Not sure what you mean.
The rooting manual lists the files that require editing for getting in (you already did that). All the rest is up to you. in /HCBv2/qml/apps/ you can edit whatever you like, although some edits may be more useful than others.
michel30
Post by michel30 »
Ah okay I see :-) thanks for your information.
michel30
Post by michel30 »
I was playing a bit with VNC and restarting the Toon.
What I notes is as follow:
1: Restart on the Toon will not connect with VNC.
2: Restart in VNC will connect automatic back in VNC.
When I restart the Toon in the menu and login with SSH and check if VNC is running than I see it is running and can also login with VNC.
It looks like that VNC is disconnect the ports after restart but when you do a restart in VNC than the login works.
michel30
Post by michel30 »
Hello All,
The numbers are too high see screenshot
is there a place where you can customise this?
Can you also customise temperature for example 21,2 or 21,3 now you see always 21,5 or 22,0 or 21,0 or 20,5.
michel30 wrote:Hello All,
This is a bug in the latest firmware (also discussed on the Eneco Toon forum).
you can customise the temperature display in the Thermostat App (I believe posted earlier on this forum)
michel30
Post by michel30 »
I installed on my Synology NAS the following app: Domoticz home automation system.
In this app is an option add Toon thermostat but you need to fill in the user name and password from Eneco so you need a subscription.
Is it possible to connect the rooted Toon without any subscription? so you can control the Toon also with this app ?
I could not find anything on the web about this.
Thanks,
Michel
michel30
Post by michel30 »
I fixed my problem with:
How:
in the folder ' /HCBv2/qml/apps/thermostat', you will find the file ' ThermostatApp.qml'
In the file 'thermostatSidePanel.qml', the right side of the homescreen is drawn, including the current temperature, the buttons to increase/decrease the temperature and showing and selecting the current temp program. At line 58 I found the following code:
 currentTemperature = app.thermInfo['currentDisplayTemp'] / 100.0;
Change the line in:
 currentTemperature = app.thermInfo['currentTemp'] / 100.0;
The current temperature in house will also 21.1 or 21.2 etc and the number 18 will also show normal in line.
walberg
Post by walberg »
How do i open port 7080 in iptables.conf?
This is my iptables.conf
*nat
:PREROUTING ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
COMMIT
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:HCB-INPUT - [0:0]
-A INPUT -j HCB-INPUT
-A FORWARD -j HCB-INPUT
-A HCB-INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
# These are all closed for Quby/Toon:
-A HCB-INPUT -p tcp -m tcp --dport 5900 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 22 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 80 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 10080 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
#-A HCB-INPUT -p udp -m udp --sport 67:68 --dport 67:68 -j ACCEPT
#-A HCB-INPUT -p udp -m udp --dport 137:138 -j ACCEPT
-A HCB-INPUT -i lo -j ACCEPT
-A HCB-INPUT -i tap+ -j ACCEPT
-A HCB-INPUT -i tun+ -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --tcp-flags SYN,RST,ACK SYN -j DROP
-A HCB-INPUT -p udp -m udp -j DROP
COMMIT
Copy this line:
to make it look like this
-A HCB-INPUT -p tcp -m tcp --dport 7080 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
then execute
/etc/init.d/iptables restart
walberg
Post by walberg »
Thanks.
And /etc/init.d/iptables restart is a lot quicker than reboot.
Nelus82
Post by Nelus82 »
Thank you for the great manuals! I rooted my second hand Toon without any big problems.
Only a small problemen, after editing InternetSettingsAp.qml I stille get the warning in the gui. I cant supress it.
* already found it on the forum!
How do i add zwave to the toon, cant find it in the menu. Do i have to install the package manually?
ronalddehaan
Post by ronalddehaan »
al_n wrote:Just a little toon UI hack to hide the annoying error notification when you are not connected to eneco.
In the file /HCBv2/qml/apps/internetSettings/InternetSettingsApp.qml after line 369:
smStatus = parseInt(statemachine);
add the following
if(smStatus == _ST_INTERNET) {
    smStatus = _ST_TUNNEL;
Somehow the code in my InternetSettingsApp.qml file is different, can someone help me with the proper code for my file? :roll:
michel30
Post by michel30 »
You don't need to do that, see Notifications bar toppic what you want to do is old.
ronalddehaan
michel30 wrote:You don't need to do that, see Notifications bar toppic what you want to do is old.
ah thanks, didn't know it was already outdated. I'll have a look.
Return to “Toon Rooting”
