Toon app: ToonBot
oepi-loepi
Re: Toon app: ToonBot
Post by oepi-loepi »
De_Bouwer
Post by De_Bouwer »
oepi-loepi wrote:so why not make it a webhook?
https://api.telegram.org/bot[BOT_API_KE ... SSAGE_TEXT]
This works, but still if i use this webhook, the toon bot is sending a message to me... and i'm not getting a responce from the toon.
Sorry i'm not a coder just a hobyist ^^
i'm using this webhookcode: https://api.telegram.org/botHere api key from the toon bot/sendMessage?chat_id=my own chat id &text=/example
Anyone that can tell me what is wrong :D
screenshot telegram
screenshot telegram
Schermafbeelding 2021-10-28 092127.jpg (87.99 KiB) Viewed 9457 times
glsf91
Post by glsf91 »
De_Bouwer wrote:Okay, I'm a lot further along :D
However, the tone bot does not accept commands from the ifttt bot, If I send a command from my own telegram it works.
Anyone have an idea? why the toon bot does not accept commands from the ifttt bot?
Does it show up on the screen of ToonBot ?
Otherwise send it to your own telegram and compare if it is only sending the command
glsf91
Post by glsf91 »
You are sending from the chatbot to your self. It should be the other way around. It should be in green, not in white.
edit: I think it will not possible to send a message with the api to a bot. (because a bot cannot send to another bot)
Dyamon
Post by Dyamon »
okay this system works really well :D ! I use it with my whole family.
Would like to express my ideas for this app. It is possible to make a separate keyboard on Telegram. maybe this is an idea for usability https://core.telegram.org/bots#keyboards
My boiler is open-therm controlled and sometimes goes into error. Is it possible to have a notification of boiler in error?
glsf91
Post by glsf91 »
Dyamon wrote:okay this system works really well :D ! I use it with my whole family.
There is something similar as the seperate keyboard. You can define commands by yourself and use them bij typing '/'. See first post.
For notification boiler error, I have to know where I can see there is an error. So if you know which url to use to request this.
Also make a photo of the screen when you see this error again.
BakkerNL
Post by BakkerNL »
Heb deze app vandaag geïnstalleerd omdat op afstand de Rooted toon 2 bedienen via de app en via de browser niet goed lukt omdat die geen contact krijgt met de toon alleen na een restart is het ongeveer een dag goed maar dan ineens krijgt die geen contact meer, maar ben er nu de hele dag al mee bezig geweest om het dan voor elkaar te krijgen om hem te kunnen bedienen via telegram maar ook dat is dus helaas geen succes. De status springt steeds binnen enkele seconden op "verversing uitgeschakeld" klik ik handmatig dan op verversen dan is het goed maar binnen enkele seconden springt de status weer op "verversing uitgeschakeld"
Hier iemand die er misschien iets meer verstand van heeft hier een oplossing voor ? ben zelf totaal nieuw met (rooted) toon dus als iemand zal kunnen helpen zal ik dat fijn vinden.
Pochoto2
Post by Pochoto2 »
Thanks for the bot it works really well!
Is there any way to translate it to english/spanish?
