miele@home
larsbeoel
Re: miele@home
Post by larsbeoel »
Hallo Erik,
Do you have the Fibaro files / LUA code for me? I want to conncet my Miele@Home washing machine to the Fibaro Home Center 2.
Thanks in advance!
Snelvuur
Re: miele@home
Post by Snelvuur »
I had to start over once, but didn't find the time to fine tune them.. but i still have the things i worked on before. Perhaps you can improve them, since they would stop working after a xx period of time was my findings..
Just make sure you have the same gw, otherwise it won't work. The new Miele works with other stuff then over power to communicate.
fibaro.zip
(5.75 KiB) Downloaded 837 times
miele icoontjes.zip
(167.58 KiB) Downloaded 763 times
hightech
Re: miele@home
Post by hightech »
Can some one give me a hint to how to upgrade XGW2000 to the new firmware, i have downloaded the Java script files but it stops with the "FTP server" configuration.
Have tryed running it on windows 7 and unbuntu 16.04 but no luck.
What version of Linux have you used to running the script, and do i need special version of java etc. installaed
Any help is welcome
Br.
Carsten
