New major firmware release 5.0.4 - UPGRADE AVAILABLE
madpatrick
Re: New major firmware release 5.0.4 - UPGRADE AVAILABLE
Post by madpatrick »
update was succesfull.
Only the custom app where removed from the tiles.
added them again and working !
thanks !!
Ierlandfan
Post by Ierlandfan »
@TheHogNL
Do you need a toon1 or toon2 drawables?
For a 1.
I noticed the update script thought I was on a Toon 2 (Only saw that when the upgrade failed) for some reason so I think that's why the file is not working.
Post by TheHogNL »
Ok just put the 5.0.4 toon1 drawables-base.rcc here for you: http://qutility.nl/resourcefiles/drawab ... s-base.rcc
Ierlandfan
Thanx! Still not working but I noticed in the QT logs this:
(A lot of those Failed to get image from provider) This is just an example.
qrc:/qb/components/ThreeStateButton.qml:52:2: QML Image: Failed to get image from provider: image://colorized/#a8a8a8/images/arrow-down.svg
Any idea?
Post by TheHogNL »
Hmms looks like your QT is not updated correctly or something. This image://colorized is new in fw 5. Try to reinstall the qt-gui package with "opkg install --force-reinstall qt-gui" with VPN connected (remember if you manually enable the VPN you will loose the scsync settings).
Ierlandfan
With the resource files replaced and a reinstall of qt it works like it should.
Thanx!
witteherder
Post by witteherder »
I m NEWBIE so I have no experience at all (for now)
Can I upgrade m toon version 4.22.7 to 5.04 from the Toon1 Panel without any problem or should I wait untill bugs are away?
Because if something goes wrong I don't know how to fix...
Toon 2 Rooted User
Firmware version: 5.94.7
Raspberry Pi 3B+
Domoticz 2022.1
10 Neo Coolcam PowerPlus
Domotica Beginner (need little help in beginning)
Post by TheHogNL »
Just wait. There is really nothing in 5.0.4 which you need to have (yes, booting is a bit quicker but that is all).
hdok
Post by hdok »
Just installed 5.0.4 on my toon1. It solved the afvalwijzer problem I had. Installation went smoothly, like stated earlier, I had to re-add all custom tiles and had to switch off some native toon apps. It appears to work as expected. Again: great work you guys! Thanks!
mogwai
Post by mogwai »
I finally dared to upgrade my toon1 to 5.0.4 using the update script. It worked flawlessly. Thanks for the hard work guys!
yjb
Post by yjb »
Finally had to courage to upgrade my Toon2 to 5.0.4: works like a charm. Thanks for all the work!
NLKris
Post by NLKris »
I did the upgrade from 4.22.x > 5.0.4. Works all fine first, untill I start to test if the auto boot of X11vnc would work. I add the follow line in the inittab:
$ x11v:5:respawn:/usr/bin/x11vnc
In 4.22.x it didn't do anything for me. With 5.0.4 it booted up after a reboot. So for the first time it booted, but I saw that it started for 10 times on 10 different ports (5900 till 5909). After some testing I found out the toon resets after a while and stay in boot loop. If I power op it will run normal, after some minutes the Toon goes back in bootloop. Remove line and problem solved. Is there any other way to boot it fine? I saw someone else had this problem but didn't post the workaround.
Also I'm looking for a way to get dimmode when the program "Weg" and/or "Slapen" is active. I wan't alway the dimstate, someone that know how to edit that?
Thanks.
Post by TheHogNL »
don't put x11vnc in inittab.. only start x11vnc if you need it. It eats a lot of memory so having it running while you are not using it is just a waste of resources.
But if you really want it to auto start, create a script int /etc/init.d and link from it from /etc/rc5.d
NLKris
Post by NLKris »
Ahh oke, thats clear. Any tips for the dimstate thing? I don't want the screen to go black while sleeping or away is set.
Post by TheHogNL »
That is not possible with the software now as far as I know
Return to “Toon Firmware”
