody any advice?
Posted: Fri Jul 14, 2017 2:26 pm
by marcelr
That's weird. I'm not sure if it has to do with the type and firmware of your meteradapter. Over the years, many types have been issued (at least, there are some six distinct firmware packages in toon's meteradapter firmware). So, maybe you happen to have an old one which is not supported too well anymore.
Posted: Fri Jul 14, 2017 9:50 pm
by DennisD
Well the gas readouts start working again, just had to have some patience I guess. But still the problem remains that the meteradapter is seen as a repeater. My guess is the meteradapter is an older type because it was already in this house when we bought it 2 years ago (bought a extra toon to root).
Posted: Sat Jul 15, 2017 9:19 pm
by DennisD
Perhaps a update will help , my toon is running 2.5.4. I see talks about a .sh to upgrade but i can't find it. Can somebody point me in the right direction?
Posted: Sat Jul 15, 2017 9:51 pm
by marcelr
Hmm, that's REALLY old school firmware. Are you sure it's not a typo, and that you actually have 3.5.4?
Posted: Sat Jul 15, 2017 10:16 pm
by DennisD
Nope 100% 2.5.4
Posted: Sat Jul 15, 2017 11:05 pm
by marcelr
Ouch! That's from way before we managed rooting this thing.
Can you check the contents of /HCBv2/tmp/opkg-cache?
.. and post that?
Posted: Sun Jul 16, 2017 8:26 am
by DennisD
The opkg-cache folder is empty. I changed the /etc/openvpn/vpn_port.conf to default in hopes to get updates, rebooted my toon and now my software version is 3.5.4, no notifications regarding updates.
