Too late: Important! Upgrade to 5.49.16 ASAP for rooted and subscription Toons!
Re: Too late: Important! Upgrade to 5.49.16 ASAP for rooted and subscription Toons!
Post by TheHogNL »
Xavier wrote: Fri Apr 22, 2022 10:00 am
So 1 questions:
How can I upgrade to 5.49.16?
I don't dare to try to upgrade my Toon2 at this moment.
I a missing the first part of the tsc update log. It should report that the certificates are updated because in the second try it shows that the certificates are already ok.
And still in the second attempt the VPN still doesn't work.
Please try to start the vpn manually (ctrl-c to abort) and paste the logs
/usr/sbin/openvpn --config /etc/openvpn/vpn.conf
Xavier
Post by Xavier »
TheHogNL wrote: Fri Apr 22, 2022 12:27 pm
So 1 questions:
Result:
Fri Apr 22 12:15:29 2022 OpenVPN 2.3.11 arm-hae-linux-gnueabi [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Nov 30 2016
Fri Apr 22 12:15:29 2022 library versions: OpenSSL 1.0.2h  3 May 2016, LZO 1.08
Fri Apr 22 12:15:30 2022 WARNING: file '/etc/openvpn/vpn/eneco-001-025058.key' is group or others accessible
Fri Apr 22 12:15:30 2022 WARNING: file '/etc/openvpn/vpn/ta.key' is group or others accessible
Fri Apr 22 12:15:30 2022 Control Channel Authentication: using '/etc/openvpn/vpn/ta.key' as a OpenVPN static key file
Fri Apr 22 12:15:30 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
Fri Apr 22 12:15:35 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby com: Name or service not known
Fri Apr 22 12:15:40 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
Fri Apr 22 12:15:45 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
Fri Apr 22 12:15:50 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
Fri Apr 22 12:15:55 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
Fri Apr 22 12:16:00 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
Fri Apr 22 12:16:05 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
Fri Apr 22 12:16:10 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
Fri Apr 22 12:16:15 2022 RESOLVE: Cannot resolve host address: vpn.qutility.quby.com: Name or service not known
^CFri Apr 22 12:16:15 2022 RESOLVE: signal received during DNS resolution attempt
Fri Apr 22 12:16:15 2022 SIGINT[hard,init_instance] received, process exiting
Post by TheHogNL »
You have same issue as here: viewtopic.php?t=13579
Using the wrong tenant (qutility, a Quby/Eneco old test tenant which isn't working anymore).
You need to switch to the eneco-nl tenant.
Xavier
Post by Xavier »
Thanks for the info, I got it fixed.
Tenant is now eneco.
Upgraded to 5.49.16
RvE
Post by RvE »
I get this error when trying to update:
Version: 4.74  - TheHogNL - 25-04-2022
Only start VPN and then quit
This toon contains old VPN certificates. Need to request new certificates!
We are on a Toon 1 so we need to request new certificates before being able to create a VPN connection...
New VPN certificate request created and now sending the request to Eneco...
403Failed to request and update the VPN certificates!
403 seems like a Forbidden error but I don't know what and how and why.
Post by TheHogNL »
Probably you vpn key was already invalidated before for some other reason.
But no need to update your toon1. Nothing new for it :)
RvE
Post by RvE »
TheHogNL wrote: Sat Aug 13, 2022 4:27 pm
Good to know. What about future updates? Or is my Toon too old for anything new?
I wanted to update because I had a problem with an app and maybe, an update could fix it.
But the problem with the app was between the chair and the keyboard :lol: :lol: :lol:
RvE wrote: Sun Aug 14, 2022 2:29 pm
No issue with staying on your current firmware if you ask me.
Looks like the development efforts at Eneco have been reduced to just the minimal bug fixing and technical moves to AWS.
There hasn't been a significant feature update for a long time on Toon.
(Even all the extra hardware sensors on the Toon 2 are still not used by the firmware)
libbkmz
Post by libbkmz »
Hello! In my house, I found a Toon thermostat. However, it isn't activated and I don't how long it was without the internet, probably more than 1 year. So, I stuck on the "Installatie Wizard." I can't activate my device because the VPN certificate is expired, and there is no "Activate" button.
So, my question is - can I make a hardware root for it? Generate a new certificate via "update-rooted.sh -c"? And is it possible to use that device with original paid subscription from Eneco?
Return to “Toon Rooting”
