Controlling Toon via Domoticz
TerrorSource
Re: Controlling Toon via Domoticz
Post by TerrorSource »
yjb wrote:
TerrorSource wrote:
madpatrick wrote: Hello TerrorSource,
Is it possible to share the DOC-file.
I can update the manual for the DzVents script, update it and correct a few errors.
You can contact me via PM or email so I can edit the modifications in the PDF files ;)
Just wondering, was the manual ever updated?
Well, this is v2 with some minor modifications from v1.
Never received any comments on this version via PM so had no need to make a v3.
madpatrick
Post by madpatrick »
I’ve offered my services to update the .doc file.
Collecting the changes and summarize it to PM is more work then direct making the changes in the original file, especially with pictures and comments.
But no problem..... the information is on the forum :)
pietpiet50
Post by pietpiet50 »
a big thankyou for the manual and the scripts.
Everything is working i think, but there are some errors in the logfile:
2019-02-11 14:42:42.280 (Toon) Light/Switch (ToonScenes)
2019-02-11 14:42:42.448 EventSystem: Sending SetPoint to device....
2019-02-11 14:42:42.453 (Toon) Thermostat (ToonThermostat)
2019-02-11 14:42:42.625 EventSystem: Sending SetPoint to device....
2019-02-11 14:42:42.630 (Toon) Thermostat (ToonThermostat)
2019-02-11 14:42:42.265 Status: User: Admin initiated a switch command (5/ToonScenes/Set Level)
2019-02-11 14:42:42.443 Status: LUA: Updating thermostat sensor to new set point: 19
2019-02-11 14:42:42.454 Status: EventSystem: Script event triggered: Toon
2019-02-11 14:42:42.463 Status: LUA: Updating 'ToonScenes' selector to 'Sleep'
2019-02-11 14:42:42.469 Status: EventSystem: Script event triggered: ToonSetpoint
2019-02-11 14:42:42.620 Status: LUA: Updating thermostat sensor to new set point: 16.5
2019-02-11 14:42:42.631 Status: EventSystem: Script event triggered: Toon
2019-02-11 14:42:42.636 Status: EventSystem: Script event triggered: ToonThermostat
2019-02-11 14:42:42.781 Status: LUA: Setting Toon setpoint to 16.50
2019-02-11 14:42:42.781 Status: EventSystem: Fetching url http://192.168.1.174/happ_thermstat?act ... point=1650...
2019-02-11 14:42:42.781 Status: EventSystem: Script event triggered: ToonThermostat
2019-02-11 14:42:42.443 Error: EventSystem: in Toon: [string "commandArray = {} ..."]:50: attempt to perform arithmetic on field '?' (a nil value)
2019-02-11 14:42:42.620 Error: EventSystem: in Toon: [string "commandArray = {} ..."]:50: attempt to perform arithmetic on field '?' (a nil value)
2019-02-11 14:42:42.775 Error: EventSystem: in Toon: [string "commandArray = {} ..."]:50: attempt to perform arithmetic on field '?' (a nil value)
2019-02-11 14:42:45.365 (Toon) Light/Switch (ToonScenes)
2019-02-11 14:42:45.352 Status: User: Admin initiated a switch command (5/ToonScenes/Set Level)
2019-02-11 14:42:45.444 Error: EventSystem: in Toon: [string "commandArray = {} ..."]:50: attempt to perform arithmetic on field '?' (a nil value)
What is going wrong on that lines?
Also on the tab temperatur, the toontemperature is Always 0 degrees, strange
Maybe it comes because of toon is not Always connected to the wifi network, it loses the connection. Also it reboot 12 times a day, with only 2 apps installed.
emielfellinger
Post by emielfellinger »
Great manual. Makes it easy :)
But i have the same error
Error: EventSystem: in Toon: [string "commandArray = {}..."]:50: attempt to perform arithmetic on field '?' (a nil value)
I double checked everything but can't seem to find what I did wrong.
witteherder
Post by witteherder »
Hi TerrorSource,
I have a question.
What I need to do else in step 5A (see attached file)
I choosed the tabblad Switches because I dont see tabblad Sensors!!!
Maybe I m in the wrong tabblad?
Step 5A
Step 5A
Toon 2 Rooted User
Firmware version: 5.94.7
Raspberry Pi 3B+
Domoticz 2022.1
10 Neo Coolcam PowerPlus
Domotica Beginner (need little help in beginning)
TerrorSource
witteherder wrote:Hi TerrorSource,
I have a question.
You did not read the manual :D You created a wrong dummy device. Please re-do the steps.
TerrorSource
Mmhmm guys help! haha
I've got some issues with the manual myself :roll:
It's all setup following the manual and setting the temperatue via "ToonThermostat" via the Domoticz webpage works but it doesn't work from Domoticz app on my phone or via Siri (via HomeBridge connected to Domoticz).
Anyone got a clue how i can fix it? Nothing usefull in the logs when i use Siri.
2019-02-23 21:43:09.635 Status: LUA: Setting Toon setpoint to 11.5
2019-02-23 21:43:09.635 Status: EventSystem: Fetching URL http://192.168.192.13/happ_thermstat?ac ... point=1150 after 0.2 seconds...
2019-02-23 21:43:09.635 Status: EventSystem: Script event triggered: ToonThermostat
2019-02-23 21:43:09.762 Status: LUA: Updating thermostat sensor to new set point: 12
2019-02-23 21:43:09.776 Status: EventSystem: Script event triggered: Toon
2019-02-23 21:43:09.976 Status: EventSystem: Script event triggered: ToonThermostat
2019-02-23 21:43:10.104 Status: EventSystem: Script event triggered: Toon
2019-02-23 21:43:10.299 Status: LUA: Setting Toon setpoint to 12.00
2019-02-23 21:43:10.299 Status: EventSystem: Fetching URL http://192.168.192.13/happ_thermstat?ac ... point=1200 after 0.2 seconds...
2019-02-23 21:43:10.299 Status: EventSystem: Script event triggered: ToonThermostat
2019-02-23 21:43:10.429 Status: LUA: Updating thermostat sensor to new set point: 11.5
2019-02-23 21:43:10.440 Status: EventSystem: Script event triggered: Toon
2019-02-23 21:43:10.636 Status: EventSystem: Script event triggered: ToonThermostat
2019-02-23 21:43:10.764 Status: LUA: Updating thermostat sensor to new set point: 12
2019-02-23 21:43:10.784 Status: EventSystem: Script event triggered: Toon
2019-02-23 21:43:10.979 Status: EventSystem: Script event triggered: ToonThermostat
TerrorSource
BOverdevest wrote:Based on several posts, I combined getting all Toon data to Domoticz in a single DzVents script. So both boiler data, thermostat data and the P1 data.
Now that I have a rooted Toon2 :D I had to update the script, as the P1 data apparently changed in the http://<ToonIP>/hdrv_zwave?action=getDevices.json.
return {
	on = {
		timer = {
			'every minute'
	execute = function(domoticz)
        local ToonThermostat        = domoticz.variables('UV_ToonThermostat').value -- Sensor showing current setpoint
        local ToonTemperature       = domoticz.variables('UV_ToonTemperature').value -- Sensor showing current room temperature
        local ToonBoilerTempIn      = domoticz.variables('UV_ToonBoilerTempIn').value -- Sensor showing water temp return
        local ToonBoilerTempOut     = domoticz.variables('UV_ToonBoilerTempOut').value -- Sensor showing current water temp out
        local ToonBoilerPressure    = domoticz.variables('UV_ToonBoilerPressure').value -- Sensor showing current room temperature
        local ToonBoilerModulation  = domoticz.variables('UV_ToonBoilerModulation').value -- Sensor showing current Boiler Modulation
        local ToonScenes            = domoticz.variables('UV_ToonScenes').value -- Sensor showing current program
        local ToonAutoProgram       = domoticz.variables('UV_ToonAutoProgram').value -- Sensor showing current auto program status
        local ToonProgramInformation = domoticz.variables('UV_ToonProgramInformation').value -- Sensor showing displaying program information status
        local ToonIP                = domoticz.variables('UV_ToonIP').value
        local DomoticzIP            = domoticz.variables('UV_DomoticzIP').value
        local ToonBurnerName        = domoticz.variables('UV_ToonBurnerName').value
        local P1SmartMeterPower     = domoticz.variables('UV_P1SmartMeterElectra').value
        local P1SmartMeterGas1      = domoticz.variables('UV_P1SmartMeterGasMeterStand').value
        local ToonBoilerSetpoint    = domoticz.variables('UV_ToonBoilerTempSetpoint').value  -- Sensor showing current boiler set point water temp out
        -- Handle json
        local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
        local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
        local ThermostatInfo = handle:read('*all')
        handle:close()
        local jsonThermostatInfo = json:decode(ThermostatInfo)
        if jsonThermostatInfo == nil then
            return
        end
        local handle2 = assert(io.popen(string.format('curl http://%s/boilerstatus/boilervalues.txt', ToonIP)))
        local BoilerInfo = handle2:read('*all')
        handle2:close()
        -- JSON data from Toon contains a extra "," which should not be there.
        BoilerInfo = string.gsub(BoilerInfo, ",}", "}")
        jsonBoilerInfo = json:decode(BoilerInfo)
         -- http://IP_TOON/hdrv_zwave?action=getDevices.json
        local handle4 = assert(io.popen(string.format('curl http://%s/hdrv_zwave?action=getDevices.json', ToonIP)))
        local GasPowerInfo = handle4:read('*all')
        handle4:close()
        -- JSON data from Toon contains a extra "." which should not be there.
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_4.", "dev_4")
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_4:", "dev_4\":")
        local jsonGasPower = json:decode(GasPowerInfo)
       -- domoticz.log(jsonGasPower)
         local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityFlow )
         local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityQuantity)
         local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityFlow )
         local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityQuantity)
         local CurrentGasFlow = tonumber(jsonGasPower.dev_41.CurrentGasFlow)
         local CurrentGasQuantity = tonumber(jsonGasPower.dev_41.CurrentGasQuantity)
         local CurrentElectricityQuantity =   CurrentElectricityFlowHoog + CurrentElectricityFlowLaag
         local CurrentElectricityDeliveredLaag = 0
         local CurrentElectricityDeliveredHoog = 0
         local totalDeliveredPower = 0
        domoticz.devices(P1SmartMeterPower).updateP1(CurrentElectricityQuantityLaag, CurrentElectricityQuantityHoog, CurrentElectricityDeliveredLaag, CurrentElectricityDeliveredHoog, CurrentElectricityQuantity, totalDeliveredPower).silent()
        domoticz.devices(P1SmartMeterGas1).updateGas(CurrentGasQuantity).silent()
 -- Update the Boiler Water In to current value
         local currentboilerInTemp = tonumber(jsonBoilerInfo.boilerInTemp)
        if domoticz.utils.round(domoticz.devices(ToonBoilerTempIn).temperature,0) ~= domoticz.utils.round(currentboilerInTemp,0) then
            -- domoticz.log('Updating Boiler Water In to current value: ' ..currentboilerInTemp)
            domoticz.devices(ToonBoilerTempIn).updateTemperature(currentboilerInTemp).silent()
        end
 -- Update the Boiler water Out to current value
     local currentboilerOutTemp = tonumber(jsonBoilerInfo.boilerOutTemp)
        if domoticz.utils.round(domoticz.devices(ToonBoilerTempOut).temperature,0) ~= domoticz.utils.round(currentboilerOutTemp,0) then
            -- domoticz.log('Updating Boiler Water Out to current value: ' ..currentboilerOutTemp)
            domoticz.devices(ToonBoilerTempOut).updateTemperature(currentboilerOutTemp).silent()
        end
 -- Update the Boiler water Pressure to current value
        local currentBoilerPressure = tonumber(jsonBoilerInfo.boilerPressure) * 10
        if domoticz.utils.round(domoticz.devices(ToonBoilerPressure)._nValue,0) ~= domoticz.utils.round(currentBoilerPressure,0) then
            -- domoticz.log('Updating Boiler Pressure to current value: ' ..currentBoilerPressure)
            domoticz.devices(ToonBoilerPressure).updatePressure(currentBoilerPressure).silent()
        end
        local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
        local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
        local currentProgramState = tonumber(jsonThermostatInfo.programState)
            if currentProgramState == 0 then currentProgramState = 10 -- No
                elseif currentProgramState == 1 then currentProgramState = 20 -- Yes
                elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary
            end
        local currentActiveState = tonumber(jsonThermostatInfo.activeState)
            if currentActiveState == -1 then currentActiveState = 50 -- Manual
                elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort
                elseif currentActiveState == 1 then currentActiveState = 30 -- Home
                elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep
                elseif currentActiveState == 3 then currentActiveState = 10 -- Away
            end
        -- Update the toon burner selector to current program state
        local currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
        local CurrentToonBurnerValue = domoticz.devices(ToonBurnerName).level
        if currentBurnerInfo == 0 then currentBurnerInfo = 0 -- uit
            elseif currentBurnerInfo == 1 then currentBurnerInfo = 10 -- cv aan
            elseif currentBurnerInfo == 2 then currentBurnerInfo = 20 -- warmwater aan
        end
        if CurrentToonBurnerValue ~= currentBurnerInfo then  -- Update toon burner selector if it has changed
            -- domoticz.log('Updating Toon burner info:')
            domoticz.devices(ToonBurnerName).switchSelector(currentBurnerInfo)
        end
        -- Update the modulation level of the burner
        local currentModulationLevel = tonumber(jsonThermostatInfo.currentModulationLevel)
        if domoticz.devices(ToonBoilerModulation).percentage + 1 ~= currentModulationLevel + 1 then
            -- domoticz.log('Updating the Modulation sensor to new value: ' ..currentModulationLevel)
            domoticz.devices(ToonBoilerModulation).updatePercentage(currentModulationLevel)
        end
         -- Update the temperature Boiler setpoint to current boiler set point
        local currentInternalBoilerSetpoint = jsonThermostatInfo.currentInternalBoilerSetpoint+1
        if domoticz.utils.round(domoticz.devices(ToonBoilerSetpoint).temperature, 1) ~= domoticz.utils.round(currentInternalBoilerSetpoint, 1) then
            -- domoticz.log('Updating the Boiler internal temperature setpoint to new value: ' ..currentInternalBoilerSetpoint)
            domoticz.devices(ToonBoilerSetpoint).updateTemperature(currentInternalBoilerSetpoint)
        end
        -- Update the thermostat sensor to current setpoint
        if domoticz.devices(ToonThermostat).setPoint*100 ~= currentSetpoint*100 then
            -- domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint)
            domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent()
        end
        -- Update the temperature sensor to current room temperature
        if domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1) ~= domoticz.utils.round(currentTemperature, 1) then
            -- domoticz.log('Updating the temperature sensor to new value: ' ..currentTemperature)
            domoticz.devices(ToonTemperature).updateTemperature(currentTemperature)
        end
        -- Update the toon scene selector sensor to current program state
        if domoticz.devices(ToonScenes).level ~= currentActiveState then  -- Update toon selector if it has changed
            -- domoticz.log('Updating Toon Scenes selector to: '..currentActiveState)
            domoticz.devices(ToonScenes).switchSelector(currentActiveState).silent()
        end
        -- Updates the toon auto program switch
        if domoticz.devices(ToonAutoProgram).level ~= currentProgramState then -- Update toon auto program selector if it has changed
            -- domoticz.log('Updating Toon Auto Program selector to: '..currentProgramState)
            domoticz.devices(ToonAutoProgram).switchSelector(currentProgramState).silent()
        end
        -- Updates the toon program information text box
        local currentNextTime = jsonThermostatInfo.nextTime
        local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
        if currentNextTime == 0 or currentNextSetPoint == 0 then
            ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
        else
            ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
        end
        if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then
            -- domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue)
            domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue)
        end
	end
I'm getting an errors using the script
Issue 1:
2019-02-23 23:16:00.445 Status: dzVents: Info: getSceneState: ------ Finished Slapen
2019-02-23 23:16:00.445 Status: dzVents: Info: ------ Start internal script: Toon:, trigger: every minute
2019-02-23 23:16:00.652 Status: dzVents: Error (2.4.14): An error occured when calling event handler Toon
2019-02-23 23:16:00.652 Status: dzVents: Error (2.4.14): /home/pi/domoticz/scripts/lua/JSON.lua:660: html passed to JSON:decode(): <?xml version="1.0" encoding="iso-8859-1"?>
2019-02-23 23:16:00.652 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
2019-02-23 23:16:00.652 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
2019-02-23 23:16:00.652 <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
2019-02-23 23:16:00.652 <head>
2019-02-23 23:16:00.652 <title>404 - Not Found</title>
2019-02-23 23:16:00.652 </head>
2019-02-23 23:16:00.652 <body>
2019-02-23 23:16:00.652 <h1>404 - Not Found</h1>
2019-02-23 23:16:00.652 </body>
2019-02-23 23:16:00.652 </html>
2019-02-23 23:16:00.652 Status: dzVents: Info: ------ Finished Toon
FIXED: Had to install ToonStore app "Boilerstatus"
Issue 2:
2019-02-24 00:08:00.478 Status: dzVents: Info: ------ Start internal script: Toon:, trigger: every minute
2019-02-24 00:08:00.809 Status: dzVents: Error (2.4.14): An error occured when calling event handler Toon
2019-02-24 00:08:00.809 Status: dzVents: Error (2.4.14): /home/pi/domoticz/dzVents/runtime/Domoticz.lua:169: attempt to perform arithmetic on local 'x' (a nil value)
2019-02-24 00:08:00.809 Status: dzVents: Info: ------ Finished Toon
Issue 3:
Cannot set temperature by using ToonThermostat. it doesn't send it to the Toon2.
FIXED: Used the DzVents script to set the setpoint, see viewtopic.php?f=102&t=12097&start=30#p88055
Issue 4:
ToonProgramInformation is not edited. looks like the function in the script is not working.
Also found out that the p1 data used is this:
Go to http://TOON_IP/hdrv_zwave?action=getDevices.json
copy the data to https://jsonlint.com/ to make it more readable and check the following:
For me it was dev_3, it can be dev_2 and dev_4 also.
"dev_3.1": {
"type": "gas", - gas
"dev_3.4": {
"type": "elec_delivered_nt", - afname normaal
"dev_3.5": {
"type": "elec_received_nt", - levering normaal
"dev_3.6": {
"type": "elec_delivered_lt", - afname laag
"dev_3.7": {
"type": "elec_received_lt",- levering laag
I had to fill in:
local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_34.CurrentElectricityFlow )
local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_34.CurrentElectricityQuantity)
local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_36.CurrentElectricityFlow )
local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_36.CurrentElectricityQuantity)
local CurrentGasFlow = tonumber(jsonGasPower.dev_31.CurrentGasFlow)
local CurrentGasQuantity = tonumber(jsonGasPower.dev_31.CurrentGasQuantity)
anconakip
Post by anconakip »
i have a Toon 1 rooted. But how can i get mij energy meters shown into domoticz?
Markie13
Post by Markie13 »
Hello people,
The following.
Is use a script from Ehoco.nl as last resort right now.
I would like to use this mode of operation on my Domoticz. Everything (scripts) seems to have been loaded properly, because I see no errors. Only the information will not been read by domoticz from my Toon. So no pressures readings, temperatures readings, statuses etc. Only manual temperature higher and lower succeeds.
All virtual sensors are correctly created as well as my user variables. My ToonIP is also known in Domoticz.
I also tried various scripts / manuals on domoticz forum and domoticaforum.eu.
I run Domoticz on an Ubuntu server because I had a spare NUC.
Can someone help me with this?
Thanks in advance
return {
   on = {
      timer = {
         'every minute'
        local ToonThermostat        = domoticz.variables('UV_ToonThermostatSensorName').value -- Sensor showing current setpoint
        local ToonTemperature       = domoticz.variables('UV_ToonTemperatureSensorName').value -- Sensor showing current room temperature
        local ToonBoilerTempIn      = domoticz.variables('UV_ToonboilerInTempName').value -- Sensor showing water temp return
        local ToonBoilerTempOut     = domoticz.variables('UV_ToonboilerOutTempName').value -- Sensor showing current water temp out
        local ToonBoilerPressure    = domoticz.variables('UV_ToonboilerPressure').value -- Sensor showing current room temperature
        local ToonBoilerModulation  = domoticz.variables('UV_ToonboilerModulationLevel').value -- Sensor showing current Boiler Modulation
        local ToonScenes            = domoticz.variables('UV_ToonScenesSensorName').value -- Sensor showing current program
        local ToonAutoProgram       = domoticz.variables('UV_ToonAutoProgramSensorName').value -- Sensor showing current auto program status
        local ToonProgramInformation = domoticz.variables('UV_ToonProgramInformationSensorName').value -- Sensor showing displaying program information status
--        local P1SmartMeterPower     = domoticz.variables('UV_P1SmartMeterElectra').value
--        local P1SmartMeterGas1      = domoticz.variables('UV_P1SmartMeterGasMeterStand').value
        local ToonBoilerSetpoint    = domoticz.variables('UV_ToonBoilerTempSetpointSensorName').value  -- Sensor showing current boiler set point water temp out
        -- Handle json
        local json = assert(loadfile "/home/mark/domoticz/scripts/lua/JSON.lua")()  -- For Linux
        handle:close()
            return
        end
        handle2:close()
--        local handle4 = assert(io.popen(string.format('curl http://%s/hdrv_zwave?action=getDevices.json', ToonIP)))
--        local GasPowerInfo = handle4:read('*all')
--        handle4:close()
--        GasPowerInfo = string.gsub(GasPowerInfo, "dev_4.", "dev_4")
--        GasPowerInfo = string.gsub(GasPowerInfo, "dev_4:", "dev_4\":")
--        local jsonGasPower = json:decode(GasPowerInfo)
--         local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityFlow )
--         local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityQuantity)
--         local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityFlow )
--         local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_46.CurrentElectricityQuantity)
--         local CurrentGasFlow = tonumber(jsonGasPower.dev_41.CurrentGasFlow)
--         local CurrentGasQuantity = tonumber(jsonGasPower.dev_41.CurrentGasQuantity)
--         local CurrentElectricityQuantity =   CurrentElectricityFlowHoog + CurrentElectricityFlowLaag
--         local CurrentElectricityDeliveredLaag = 0
--         local CurrentElectricityDeliveredHoog = 0
--         local totalDeliveredPower = 0
--        domoticz.devices(P1SmartMeterPower).updateP1(CurrentElectricityQuantityLaag, CurrentElectricityQuantityHoog, CurrentElectricityDeliveredLaag, CurrentElectricityDeliveredHoog, CurrentElectricityQuantity, totalDeliveredPower).silent()
--        domoticz.devices(P1SmartMeterGas1).updateGas(CurrentGasQuantity).silent()
        end
        end
        end
        local currentTemperature = domoticz.utils.round(tonumber(jsonThermostatInfo.currentTemp) / 100,1)
            end
                elseif currentActiveState == 3 then currentActiveState = 10 -- Away<br>                elseif currentActiveState == 4 then currentActiveState = 60 -- Holiday
            end
            elseif currentBurnerInfo == 2 then currentBurnerInfo = 20 -- warmwater aan<br>            elseif currentBurnerInfo == 3 then currentBurnerInfo = 10 -- voorverwarmen volgend setpoint
        end
        end
        end
        end
        end
        end
        end
        end
        else
        end
        end
   end
TerrorSource
Markie13 wrote:Hello people,
The following.
Thanks in advance
You know that Ehoco "steals" all the information from this forum without a proper source underneath it?
The script you copied is EXACTLY the one from Boverdevest on page 2/3.
Markie13
Post by Markie13 »
In that way I saw some similarities. But I didn't know. Sorry for that.
anconakip
Post by anconakip »
When i use this script i get the next error:
2019-02-26 13:09:01.611 Status: dzVents: Error (2.4.14): An error occured when calling event handler Toon
2019-02-26 13:09:01.611 Status: dzVents: Error (2.4.14): /home/pi/domoticz/scripts/lua/JSON.lua:660: html passed to JSON:decode(): <?xml version="1.0" encoding="iso-8859-1"?>
2019-02-26 13:09:01.611 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
2019-02-26 13:09:01.611 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
2019-02-26 13:09:01.611 <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
2019-02-26 13:09:01.611 <head>
2019-02-26 13:09:01.611 <title>404 - Not Found</title>
2019-02-26 13:09:01.611 </head>
2019-02-26 13:09:01.611 <body>
2019-02-26 13:09:01.611 <h1>404 - Not Found</h1>
2019-02-26 13:09:01.611 </body>
2019-02-26 13:09:01.611 </html>
2019-02-26 13:09:01.612 Status: dzVents: Info: ------ Finished Toon
What should i do?
When you use the Ehoco script, go and ask there ...
Not sure what your web client is asking for, but whatever it is, it's not in the place where it is expected.
Markie13
Post by Markie13 »
marcelr wrote:When you use the Ehoco script, go and ask there ...
Okay, then I will change my question.
As mentioned in my post, scripts, tutorials etc like in the 1ste post here didn't work as well! These script don't read my Toon. Im not asking to make that script working. Im asking to make all of your scripts read out my Toon!
