I was wondering if there is some complete list of local web methods and arguments that the Toon can handle. If not, i would like to help build this documentation.
When using 'strings -f hdrv_p1', i get so much garble, i don't know what to look for.
By decompiling (using https://retdec.com/) i found some web_ prefixed functions, but can't figure out the argument names.
Some posts back, some where talking about these web handlers and mentioned the BoxTalk Hub ('the heart of the system') that can be accessed by:
telnet localhost:1337
But i don't know how to use it. What commands are available?
Hey guys!
Lurking for a while now, and since about two weeks the proud owner of a rooted toon! Unfortunately I am running into a challenge: the electricity usage I receive from my P1 adapter is somehow only returning values for the daytime tariffs. As soon as the clock strikes 23:00, my electricity goes down to 0 Watt, only to get back to a real value on 7:00 the next morning. In weekends the reading is 0 Watt as well.
With http://<toon-ip>:10080/hdrv_zwave?action=getDevices.json I get a nice overview of all the adapters and their names & values. In my Toon, device 5.3 with name "elec_delivered_nt" is the only one with a value (between 7:00 - 23:00). Another one, dev 5.5 or elec_delivered_lt is at NaN all the time.
I already talked to @TerrorSource and he even remotely checked my Toon, but no luck: we have no idea what could be causing this.
Anybody seen this issue before, or does anyone perhaps have a pointer where to look?
Just to rule out some issue's does the Toon display the correct value at the display? If so, the P1 sensor is allright. If not, it might be some firmware issue on the P1 sensor.
What software version is your Toon?
I have a question, i turned on the solar panel option but i don't have connected solar panels so i want to remove the solar option form the menu but i can't remember were i turned it on, can someone put me in the right direction?
remove/disable from the Globals.qml file probablygielie wrote:I have a question, i turned on the solar panel option but i don't have connected solar panels so i want to remove the solar option form the menu but i can't remember were i turned it on, can someone put me in the right direction?
Hi,gielie wrote:I have a question, i turned on the solar panel option but i don't have connected solar panels so i want to remove the solar option form the menu but i can't remember were i turned it on, can someone put me in the right direction?
you can disable this in the config_happ_scsync.xml.
lsiepel wrote:I was wondering if there is some complete list of local web methods and arguments that the Toon can handle. If not, i would like to help build this documentation.
string -f <binary> |grep web > webhandlers.txt
The specific bxt code to send using the bxt client can be found using strace. All the logic still works for updating the webhandler ThermstatInfo.
Only the values aren't poulated. Dumping the output now to see what changed (If possible).
The readings I get from 7:00 - 23:00 seem perfectly normal (as in: expected values - high when my coffee maker is on, low when the kids are off to school and the home is powered down more or less). What seems strange is that I expected that at 23:00 one zwave device would stop sending data and the other one would take over.lsiepel wrote:Just to rule out some issue's does the Toon display the correct value at the display? If so, the P1 sensor is allright. If not, it might be some firmware issue on the P1 sensor. What software version is your Toon?
An example of the data I get from my Toon before and after 7:00:
06:25:01am Flow Quantity
Dev 5.1 - gas 0.00 3735858.00
Dev 5.2 - elec NaN NaN
Dev 5.3 - elec_delivered_nt 0.00 6286255.00
Dev 5.4 - elec_received_nt NaN NaN
Dev 5.5 - elec_delivered_lt NaN NaN
Dev 5.6 - elec_received_lt NaN NaN
06:40:02am Flow Quantity
06:55:01am Flow Quantity
07:10:01am Flow Quantity
Dev 5.1 - gas 693.00 3736551.00
Dev 5.3 - elec_delivered_nt 329.00 6286297.00
My Toon is running the latest software - version 4.8
EDIT - Nov 14.
I think I have resolved the issue. I reset the P1 adapter to factory defaults. First removed it from Toon, then placed the P1 adapter in a socket nearby. Pressed the button on the side for at least 10 seconds and reconnected it to Toon. By adding it, Toon changed the device-number in Zwave, but I have data now...
What I got in the past:
09:10:01am Flow Quantity
Dev 5.1 - gas 664.00 3737455.00
Dev 5.3 - elec_delivered_nt 313.00 6288930.00
11:06:14am Flow Quantity
Dev 6.1 - gas 144.00 3832635.00
Dev 6.2 - elec NaN NaN
Dev 6.3 - elec_delivered_nt 477.00 6386978.00
Dev 6.4 - elec_received_nt 0.00 0.00
Dev 6.5 - elec_delivered_lt 0.00 4826769.00
Dev 6.6 - elec_received_lt 0.00 0.00
I cried victory too soon...
The elec_delivered_lt reading remains 0.00 Watt, no change after 23:00. After the reset I got an initial value but no electricity usage showed during the night. This leads me to believe that the P1 adapter is 'broken', at least software wise. Will see what to do about it, since finding one on Marktplaats is not that easy (they usually come with a Toon - I already got one of those
). Alternatively I could subscribe to Eneco's service again and request a replacement...
Is there a way to push or pull elec&gas to Domoticz?
Hello all,
The whole idea of rooting was that interesting for me, that i decided to buy an extra toon via marktplaats.
That thing is succesfully rooted now, and connected for testing first. Thanks for everyone's good manuals and downloads!.
At this moment, my primary (not rooted) Toon is measuring the P1 slimme meter data.
My Domoticz raspberry is pulling those readings from the service centers from Eneco to login via some sort of toonopafstand website.
I'm planning to quit my subscription with Eneco toon and the service from the service centers, because i don't need that anymore with all the functions of my rooted toon.
Is there a way to push or pull the P1 meter readings from the rooted toon to my Domoticz raspberry, without a subscription to the eneco service centers?.
I really like the graphs that Domoticz is capable of showing.
Thank you for further help.
Jos.
Jos.
Does the module heeft the most recent firmware? (diffent than Toon itself)Henk-JanS wrote:I cried victory too soon...
The elec_delivered_lt reading remains 0.00 Watt, no change after 23:00. After the reset I got an initial value but no electricity usage showed during the night. This leads me to believe that the P1 adapter is 'broken', at least software wise. Will see what to do about it, since finding one on Marktplaats is not that easy (they usually come with a Toon - I already got one of those). Alternatively I could subscribe to Eneco's service again and request a replacement...
TerrorSource wrote:If you need any help, let me knowToonz wrote:Thanks BrainHunt, works like a charm from my Raspberry. Opens a new world of opportunitiesBrainHunt wrote:Hi TerrorSource,
For linking the hacked Toon with your Domoticz server, take a look at https://www.domoticz.com/forum/viewtopic.php?t=11421. This allows you to control the temperature and Toon scenes etc. through Domoticz.
BrainHuntGot it working now, can use Siri on my iPhone to control the thermostat of Toon.
Can someone tell me why i get the "Ketelhulp" app in the tray?
Dont have a boiler connected to my Toon now but that wont cause the Tray icon/app to show up.
Also, i cannot disable some apps on my Toon.
Looks like i cannot hide/remove these from the menu, i already removed them from the AppsToLoad in Globals.qml:
Verkeer (traffic)
Weer (weather & weatherInt)
Ketelhulp
Rookmelder (smokeDetector)
Toon Support
Wat is nieuw
Wat is Toon
Hello TerrorSource,
I have running Toon in Domoticz and I can use:
Toon Program Information
Toon Auto Program
Toon Scenes
Toon Temperature
Toon Thermostat
Now also installed apple homekit on my raspberry PI1 and connect in to Domoticz.
When I open my Iphone or Ipad I see he makes 2 light swith in homekit: Toon Auto Program and Toon Scenes ( but these are in domoticz push buttons ) and on the apple I can only slight.
I do not see Toon Temperature and Toon Thermostat when I say hey siri what is the temperature it says no device found.
Could you give me a small wiki how I connect the TOON in domoticz works but how from DOMOTICZ to apple homekit.
Thanks for your help.
- Administrator
I guess that you used the wrong IDX to connect in HomeBridge. You need to check these out. Did you check out the domoticzforum with this question yet?michel30 wrote:
Hello TerrorSource,
Toon Auto Program
Toon Scenes
Toon Temperature
Toon Thermostat
@TerrorSource
I could not find that part
the only thing what I did is: edit the config.json file
I Domoticz self I create a room the room has IDX2 so I add it as roomid2 plus I putt all my devices in that room.
But for my under standing, I need to edit config.json and putt there Toon Program Information with idx number and than Toon Auto Program with idx number - Toon Scenes Toon Temperature -Toon Thermostat etc.
In domoticz self everything works, it is only for in the homekit from apple and siri.
This how I install the connection to the Toon where you see the arrows that is type that I choose.
"bridge": {
"name": "Homebridge",
"username": "CC:22:3D:E3:CE:30",
"port": 51826,
"pin": "031-45-154"
"description": "This is an example configuration file with one fake accessory and one fake platform. You can use this as a template for creating your own configuration file containing devices you actually own.",
"accessories": [
"platforms": [
"platform" : "Domoticz",
"name" : "Domoticz",
"server" : "127.0.0.1",
"port" : "8080",
"roomid" : 2,
"loadscenes" : 0
- type.jpg (158.98 KiB) Viewed 14661 times
Hello Fellow Members!
I just read almost al the messages about Rooting and cosumizing Toon the last month. Just saw a bunch of posts about sending P1 meter data from Toon to domoticz (RPi).
Now my question about this, is it possible to send the data from the p1 smart meter cable in domoticz to toon. The reason i ask,
i am reading data from my smart meter for a while now, and like 2 keep it (history) and want to cancel the Toon meteradapter, do not have enough wallsockets at my "meterkast". I could buy some p1 splitter (an rj11 phone splitter doenst work, even with the 5v pin out), but it seems to be nice to have the "meteradapter" out of my setup.
Is it possible or is this a lot af work for a little electric use and power-history?
Greetings, Sjoek
Greetings, Sjoek
