Page 4 of 4
Re: ELV Max! Radio Signal Protocol 868.3MHz
Posted: Thu Oct 31, 2013 12:05 pm
by matthijskooijman
Copying the README would be fine, AFAICS you have then fulfilled the only condition in the MIT license, which is to include the license notice in all "copies or substantial portions" of the software.
Alternatively, I hereby give you permission to redistribute my RF22-related source files under the Apache 2.0 license or any other license you see fit, under the sole condition that you at least indicate my copyright somewhere in your project (a simple notice "based on work by Matthijs Kooijman <
matthijs@stdin.nl>" is also fine!).
Posted: Thu Oct 31, 2013 1:46 pm
by firefox0815
ok thank you,
i think this is a good solution without to much effort and i hope the result is usefull for someone out there.
Posted: Sun Jan 26, 2014 12:55 pm
by mike7
I want to implement solution based on RF22, but there are 2 versions - 433 & 868 MHz. Is it possible to use 433 MHz version to handle MAX! messages on 868.3 MHz? It's not clear for me from datasheet and library description.
Posted: Wed Feb 26, 2014 8:38 pm
by delboy711
Mike
The 433MHz module has a hardware band pass filter so although the software is identical to the 868MHz version, it will not work for you.
Posted: Wed Feb 26, 2014 8:43 pm
by delboy711
firefox0815 wrote:ok thank you,
It certainly is useful. Thanks very much to yourself and matthijskooijman for the excellent work.
I have one question. Using your code I have put together an Arduino script to comminicate with eq-3 max thermostats, but I do not have a cube or wall thermostat so I cannot listen in to the protocol when they pair with the thermostat.
Does someone know what the format of the pair command is?
I have tried looking in the fhem code to find it without success so far.
Thanks
Posted: Sat Mar 15, 2014 10:54 am
by firefox0815
have a look inside the message package. the protocol is complete for basics like connecting setting weekproflies valve states and of course read and write temperature modes.
have fun
