Bwired Googlemaps upload data webservice
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by sooty</i>
<br />It looks like I found the answer, and yes it will.
I have used 19 kWh of power in less than 23 minutes [:(]
Paul..
LOL!! "Today Water 539 ltr". Damn is your waterpipe broken and is your house flooded ?
Paul..
Lorenzo,
If you copy the code (In purple colour) below to a file and re-name it ???.vb, then this should work for the lamp status. NOTE: the code is not tested, but should work OK.
You will need to add your other information where indicated. if you still have problems, then let me know the device codes and device types you want to add, and I will create the whole script for you.
Note the GetStatus function. This will return a text value based on the status of the device.
To add lamp 2 for example, you can add another Const lamp2 = "A3" and in the entry section call the GetStatus like this: GetStatus(lamp2)
Hope that makes sense.
Paul..
<font color="purple"></font id="purple">
Paul..
Imports System.IO
Imports System.Net
Imports System.Text
Sub Main(ByVal parms As Object)
Const url = "http://www.bwired.nl/Bwiredservice/receive.asp"
Const screenname = "YourScreenName" '<---REPLACE THIS WITH YOUR INFO
Const name = "YourName" '<---REPLACE THIS WITH YOUR INFO
Const passwd = "YourPassword" '<---REPLACE THIS WITH YOUR INFO
Const city = "YourCity" '<---REPLACE THIS WITH YOUR INFO
Const gpslat = "YourLat" '<---REPLACE THIS WITH YOUR INFO
Const gpslong = "YourLon" '<---REPLACE THIS WITH YOUR INFO
Const title = "YourTitle" '<---REPLACE THIS WITH YOUR INFO
Const temp = "??" '<---REPLACE ?? WITH YOUR HOMESEER TEMPERATURE DEVICE CODE
Const humid = "??" '<---REPLACE ?? WITH YOUR HOMESEER HUMIDITY DEVICE CODE
Const baro = "??" '<---REPLACE ?? WITH YOUR HOMESEER BAROMETER DEVICE CODE
Const lamp1 = "A2" '<---REPLACE ?? WITH YOUR HOMESEER LAMP 1 DEVICE CODE
Dim myXML
Dim xmlhttp
myXML = hs.CreateStringClass
myXML.Add("<?xml version=""1.0"" encoding=""UTF-8"" ?>")
myXML.Add("<BWired>")
myXML.Add("<Init>")
myXML.Add("<DateTime>" & Now() & "</DateTime>")
myXML.Add("<UserName>" & name & "</UserName>")
myXML.Add("<Password>" & passwd & "</Password>")
myXML.Add("<ScreenName>" & screenname & "</ScreenName>")
myXML.Add("<Gpslat>" & gpslat & "</Gpslat>")
myXML.Add("<Gpslong>" & gpslong & "</Gpslong>")
myXML.Add("<City>" & city & "</City>")
myXML.Add("<Website />")
myXML.Add("<WebCamPicUrl />")
myXML.Add("<Title>" & title & "</Title>")
myXML.Add("</Init>")
myXML.Add("<Entry>")
myXML.Add("<Name>Outside Temperature</Name>")
myXML.Add("<ID>1</ID>")
myXML.Add("<Units>C</Units>")
myXML.Add("<Value>" & CStr(hs.DeviceValue(temp) / 10).Replace(",", ".") & "</Value>")
myXML.Add("</Entry>")
myXML.Add("<Name>Outside Humidity</Name>")
myXML.Add("<ID>2</ID>")
myXML.Add("<Units>%</Units>")
myXML.Add("<Value>" & hs.DeviceValue(humid) & "</Value>")
myXML.Add("<Name>Barometer</Name>")
myXML.Add("<ID>3</ID>")
myXML.Add("<Units>hPa</Units>")
myXML.Add("<Value>" & CInt(hs.DeviceValue(baro) / 100) & "</Value>")
myXML.Add("<Name>Lamp 1</Name>")
myXML.Add("<ID>4</ID>")
myXML.Add("<Units></Units>")
myXML.Add("<Value>" & GetStatus(lamp1) & "</Value>")
myXML.Add("</BWired>")
xmlhttp = WebRequest.Create(url)
xmlhttp.Method = "POST"
Dim byteArray As Byte() = Encoding.UTF8.GetBytes(myXML.Value)
xmlhttp.ContentType = "text/xml"
xmlhttp.ContentLength = byteArray.Length
Dim dataStream As Stream = xmlhttp.GetRequestStream()
dataStream.Write(byteArray, 0, byteArray.Length)
dataStream.Close()
Dim response As WebResponse = xmlhttp.GetResponse()
response.Close()
myXML.Reset()
End Sub
Public Function GetStatus(ByVal devCode As String) As String
Dim strInpStatus As String
Dim strOutStatus As String
strInpStatus = hs.DeviceStatus(devCode)
Select Case strInpStatus
Case "2"
strOutStatus = "ON"
Case "3"
strOutStatus = "OFF"
Case "4"
strOutStatus = "DIM"
Case Else
strOutStatus = "UNKNOWN"
End Select
Return strOutStatus.ToString
End Function
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by mgizmo</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by sooty</i>
Paul..
I will let Pieter get all the grey hairs working out how he will sort out the time difference problems [:D]
Not so much of a problem with the small time difference between UK & NL local time, but it could be a problem with larger differences from other countries.
Paul..
Paul..
Paul..
Also, He needs to look into the decimal point i guess?
Only decimal points are supported at this time. For this reason I convert any commas to dots in my Homeseer script.
@Sooty , thank you! I will try later. I'll let you know.
@Sooty , i did that and i don't have any errors in log file. Let's hope. Now i'm waiting that my xml data are accepted and published on asp page. Pieter are you there?
Best regards boys.
Nothing coming in, when are you sending?
I should see some XML's coming in, but nothing!
Pieter i did a schedule , every 60 min. here's log of HS.
19/03/2009 12.22.05 Info Event Trigger "xml2bwired"
19/03/2009 12.22.05 Info Running script in background: xml2bwired.vb
19/03/2009 13.22.05 Info Event Trigger "xml2bwired"
19/03/2009 13.22.05 Info Running script in background: xml2bwired.vb
and so on...
this is my script
Imports System.IO
Imports System.Net
Imports System.Text
Sub Main(parms As Object)
const url = "http://www.bwired.nl/Bwiredservice/receive.asp"
const screenname="<Domotica_IT>"
const name="<xxxxx>"
const passwd="<xxxxxx>"
const city="<Dumenza>"
const gpslat="46.018781"
const gpslong="<8.787689>"
const title="<The Wolf's land>"
Const temp = "??"
Const humid = "??"
Const baro = "??"
Const lamp1 = "A2"
Dim myXML
Dim xmlhttp
myXML.Add("<Init>")
myXML.Add("<Name>Gate's lamp</Name>")
dataStream.Close()
response.Close()
myXML.Reset()
End Sub
Case "2"
strOutStatus = "ON"
Case "3"
Case "4"
Case Else
End Select
End Function
and so on...
this is my script
Imports System.IO
Imports System.Net
Imports System.Text
Const temp = "??"
Const humid = "??"
Const baro = "??"
Const lamp1 = "A2"
Dim myXML
Dim xmlhttp
myXML.Add("<Init>")
dataStream.Close()
response.Close()
myXML.Reset()
End Sub
Case "2"
strOutStatus = "ON"
Case "3"
Case "4"
Case Else
End Select
End Function
Lorenzo,
I would be surprised if this will run. Take the time to review the script once more!
An example: CInt(hs.DeviceValue(baro) / 100); what you're actually doing is CInt(hs.DeviceValue("??") / 100).
So, you have a device "??". I don't think so
Somewhere the script will throw an exception and stop executing there, so it's not reaching the end where the XML is actually sent.
@drmacchi: Add the following line to your script, just between the response.Close() and myXML.Reset() lines, to check whether the XML is created correctly:
hs.SendEmail(<your email address>,<your email address>,"test",myXML.Value)
Replace <your email address> with your email adres between "".
I did insert code for mail test. This is the mail that i receive:
<?xml version="1.0" encoding="UTF-8" ?><BWired><Init><DateTime>19/03/2009 18.08.22</DateTime><UserName><drmacchi></UserName><Password><43694369></Password><ScreenName><Domotica_IT></ScreenName><Gpslat>46.018781</Gpslat><Gpslong><8.787689></Gpslong><City><Dumenza></City><Website /><WebCamPicUrl /><Title><The Wolf's land></Title></Init><Entry><Name>Outside Temperature</Name><ID>1</ID><Units>C</Units><Value>0</Value></Entry><Entry><Name>Outside Humidity</Name><ID>2</ID><Units>%</Units><Value>0</Value></Entry><Entry><Name>Barometer</Name><ID>3</ID><Units>hPa</Units><Value>0</Value></Entry><Entry><Name>Gate's lamp</Name><ID>4</ID><Units></Units><Value>OFF</Value></Entry></BWired>
Ops, user and password will be changed immediatly!
Remove the "<" and ">" from your values.
So for instance <drmacchi> should be drmacchi,
<Domotica_IT> should be Domotica_IT, etc.
- Fantic
you mean like this?
<ScreenName>Domotica_IT</ScreenName>
Regards, Maarten.
Regards, Maarten.
