Sending data to toon is easy.
Getting the data into the databases for display on toon is a totally different kettle of fish.
It will require some serious programming, to get all data averaged and plugged into the databases. But it's entirely possible.
Why would you even want to have the electric usage on the Toon? You already have it in domoticz now. You can remove all tiles regarding electric usage from Toon saving some memory for other apps.Sjoek wrote:Hello Fellow Members!
i am reading data from my smart meter for a while now, and like 2 keep it (history)
Is it possible or is this a lot af work for a little electric use and power-history?
If so, I would suggest to use the meteradapter (no idea if the electric usage is really a thing to consider) and then update your our domoticz P1 device from the data collected using the Toon output. You will keep your history but the P1 device is now updated using some scripting which collect them from Toon.
I know this is very old.al_n wrote:Can someone please repeat the following test;
Please go to http://10.10.10.7/hdrv_zwave?action=getDevices.json (use your toon's IP) and compare the results of CurrentGasQuantity with the daily gas usage on the toon's screen.
I get 6,83 m3 on the toon's screen and 669490.00 from the json reply and I don't understand why.
The electricity readouts are accurate.
on http://10.10.10.7:7080/happ_pwrusage?ac ... rrentUsage
I get only avgValue for gas of 298.10 which makes no sense either.
If anyone knows of another way to get the daily gas usage than I'll be happy to know.
I have the same problem. I have a analog gas meter (No P1-meter).
Hopefully there will be more knowledge available now how to read the (analog) gas consumption.
My value on the display now 6,66m3 and the json:
"dev_2.1":{"uuid":"169b26b1-0939-4f27-b6af-8d53ffed9fa6", "name":"HAE_METER_v2_1", "internalAddress":"2.1", "type":"gas", "supportsCrc":"0", "ccList":"3c 3d 3e 72 86", "supportedCC":"3c 3d 3e 72 86", "CurrentGasFlow":"0.00", "CurrentGasQuantity":"19870.00", "location":"(null)"},
How can I retrieve the gas consumption?
Edit: I made a mistake in understanding the gas meter. Next day it was working like expected. So it is now showing the same value in domoticz as on the Toon display.
i rewrote the gas_data_json.php & analog_electricity_data_json.phpglsf91 wrote:I know this is very old.al_n wrote:Can someone please repeat the following test;
Since the scripts i downloaded from the Forum didn't work for me.
I'm not a programmer; but this scripts works for me...
what it does.
1) It read the Domoticz value of Gas-Total-Value of the GasMeter.
2) It reads a Domoticz User-Variable "UV_LastToonGas" (integer type)
3) It reads the CurrentGasQuantity from toon.
New value to be sent to domoticz = (3) - (2) + (1)
Domoticz does the rest of the calculations.
everytime i sent a higher total-gas-value.
#!/usr/bin/php
<?php
/* Version 1.0 written by Ierlandfan */
/* Version 1.0 modified by DennisD */
/* Version 2.0 rewritten by FunFair */
/* Version 2.2 rewritten by Hypermobile */
/* 17-01-2018 */
/* Changelog Version 2.2
- Changed the way of calculating gas. by saving the last Value into a User-Variable: "UV_LastToonGas" (Interger) in Domoticz
- And checks whether the next Input is larger then the last input. to prevent getting wrong values in Domoticz like this one "18446744949882880"
Changelog Version 2.1
- Removed the compare to previous value, so it will update every minute.
Changelog Version 2.0:
- Rewrite from version 1.0
- Define IP adresses and idx value at start
- Check if Toon value is higher than Domoticz Value. (In case connection is lost with meteradapter, Toon will output wrong values)
/* Instructions:
- Place script in Domoticz folder /home/pi/domoticz/scripts/p1_meter/ or desired folder.
- Make sure Curl is installed (sudo apt-get install php-curl).
- Make sure script is executable (chmod +x filename.php).
- All echo's are used for debugging.
- Put script in 'crontab -e' to run every minute. */
#Example crontab: (*/1 * * * * /home/pi/domoticz/scripts/p1_meter/gas_data_json.php)
/* Set IP addresses and idx*/
$IPDomoticz = '192.168.x.x:8084';
$IPToon = '192.168.x.x';
$idx = 357;
$idx2 = 11; #UV_LastToonGas
/* read LastToonGasValue value from Domoticz */
$json_string = file_get_contents("http://$IPDomoticz/json.htm?type=command¶m=getuservariable&$idx2");
$parsed_json = json_decode($json_string, true);
$parsed_json = $parsed_json['result'][0];
$GasValueToonLast = $parsed_json['Value'] / 100;
echo "Gas Value UV_Domoticz = ";
echo $GasValueToonLast;
echo " liters";
echo "\n";
/* read Gasmeter value from Domoticz */
$json_string = file_get_contents("http://$IPDomoticz/json.htm?type=devices&rid=$idx");
$GasValueDomoticz = $parsed_json['Counter']*1000; #value Domoticz is in m3, convert to liters.
echo "Gas Value Domoticz = ";
echo $GasValueDomoticz;
echo " liters Totaal";
echo "\n";
/* http://$IPDomoticz/json.htm?type=command¶m=getuservariable&idx=11
/* read Gasmeter Value from Toon */
$file_string_gas = file_get_contents("http://$IPToon/hdrv_zwave?action=getDevices.json");
$parsed_json = json_decode($file_string_gas, true);
$GasValueToon= $parsed_json['dev_3.1']['CurrentGasQuantity']; #value Toon is in liters.
echo "Gas Value Toon = ";
echo $GasValueToon;
echo " liters";
echo "\n";
echo "\n";
/*write current value to last uv_parameter]*/
$GasValueToonNext = $GasValueToon * 100;
if ($GasValueToonNext > 10) {
$WriteVar = curl_init("http://$IPDomoticz/json.htm?type=command¶m=updateuservariable&vname=UV_LastToonGas&vtype=Integer&vvalue=$GasValueToonNext");
curl_exec($WriteVar);
if ($GasValueToon == $GasValueToonLast){
echo "geen gasverbruik \n";
if ($GasValueToon > $GasValueToonLast){
$GasValueToon = $GasValueDomoticz + $GasValueToon - $GasValueToonLast ;
echo $GasValueToon;
echo "GasValueToon Herschreven \n";
$WriteValue = curl_init("http://$IPDomoticz/json.htm?type=command¶m=udevice&idx=$idx&nvalue=0&svalue=$GasValueToon");
curl_exec($WriteValue);
yesterday my fuse blew ;Toon restarted. and got a wrong number in Domoticz.
I have something strange when I check this website: http://IP_TOON/hdrv_zwave?action=getDevices.json
The following is changed " dev_5.1: "
Before I had dev_2.3: And Domiticz was reading out.
After upgrade the software off Toon it want dev_3.1:
But today it is dev_5.2:
So domoticz is not reading out.
I did one small thing but I don't know is that is the case.
I remove the meter from Toon and reconnected back in Toon.
I have also an other strange thing?
On my Toon my GAS use at this moment is 0,86 m3 but when I check in domoticz my GAS use is 10.160 m3 that sounds better than 0,86
Where is TOON getting this display information from? domoticz is receiving every min the GAS information from TOON.
Als my electric use on TOON is lower than it shows before..
It looks like TOON gives the wrong information on the display..
dev_5.1: {
uuid: " ",
internalAddress: "5.1",
type: "gas",
supportsCrc: "0",
dev_5.2: {
uuid: " ",
internalAddress: "5.2",
type: "elec",
supportsCrc: "0",
If you have http://toon_ip/hdrv_zwave?action=getDevices.json and you see this:
CurrentGasFlow: "0.00",
CurrentGasQuantity: "15820.00",
Sud the CurrentGasFlow also filled in?
And when you check here: http://toon_ip/happ_pwrusage?action=GetCurrentUsage
sud this not filled in?
gasUsage:
value: 0,
dayCost: 0,
avgValue: 0
gasUsage:
value: 0,
dayCost: 0,
avgValue: 0
Maybe the MeterAdapter's firmware was updated and thus the device id has changed.
CurrentGasFlow is only non zero if you're actually using gas for i.e. heating or warm water right now.
{"result":"ok",
"powerUsage": {"value":xxxx, "dayCost":x.xx, "avgValue":xxx.xx},
"powerProduction": {"value":0, "dayCost":0.00, "avgValue":0.00},
"gasUsage": {"value":7976, "dayCost":103.37,"avgValue":272.56}
Ignore my values; my sensor is oriented the wrong way and that might be causing these high values.
It's cold outside, but not thát cold.
{"result":"ok",
Thanks for you information: I see information now.
result: "ok",
powerUsage: {value: 184,dayCost: 0.97,avgValue: 270.54},
powerProduction: {value: 0,dayCost: 0,avgValue: 93.67},
gasUsage: {value: 0,dayCost: 0,avgValue: 10.79}
Only one thing I don't understand is GAS using today at table display say 1,28 m3
When I check: http://IP_TOON/hdrv_zwave?action=getDevices.json I see that CurrentGasQuantity: is "26490.00", when I check in my domoticz GAS used: for today it say 10,280 it looks like that I miss a number on my Toon that is sued be 10.28 m3
There also a strange thing last month I had always around 15 - 20 kwh of electric but for some how is it now between 6 - 10 kwh when I check http://IP_TOON/hdrv_zwave?action=getDevices.json CurrentElectricityQuantity: "14769.00", it looks like this shows also wrong in the total of electric use.
Is there a way to fix this? I have toon software 4.10.6
result: "ok",
- Webp.net-resizeimage.jpg (30.61 KiB) Viewed 13538 times
/qmf/qml/themes for the loadscreens
/qmf/qml/images for the logo.png
- loadscreen_0.png (186.13 KiB) Viewed 13537 times
loadscreen_1
- loadscreen_1.png (127.67 KiB) Viewed 13535 times
- logo.png (2.76 KiB) Viewed 13535 times
CoolHypermobile wrote:loadscreen_1
What about the splash screen and "first dot" image after kernel boot?
Well it's a Animationmarcelr wrote:CoolHypermobile wrote:loadscreen_1![]()
1) Kernal-Original
2) Lightning Burst
3) complete Breakdown
My Workaround to keep the Kernal one and still have a nice intro
Didn't know how to get to that one too
i'm more a Image Guy rather then a Programmer Guy
