Toon app: boiler status
Hypermobile
Re: Toon app: boiler status
Post by Hypermobile »
I think you need to choose from these to make it work.
json = assert(loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\json.lua")()  -- For Windows
json = assert(loadfile "/usr/local/domoticz/var/scripts/lua/JSON.lua")()  -- For Synology
json = assert(loadfile "/opt/domoticz/scripts/lua/JSON.lua")()  -- For Linux (LEDE)
Emacee
Post by Emacee »
gijsje wrote:If i go to /happ_thermstat?action=printTableInfo it only gives me 0 on all values.
If i go to /hcb_rrd/ReadRRD.html it says 404 not found.
If i look at the toon i does see it is otgw boiler but i also says it can not connect to the boiler
Is there something else t check to get this to work?
I had exactly the same issue. The http://192.168.x.x/boilerstatus/boilervalues.txt shows this output (mostly zeroes except room temperature and setpoint):
{"sampleTime":"22-01-2018 15:55:00","boilerSetpoint":0,"roomTempSetpoint":22,"boilerPressure":0,"roomTemp":21.63,"boilerOutTemp":0,"boilerInTemp":0,"boilerModulationLevel":35}
I then removed the Boiler Status app, let the Toon restart en reinstalled. Turned out that my Toon was set to on/off-mode rather then OpenTherm. After putting that back on it is working (except for the pressure but I'm not sure my boiler supports it). So you can try reinstalling the boiler app and restarting Toon. Maybe switch from OpenTherm to on/off and back to make sure that it is set correctly.
{"sampleTime":"22-01-2018 16:18:00","boilerSetpoint":42.66,"roomTempSetpoint":22,"boilerPressure":0,"roomTemp":21.71,"boilerOutTemp":45,"boilerInTemp":44,"boilerModulationLevel":0}
A small update of the boilerstatus app (1.0.3) is available on ToonStore.
Changelog 1.0.3:
- you can select which value to display in dim state by clicking on the tile (when not in dim state obviously).
toggle between water pressure and relative burner modulation level.
The same value will be displayed again after reboot / restart of the gui.
It is bit creative to change the 'config' like this but is saves a separate config screen and therefor has a smaller memory footprint.
Kind regardz,
gielie
Post by gielie »
Hypermobile wrote:Adjusted somebody elses Script to get it to work with this new app:
It's for Domoticz:
1) make 5 UV_variables in domoticz
UV_ToonIP => {STRING} =192.168.x.x
UV_DomoticzIP => {STRING} = 192.168.x.x
UV_ToonboilerInTempName => {STRING} = BoilerInletTemp
UV_ToonboilerOutTempName => {STRING} = BoilerOutletTemp
UV_BoilerPressure => {STRINT} = BoilerPressure
2) Create 3 dummy sensor; with Name BoilerInletTemp, BoilerOutletTemp, BoilerPressure
3) Create a LUA TIME Event copy paste script.
-- Time script runs every minute, intended to sync Domoticz with Toon in case the value is changed on the physical device.
-- Updates Toon ToonboilerOutTempName Sensor to value set on Toon
-- Updates Toon ToonboilerInTempName Sensor to value set on Toon
-- Updates Toon ToonboilerPressure sensor to value set on Toon
commandArray = {}
    ToonboilerInTempName = uservariables['UV_ToonboilerInTempName'] -- Sensor inlet temperature
    ToonboilerOutTempName = uservariables['UV_ToonboilerOutTempName'] -- Sensor outlet temperature
    ToonboilerPressure  =   uservariables['UV_ToonboilerPressure'] -- ToonboilerPressure
  	ToonIP = uservariables['UV_ToonIP']
    DomoticzIP = uservariables['UV_DomoticzIP']
local handle = assert(io.popen(string.format('curl http://%s/boilerstatus/boilervalues.txt', ToonIP)))
   local BoilerInfo = handle:read('*all')
handle:close()
-- JSON data from Toon contains a extra "," which should not be there.
BoilerInfo = string.gsub(BoilerInfo, ",}", "}")
jsonBoilerInfo = json:decode(BoilerInfo)
    currentboilerInTemp = tonumber(jsonBoilerInfo.boilerInTemp)
    currentboilerOutTemp = tonumber(jsonBoilerInfo.boilerOutTemp)
    currentboilerPressure = tonumber(jsonBoilerInfo.boilerPressure)
    -- Update the boilerInTemp
    if otherdevices_svalues[ToonboilerInTempName]*100 ~= currentboilerInTemp*100 then
        print('Updating boiler inlet temp to new value: ' ..currentboilerInTemp)
        commandArray[1] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonboilerInTempName], currentboilerInTemp)}
    end
    -- Update the boilerOutTemp
    if otherdevices_svalues[ToonboilerOutTempName]*100 ~= currentboilerOutTemp*100 then
        print('Updating boiler outlet temp to new value: ' ..currentboilerOutTemp)
        commandArray[2] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonboilerOutTempName], currentboilerOutTemp)}
    end
    -- Update the boilerPressure
    if otherdevices_svalues[ToonboilerPressure]*100 ~= currentboilerPressure*100 then
        print('Updating boiler pressure to new value: ' ..currentboilerPressure)
        commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonboilerPressure], currentboilerPressure)}
    end
return commandArray
---EDITTED: added Pressure measurement
---EDITTED: added *100 to let the IF THEN work Correct
The script works great, accept the pressure because i dont have that value.
Could you add the other parameters to the script like %modulation?
I tried it myself but it doesnt work, i replaced the pressure items for the Modulation parts with no luck.
Rudolf
Post by Rudolf »
For those with Home Assistant this might be helpful:
sensors.yaml
- platform: rest
  json_attributes:
    - sampleTime
    - boilerSetpoint
    - roomTempSetpoint
    - boilerPressure
    - roomTemp
    - boilerOutTemp
    - boilerInTemp
    - boilerModulationLevel
  resource: http://toon/boilerstatus/boilervalues.txt
  value_template: '{{ value_json.sampleTime }}'
- platform: template
  sensors:
    sampleTime:
      friendly_name: 'SampleTime'
      value_template: '{{ states.sensor.boiler_status.attributes["sampleTime"] }}'
odelay99
Post by odelay99 »
It's for Domoticz:
commandArray = {}
handle:close()
    end
    end
    end
return commandArray
I also implemented this script in Domoticz but in the log it shows an error:
EventSystem: in toon_boiler: [string "-- Time script runs every minute, intended to..."]:31: attempt to perform arithmetic on field '?' (a nil value)
Does anone know how to correct this or give me a hint what I did wrong?
Hypermobile
It's for Domoticz:
commandArray = {}
handle:close()
    end
    end
    end
return commandArray
Current Setpoint
Current temp
Current programstate
Burner info
Modulation level;
Next setpoint.
I grab those from another IPTOON/happ_thermstat?action=getThermostatInfo
The BoilerStatus grabs Modulation levels; also from this location;
So i thought it's more usefull to get it at it's source
Check allso this Forum
https://www.domoticz.com/forum/viewtopic.php?t=11421
This is my LUA TIME EVENT:
You Need to create a WHole Bunch of USER Variables. to get it to work
-- Updates Toon Thermostat Sensor to value set on Toon
-- Updates Toon Temperature Sensor to value set on Toon
-- Updates Toon Scenes switch based on program set on Toon
-- Updates Toon Auto Program switch to value set on Toon
-- Updates Toon program information text to value set on Toon
-- Updates Toon Burner status in order to see in domoticz if tyou boiler is on for the hotwater or heating or off (still is a undefined number which i must hunt down)
commandArray = {}
    ToonThermostatSensorName = uservariables['UV_ToonThermostatSensorName'] -- Sensor showing current setpoint
    ToonTemperatureSensorName = uservariables['UV_ToonTemperatureSensorName'] -- Sensor showing current room temperature
    ToonScenesSensorName  = uservariables['UV_ToonScenesSensorName'] -- Sensor showing current program
    ToonAutoProgramSensorName = uservariables['UV_ToonAutoProgramSensorName'] -- Sensor showing current auto program status
	ToonBurnerName = uservariables['UV_ToonBurnerName']
	ToonProgramInformationSensorName = uservariables['UV_ToonProgramInformationSensorName'] -- Sensor showing displaying program information status
	TooncurrentModulationLevel = uservariables['UV_TooncurrentModulationLevel'] -- Sensor showing displaying Current modulation leven
	ToonInternalBoilerSetpoint = uservariables['UV_ToonInternalBoilerSetpoint']
local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
   local ThermostatInfo = handle:read('*all')
handle:close()
if(ThermostatInfo ~= "") then
ThermostatInfo = string.gsub(ThermostatInfo, ",}", "}")
jsonThermostatInfo = json:decode(ThermostatInfo)
    currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
    currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
    currentProgramState = tonumber(jsonThermostatInfo.programState)
    currentActiveState = tonumber(jsonThermostatInfo.activeState)
    currentNextTime = jsonThermostatInfo.nextTime
	currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
    currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
    currentModulationLevel = tonumber(jsonThermostatInfo.currentModulationLevel)
    currentInternalBoilerSetpoint = tonumber(jsonThermostatInfo.currentInternalBoilerSetpoint)
    -- Update the thermostat sensor to current setpoint
    if otherdevices_svalues[ToonThermostatSensorName]*100 ~= currentSetpoint*100 then
        print('Updating thermostat sensor to new set point: ' ..currentSetpoint)
        commandArray[1] = {['Variable:UV_ToonChangedByDomoticz'] = '1'} -- Set variable changed to 1 to prevent script ToonSetPoint from shooting an event at Toon
        commandArray[2] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonThermostatSensorName], currentSetpoint)}
    end
    -- Update the temperature sensor to current room temperature
    if otherdevices_svalues[ToonTemperatureSensorName]*100 ~= currentTemperature*100 then
        print('Updating the temperature sensor to new value: ' ..currentTemperature)
        commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonTemperatureSensorName], currentTemperature)}
    end
    -- Update the toon scene selector sensor to current program state
    CurrentToonScenesSensorValue = otherdevices_svalues[ToonScenesSensorName]
    if currentActiveState == -1 then currentActiveState = '50' -- Manual
    elseif currentActiveState == 0 then currentActiveState = '40' -- Comfort
    elseif currentActiveState == 1 then currentActiveState = '30' -- Home
    elseif currentActiveState == 2 then currentActiveState = '20' -- Sleep
    elseif currentActiveState == 3 then currentActiveState = '10' -- Away
    end
    if CurrentToonScenesSensorValue ~= currentActiveState then  -- Update toon selector if it has changed
        print ('Updating Toon Scenes selector')
        commandArray[4] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonScenesSensorName], currentActiveState)}
    end
    -- Updates the toon auto program switch
    CurrentToonAutoProgramSensorValue = otherdevices_svalues[ToonAutoProgramSensorName]
    if currentProgramState == 0 then currentProgramState = '10' -- No
    elseif currentProgramState == 1 then currentProgramState = '20' -- Yes
    elseif currentProgramState == 2 then currentProgramState = '30' -- Temporary
    end
    if CurrentToonAutoProgramSensorValue ~= currentProgramState then -- Update toon auto program selector if it has changed
        print ('Updating Toon Auto Program selector')
        commandArray[5] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonAutoProgramSensorName], currentProgramState)}
    end
    -- Updates the toon program information text box
    CurrentToomProgramInformationSensorValue = otherdevices_svalues[ToonProgramInformationSensorName]
    if currentNextTime == 0 or currentNextSetPoint == 0 then
        ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
    else
        ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
    end
    if CurrentToomProgramInformationSensorValue ~= ToonProgramInformationSensorValue then
        commandArray[6] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonProgramInformationSensorName], ToonProgramInformationSensorValue)}
    end
 -- Update the toon burner selector to current program state
    CurrentToonBurnerValue = otherdevices_svalues[ToonBurnerName]
	if currentBurnerInfo == 0 then currentBurnerInfo = '0' -- uit
    elseif currentBurnerInfo == 1 then currentBurnerInfo = '10' -- cv aan
    elseif currentBurnerInfo == 2 then currentBurnerInfo = '20' -- warmwater aan
    end
    if CurrentToonBurnerValue ~= currentBurnerInfo then  -- Update toon burner selector if it has changed
        print ('Updating Toon burner info')
        commandArray[7] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonBurnerName], currentBurnerInfo)}
    end
 -- Update the modulation level of the burner
    if otherdevices_svalues[TooncurrentModulationLevel]+1 ~= currentModulationLevel+1 then
        print('Updating the ModulationLevel to new value: ' ..currentModulationLevel)
        commandArray[8] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[TooncurrentModulationLevel], currentModulationLevel)}
    end
      -- Update the Internal Setpoint of the boiler
    if otherdevices_svalues[ToonInternalBoilerSetpoint]+1 ~= currentInternalBoilerSetpoint+1 then
        print('Updating the currentInternalBoilerSetpoint to new value: ' ..currentInternalBoilerSetpoint)
        commandArray[9] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonInternalBoilerSetpoint], currentInternalBoilerSetpoint)}
    end
else
print ('Geen data terug')
end
return commandArray
Hypermobile
GAS and Electricity
are done with PHP TimeScripts
but that maybe also possieble with a Lua Script
Hypermobile
Minor issue:
IPTOON/boilerstatus/boilervalues.txt AFTER a FULL reboot
"roomTempSetpoint":null,"boilerPressure":null
Pushed Comfort;
"roomTempSetpoint":20.5,"boilerPressure":null
so after a Reboot; RoomTempSetpoint needs to change to be able to see it in the Boilervalues.txt
Also noticed that Boiler Pressure is now "NULL" or "NaN"
That was definitely 0.0 yesterday.
Hypermobile wrote:Minor issue:
Pushed Comfort;
This is because the app is retrieving data from the rra databases of the last three seconds.
After a full reboot the app is starting up faster then the rra databases are getting populated.
This should automatically resolve itself pretty quickly after a full reboot.
glsf91
Post by glsf91 »
Hypermobile wrote:
Current Setpoint
Current temp
Burner info
Modulation level;
Next setpoint.
commandArray = {}
handle:close()
    end
    end
    end
    end
    end
    end
    else
    end
    end
    end
    end
    end
    end
else
end
return commandArray
Which kind of device type did you use for Modulation level and Next setpoint ?
RDNZL
Post by RDNZL »
Great work!
I want to get this boilerstatus info from toon and implement it in my hass component, but I rather not install the boiler status app from toon app store.
Is it possible to install the app manually, outside the store?
If so where can I get the bin/src code for it?
Regards, Ron.
RDNZL
Post by RDNZL »
Oh wait, I probably only need the html code to get the json data, will try that first, thanks.
Regards, Ron.
RDNZL
Post by RDNZL »
No that's the rrd data lol...
Regards, Ron.
Emacee
Post by Emacee »
Rudolf wrote:For those with Home Assistant this might be helpful:
sensors.yaml
- platform: rest
  json_attributes:
    - sampleTime
    - boilerSetpoint
    - roomTempSetpoint
    - boilerPressure
    - roomTemp
    - boilerOutTemp
    - boilerInTemp
  sensors:
    sampleTime:
Works like a charm, thanks! Would be nice to split the attributes into different sensors so you are able to use it for graphing and grouping. I would have no idea where to start with that tough :lol:
