Toon firmware - update script
PeJeWe
Post by PeJeWe »
Which version do you want to upgrade to?
5.5.7
Alright, I will try to upgrade to 5.5.7
./update-rooted.sh: line 898: /usr/sbin/openvpn: not found
Could not enable VPN in a normal reasonable time!
DEBUG information:
192.168.***.***/24 dev wlan0 scope link src 192.168.***.***
default via 192.168.***.*** dev wlan0 metric 10
# <persistent /etc/hosts content can be added to /etc/hosts.template file>
127.0.0.1 localhost.localdomain localhost eneco-001-******
127.0.0.1 feed.hae.int feed
127.0.0.1 ping.quby.nl
END DEBUG information
killall: openvpn: no process killed
it looks like my vpn is gone??
You can always check if it's there:
which openvpn
But by the looks of it, it has left the building ...
What FW version are you using now?
PeJeWe
Post by PeJeWe »
marcelr wrote:You can always check if it's there:
which openvpn
i get no reaction with: which openvpn
I have 5.2.11 installed
can i reinstall openvpn?
mAiden
Post by mAiden »
Who root you're Toon? If it was Quby, they remove you're VPN.
PeJeWe
Post by PeJeWe »
mAiden wrote:Who root you're Toon? If it was Quby, they remove you're VPN.
I have rooted nu toon.
And i think that i have removed openvpn.
opgk remove openvpn
Most of the directorys are stil there.
How can i reinstall openvpn
Post by TheHogNL »
Why did you remove it yourself?
Here
openvpn_2.3.11-r1_qb2.zip
(243.44 KiB) Downloaded 365 times
the latest ipk for openvpn for the toon 1 (qb2). You can install it with opkg install filename
PeJeWe
Post by PeJeWe »
TheHogNL wrote:Why did you remove it yourself?
I thought I did not need to use it.
Post by TheHogNL »
I hope you didn't remove the files in /etc/openvpn which contain your VPN private key's. Without it it is impossible to connect the VPN to Eneco from your Toon.
PeJeWe
Post by PeJeWe »
i did not remove them
PeJeWe
Post by PeJeWe »
I have succefully installed openvpn but now i get the next error:
5.5.7
DEBUG information:
192.168.1.0/24 dev wlan0 scope link  src 192.168.***.***
172.22.64.0/20 dev tap0 scope link  src 172.22.67.88
172.22.64.0/20 via 172.22.64.1 dev tap0  metric 1024
# <persistent /etc/hosts content from /etc/hosts.template file>
172.30.80.1             feed.hae.int            feed
# </persistent /etc/hosts content from /etc/hosts.template file>
172.22.64.1             feed.hae.int            feed
Post by TheHogNL »
Please remove all lines containing feed.hae.int in /etc/hosts (and /etc/hosts.template if that exists).
PeJeWe
Post by PeJeWe »
TheHogNL wrote:Please remove all lines containing feed.hae.int in /etc/hosts (and /etc/hosts.template if that exists).
edit:
after a reboot, i ran the firmware update succefully :D
Post by TheHogNL »
Ok try to enter "127.0.0.1 feed.hae.int" into your hosts file.
somehow your VPN isn't modifying this hosts file entry when the VPN is started.
You could also just manually start the VPN and fill in the host entry your self (the subnet route into the VPN and then feed.hae.int should point to the .1 address).
FunFair
Post by FunFair »
I am trying to update to 5.5.7. First used TSC but it failed. Checked the log and getting this message.
After tunning the latest update script manually I get the same result.
Is it safe to continue?
5.5.7
Warning: upgrade script from Eneco server is changed. Do you want to continue downloading the files (if not sure, type no and report in the forums)?
Haven't seen this message before? Coming from firmware 5.2.11
Post by TheHogNL »
Ah ok Eneco changed their scripts again. Just checked and it is ok. I updated the update-rooted script to allow this (version 3.86 just published).
Return to “Toon Firmware”
