Controlling Toon via Domoticz
- Starting Member
Re: Controlling Toon via Domoticz
Hi madpatrick,
That last comment did it. Change lines 51 and 52 to 2. or 2: (in my case that is). I had a few other problems, but nothing where the logfile couldn't point me in the right direction. I now have both dzEvent scripts and no LUA scripts running for my Toon and I can see all the info coming in and change the temperature with my app / homekit setup.
Thanks for the great help! It sure helped me a lot.
Is there any way to add Toon poweradapters and lights in Domoticz?
- madpatrick
If they are z-wave compatible you can, but you to connect them to Domoticz and release from your ToonWickedMaster wrote:Is there any way to add Toon poweradapters and lights in Domoticz?
I managed to set the state (on/off) on a Z-Wave smartplug using hdrv_zwave?action=basicCommand&uuid=688b44c4-19d4-4453-8aa8-6b02ee9aa78f&state=1. This works, but when I have a look at the Toon itself, it still shows the old state. So, when I turn it off, the smartplug goes off, but Toon still shows it as active. What did I miss?madpatrick wrote:If they are z-wave compatible you can, but you to connect them to Domoticz and release from your ToonWickedMaster wrote:Is there any way to add Toon poweradapters and lights in Domoticz?
You miss nothing, Domoticz didn't sync with Toon.WickedMaster wrote:I managed to set the state (on/off) on a Z-Wave smartplug using hdrv_zwave?action=basicCommand&uuid=688b44c4-19d4-4453-8aa8-6b02ee9aa78f&state=1. This works, but when I have a look at the Toon itself, it still shows the old state. So, when I turn it off, the smartplug goes off, but Toon still shows it as active. What did I miss?madpatrick wrote:If they are z-wave compatible you can, but you to connect them to Domoticz and release from your ToonWickedMaster wrote:Is there any way to add Toon poweradapters and lights in Domoticz?
Will see if I have time to look at it this weekend, so that there will be sync.
- madpatrick
It's is easier to let Domoticz control your switches, but that is my opinion.
For your understandig: Domoticz is still seperate from this since we simply send the command from the webbrowser. The smartplug changes the state, but Toon just doesn't show the right state. The smartplug is by the way connected to the Toon (so not to another Z-Wave controller).mAiden wrote:You miss nothing, Domoticz didn't sync with Toon.
I agree, but I still didn't manage to show external Z-Wave plugs on the Toon itself. I would like to have the on-off option at the Toon's control panel (the easy access panel).madpatrick wrote:It's is easier to let Domoticz control your switches, but that is my opinion.
does somebody runs Domoticz with IFTTT?
When I say to google someting what I enter in IFTTT it says I don't now what you mean or I cannot find it please add it in google.
That should work. I've just tested it out, and you can simply make an applet with Google Assisant as "if". Then, for example, you can pick the "Say a simple phrase" trigger. Enter the texts there and create the trigger. After that you've to create the "that" action service which will be a web request (using Webhooks). There you can enter the URL which IFTTT has to execute and create the trigger (no need to modify the other settings such as method).michel30 wrote:Hello,
This worked for me.
I am trying first with my lights but it always says This isn't a valid URL.
http://<user>:<password>@<domoticz public IP or URL>:8080/json.htm?type=command¶m=switchlight&idx=181&switchcmd=Off
When I used this command in my webbrowser the light will switch off.
I also try this out with a hotspot and when I try it does not work.
How does your URL looks like for phrase?
And can I talk dutch with IFTTT? I only see couple of language , german, french , english..
Thanks,
Thanks,
I have only tested it out with the direct link of the Toon itself. Haven't tried it out with Domoticz yet. Will try that tomorrow and come back to it.
You can only talk the languages which are listed at IFTTT to it. I tried Dutch, but that doesn't seems like to work..
Okay, Toon is now working with IFTTT and domoticz is I say set temperature ... degrees is switch.
This how you set up the connection in IFTTT
I am searching how to set up when you ask google home what is the temperature in house that it will say at this moment the temperature is....
An other question: what could you do more with integrate Toon and Google home together with Domoticz and IFTTT?
https://user:password@IP:port/json.htm?type=command¶m=updateuservariable&vname=Status&vtype=2&vvalue={{TextField}}
Hello WickedMaster,WickedMaster wrote:I have only tested it out with the direct link of the Toon itself. Haven't tried it out with Domoticz yet. Will try that tomorrow and come back to it.
Did you already try the Toon with Domoticz and google home?
The only thing that works for me is only set the temperature on .. degrees but asking what is the temperature in the house it does not work yet.
BOverdevest wrote:Based on several posts, I combined getting all Toon data to Domoticz in a single DzVents script. So both boiler data, thermostat data and the P1 data.
Now that I have a rooted Toon2 I had to update the script, as the P1 data apparently changed in the http://<ToonIP>/hdrv_zwave?action=getDevices.json.
return { on = { timer = { 'every minute' } }, execute = function(domoticz) local ToonThermostat = domoticz.variables('UV_ToonThermostat').value -- Sensor showing current setpoint local ToonTemperature = domoticz.variables('UV_ToonTemperature').value -- Sensor showing current room temperature local ToonBoilerTempIn = domoticz.variables('UV_ToonBoilerTempIn').value -- Sensor showing water temp return local ToonBoilerTempOut = domoticz.variables('UV_ToonBoilerTempOut').value -- Sensor showing current water temp out local ToonBoilerPressure = domoticz.variables('UV_ToonBoilerPressure').value -- Sensor showing current room temperature local ToonBoilerModulation = domoticz.variables('UV_ToonBoilerModulation').value -- Sensor showing current Boiler Modulation local ToonScenes = domoticz.variables('UV_ToonScenes').value -- Sensor showing current program local ToonAutoProgram = domoticz.variables('UV_ToonAutoProgram').value -- Sensor showing current auto program status local ToonProgramInformation = domoticz.variables('UV_ToonProgramInformation').value -- Sensor showing displaying program information status local ToonIP = domoticz.variables('UV_ToonIP').value local DomoticzIP = domoticz.variables('UV_DomoticzIP').value local ToonBurnerName = domoticz.variables('UV_ToonBurnerName').value local P1SmartMeterPower = domoticz.variables('UV_P1SmartMeterElectra').value local P1SmartMeterGas1 = domoticz.variables('UV_P1SmartMeterGasMeterStand').value local ToonBoilerSetpoint = domoticz.variables('UV_ToonBoilerTempSetpoint').value -- Sensor showing current boiler set point water temp out -- Handle json local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP))) local ThermostatInfo = handle:read('*all') handle:close() local jsonThermostatInfo = json:decode(ThermostatInfo) if jsonThermostatInfo == nil then return end local handle2 = assert(io.popen(string.format('curl http://%s/boilerstatus/boilervalues.txt', ToonIP))) local BoilerInfo = handle2:read('*all') handle2:close() -- JSON data from Toon contains a extra "," which should not be there. BoilerInfo = string.gsub(BoilerInfo, ",}", "}") jsonBoilerInfo = json:decode(BoilerInfo) -- http://IP_TOON/hdrv_zwave?action=getDevices.json local handle4 = assert(io.popen(string.format('curl http://%s/hdrv_zwave?action=getDevices.json', ToonIP))) local GasPowerInfo = handle4:read('*all') handle4:close() -- JSON data from Toon contains a extra "." which should not be there. GasPowerInfo = string.gsub(GasPowerInfo, "dev_4.", "dev_4") GasPowerInfo = string.gsub(GasPowerInfo, "dev_4:", "dev_4\":") local jsonGasPower = json:decode(GasPowerInfo) -- domoticz.log(jsonGasPower) local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityFlow ) local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityQuantity) local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityFlow ) local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityQuantity) local CurrentGasFlow = tonumber(jsonGasPower.dev_41.CurrentGasFlow) local CurrentGasQuantity = tonumber(jsonGasPower.dev_41.CurrentGasQuantity) local CurrentElectricityQuantity = CurrentElectricityFlowHoog + CurrentElectricityFlowLaag local CurrentElectricityDeliveredLaag = 0 local CurrentElectricityDeliveredHoog = 0 local totalDeliveredPower = 0 domoticz.devices(P1SmartMeterPower).updateP1(CurrentElectricityQuantityLaag, CurrentElectricityQuantityHoog, CurrentElectricityDeliveredLaag, CurrentElectricityDeliveredHoog, CurrentElectricityQuantity, totalDeliveredPower).silent() domoticz.devices(P1SmartMeterGas1).updateGas(CurrentGasQuantity).silent() -- Update the Boiler Water In to current value local currentboilerInTemp = tonumber(jsonBoilerInfo.boilerInTemp) if domoticz.utils.round(domoticz.devices(ToonBoilerTempIn).temperature,0) ~= domoticz.utils.round(currentboilerInTemp,0) then -- domoticz.log('Updating Boiler Water In to current value: ' ..currentboilerInTemp) domoticz.devices(ToonBoilerTempIn).updateTemperature(currentboilerInTemp).silent() end -- Update the Boiler water Out to current value local currentboilerOutTemp = tonumber(jsonBoilerInfo.boilerOutTemp) if domoticz.utils.round(domoticz.devices(ToonBoilerTempOut).temperature,0) ~= domoticz.utils.round(currentboilerOutTemp,0) then -- domoticz.log('Updating Boiler Water Out to current value: ' ..currentboilerOutTemp) domoticz.devices(ToonBoilerTempOut).updateTemperature(currentboilerOutTemp).silent() end -- Update the Boiler water Pressure to current value local currentBoilerPressure = tonumber(jsonBoilerInfo.boilerPressure) * 10 if domoticz.utils.round(domoticz.devices(ToonBoilerPressure)._nValue,0) ~= domoticz.utils.round(currentBoilerPressure,0) then -- domoticz.log('Updating Boiler Pressure to current value: ' ..currentBoilerPressure) domoticz.devices(ToonBoilerPressure).updatePressure(currentBoilerPressure).silent() end local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100 local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100 local currentProgramState = tonumber(jsonThermostatInfo.programState) if currentProgramState == 0 then currentProgramState = 10 -- No elseif currentProgramState == 1 then currentProgramState = 20 -- Yes elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary end local currentActiveState = tonumber(jsonThermostatInfo.activeState) if currentActiveState == -1 then currentActiveState = 50 -- Manual elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort elseif currentActiveState == 1 then currentActiveState = 30 -- Home elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep elseif currentActiveState == 3 then currentActiveState = 10 -- Away end -- Update the toon burner selector to current program state local currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo) local CurrentToonBurnerValue = domoticz.devices(ToonBurnerName).level if currentBurnerInfo == 0 then currentBurnerInfo = 0 -- uit elseif currentBurnerInfo == 1 then currentBurnerInfo = 10 -- cv aan elseif currentBurnerInfo == 2 then currentBurnerInfo = 20 -- warmwater aan end if CurrentToonBurnerValue ~= currentBurnerInfo then -- Update toon burner selector if it has changed -- domoticz.log('Updating Toon burner info:') domoticz.devices(ToonBurnerName).switchSelector(currentBurnerInfo) end -- Update the modulation level of the burner local currentModulationLevel = tonumber(jsonThermostatInfo.currentModulationLevel) if domoticz.devices(ToonBoilerModulation).percentage + 1 ~= currentModulationLevel + 1 then -- domoticz.log('Updating the Modulation sensor to new value: ' ..currentModulationLevel) domoticz.devices(ToonBoilerModulation).updatePercentage(currentModulationLevel) end -- Update the temperature Boiler setpoint to current boiler set point local currentInternalBoilerSetpoint = jsonThermostatInfo.currentInternalBoilerSetpoint+1 if domoticz.utils.round(domoticz.devices(ToonBoilerSetpoint).temperature, 1) ~= domoticz.utils.round(currentInternalBoilerSetpoint, 1) then -- domoticz.log('Updating the Boiler internal temperature setpoint to new value: ' ..currentInternalBoilerSetpoint) domoticz.devices(ToonBoilerSetpoint).updateTemperature(currentInternalBoilerSetpoint) end -- Update the thermostat sensor to current setpoint if domoticz.devices(ToonThermostat).setPoint*100 ~= currentSetpoint*100 then -- domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint) domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent() end -- Update the temperature sensor to current room temperature if domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1) ~= domoticz.utils.round(currentTemperature, 1) then -- domoticz.log('Updating the temperature sensor to new value: ' ..currentTemperature) domoticz.devices(ToonTemperature).updateTemperature(currentTemperature) end -- Update the toon scene selector sensor to current program state if domoticz.devices(ToonScenes).level ~= currentActiveState then -- Update toon selector if it has changed -- domoticz.log('Updating Toon Scenes selector to: '..currentActiveState) domoticz.devices(ToonScenes).switchSelector(currentActiveState).silent() end -- Updates the toon auto program switch if domoticz.devices(ToonAutoProgram).level ~= currentProgramState then -- Update toon auto program selector if it has changed -- domoticz.log('Updating Toon Auto Program selector to: '..currentProgramState) domoticz.devices(ToonAutoProgram).switchSelector(currentProgramState).silent() end -- Updates the toon program information text box local currentNextTime = jsonThermostatInfo.nextTime local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100 if currentNextTime == 0 or currentNextSetPoint == 0 then ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°' else ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°' end if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then -- domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue) domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue) end end }
Are you sure "domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent()" is indeed silent?
In my Domoticz it is still triggering the ToonThermostat setpoint script. Looks like silent is not working. I'am on the recent stable version.
Just wondering, was the manual ever updated?TerrorSource wrote:You can contact me via PM or email so I can edit the modifications in the PDF filesmadpatrick wrote: Hello TerrorSource,
Is it possible to share the DOC-file.
I can update the manual for the DzVents script, update it and correct a few errors.
