With DMX is there a constant signal over the cable, so lets say 0 0 0 0 0 is all channels off and 1 1 1 1 1 is a channel on 2 2 2 2 2 2 is a channel.
Decoder number 1 is off, but it sends constantly 0 0 0 0 0 0 0 0 0 0 0 0 0 0
I want to turn on controller 2, that is located in this case in the kitchen.
The controller nr 2 sends out 2 2 2 2 2 2 2
Here comes the but, because controller 1 is idle and sends out 0 0 0 0 0 0 0 and now suddenly controller 2 starts sending 2 2 2 2 2 2 , you can see what is going to happen - 0 2 0 2 0 2 0 2 0 2 0 and this will get the decoders confused since he does not know what to do with this type of signal.
This is what i have understood about the DMX and have been told about.
So please correct me if i am wrong !
Now what i am going to do is this, i am going to use a IR ( lichtsluis) i do not know the english word but i have used some and got a spare here that works without a reflector.
The range will be about 15 CM that he detects a movement like a hand that is getting closer to the switch.
When the lichtsluis response it powers the relay that is connected with the DMX signal wires of this controller
What happens is that the decoders only get a signal from controller 1 where the lichtsluis detects movement, so the problem of the 0 2 0 2 0 2 0 2 0 is solved.
Same with all the other controllers, the relay is activated at that time when you need it.
I am not totally sure if this will work ! but when my dmx equipment comes from my Chinese friends with the mail i can do some testing.
One other "problem" i can think off is if there is a button press at the same time then you have both signals again.
But i think i will solve this by using again a relay that cut's off the other controller relays, so when controller 1 is activated first then he shuts off the power that the relays feed from the other controllers.
And if this all works , i will try to find maybe another solution or probably make a nice pcb with this switching drawing on it.
If this all fail, then i have another solution and this will be with wired or wireless butons that i connect to a arduino input, or rfxom.
And these get connected to a event, If pressed, then light dmx ch 3 4 5 6 7.
If pressed twice, shut down dmx ch 3 4 5 6 7 and so on.
It will be allot of work to program everything and get it running but i actually must say that i can't wait especially to get it working correctly like i want.
If someone has a better idea , please say so , i am interested, i am all ears.
I actually have done some work also but saturday i had a surprise party from a friend of mine so i had to stop early.
This is the picture of the cables that come from downstairs mainly for the lights and some sensores and power
Busy closing the cable holders, the wires and tubes/hose that you see on top of these have to be removed but first i have to drain my heating system so i can remove them out of sight.
Everything that goes into the server rack
Cleaned up a little, when the covers are on it looks so much better instead of the spaghetti, it is still allot of work to get the wires in the holder nice and firm next to eachother.
Biggest mess is gone , only needs the covers to be placed on them, it is still allot of work to get the wires in and the wires out on the right places.
And i did some shopping, some more cabinets for the relays and fuses and some nice LED light spots.
Very nice one and real warm white color
Very small LED spot , amazing how much light comes off even when it is running at 12V and 10mA
Small animation of this LED on and off
Nice led for in a hallway on the ground or something
The usage of the LED above this image
This i like for in my garage, it gives allot of light but it is more white then 3000K
Still pretty bright in the dark but the camera's auto settings show it like it is not bright - notice the power usage on the background.
Also got very nice LED drivers that are maybe if the dmx part is not going to act like i want, another solution for my "problem".
Will make a movie about the options it has.
This is it for now, probably friday/saturday/sunday that i am going to work again in my house.
