Page 42 of 44
Posted: Sat May 23, 2020 1:26 pm
by hmay
I have a never used Toon (from 2017) running software version 3.2.18. So the Toon has never been activated.
I was able to root it with the rooting script and I have SSH access.
I guess the next step is to update the firmware with the update script, but what is the right order?
Can I update to the latest version straight away or should I upgrade it with steps? And if so which steps should I take?
Thanks in advance!
Posted: Sat May 23, 2020 9:49 pm
by TerrorSource
hmay wrote:I have a never used Toon (from 2017) running software version 3.2.18. So the Toon has never been activated.
Thanks in advance!
Use the update script to update to 5.0.6, run fixed, reboot, update to 5.28.9, run fixed and reboot
Posted: Sun May 24, 2020 10:28 am
by TheHogNL
And in fact, the script won't let you update past 5.0.6 first. So just use the script and it will fix it for you.
Posted: Sun May 24, 2020 12:21 pm
by hmay
Brilliant and it worked without a problem.
Thank you very much!
Posted: Thu May 28, 2020 10:41 pm
by Stampre
I tried to update from 5.22.14 tot 5.28.9 but Toon dont want to. I tried on the toon and with the update script with -f.
The script runs and update all the programs but not the firmware. also after reboot firmware isnt updated. is there another way?
Posted: Thu May 28, 2020 10:50 pm
by TerrorSource
Stampre wrote:I tried to update from 5.22.14 tot 5.28.9 but Toon dont want to. I tried on the toon and with the update script with -f.
What model Toon? Did you check the upgrade logs?
Posted: Fri May 29, 2020 8:09 am
by mAiden
Try it with -v (ex: sh update-rooted.sh -v 5.28.9)
-f only fix files
Posted: Fri May 29, 2020 11:15 am
by TheHogNL
Or without any options where it asks to which version you want to update
Posted: Fri May 29, 2020 10:14 pm
by Stampre
Don't ask how but after a reboot and tsc its done right now.
Posted: Mon Jun 01, 2020 10:52 pm
by Vriesfde
I updated my Toon some days ago, used the approach mentioned some posts back as I was running a quite old version (upgrading in two steps)
All went well and enjoy the overall speed increase.
I noticed during upgrade cerain old apps were auto updated, great!
Today, 2 days after upgrade I noticed buienradar showed 11celsius..... it was more like 22 so I thought app frozen.
Removed it from toonstore to reinstall, it did indeed remove buienradar but after reboot the toonstore is completely blank.
Any suggestions what I should do now?
Greets,
Frans
Posted: Mon Jun 01, 2020 11:10 pm
by PeJeWe
Vriesfde wrote:I updated my Toon some days ago, used the approach mentioned some posts back as I was running a quite old version (upgrading in two steps)
Greets,
Frans
Run the script again with option - f
It only fixing things.
Posted: Mon Jun 01, 2020 11:14 pm
by Vriesfde
Thanks for the tip, I found I had poor troubleshooting skills.....
Could not ssh in, checked wifi connection on toon, it was discoonected.
Could not connect to the ssid I always used for the toon and rpi, nas etc. it did connect to my regular ssid.
Problem solved!
Posted: Mon Jun 01, 2020 11:20 pm
by TerrorSource
Greets,
Frans
Empty ToonStore usually means a hiccup in the internet connection. The source of the ToonStore is on GitHub which has like 99.999% uptime.
Can you reboot the Toon and try again?
Posted: Mon Nov 30, 2020 4:28 pm
by pkaak
is 5.33.9 the latest stable version for the Toon 1?
Posted: Wed Dec 02, 2020 10:52 pm
by ArieKanarie
Is it advisable to revert to an older firmware version? I while ago I upgraded (not sure what version) but the load on the Toon is too heavy and it is almost constantly rebooting.
I deleted almost every app, only afvalwijzer, calendar and wifiqr are installed.
For now I changed the domoticz script to get toon data every 15 minutes to be able to use the toon.
