Toon mobile access
Re: Toon mobile access
Safari still doesn't like it, and I still have to login. (and it is local IP too)
But it gets even stranger, wanted to remove and reinstall the app so went to the toonstore, but the app is gone.
17 apps in the store but no mobile.
Toonstore V 5.0.0 Firmware 5.15.6
Ron.
Ron.
Mobile website (app) is auto installed since last update as it can't be part of the github normal app installation. If you remove it (from /qmf/www/mobile) it will be reinstalled after next update.Ron_nl wrote:Safari still doesn't like it, and I still have to login. (and it is local IP too)
Ron.
There is no reason to reinstall it because it is just a few simpel webpages.
Ahh so it used to be an app.
Cleared that part, thanks!
Ron.
Ron.
- Administrator
Yup! Way more easier now. Only set username/password in Instellingen > TSC and you're done!Ron_nl wrote:Ahh so it used to be an app.
Ron.
But that is just what I don't wantTerrorSource wrote:Yup! Way more easier now. Only set username/password in Instellingen > TSC and you're done!
Want it without the login.
Ron.
Just edit the lighttpd.conf for that.Ron_nl wrote:But that is just what I don't wantTerrorSource wrote:Yup! Way more easier now. Only set username/password in Instellingen > TSC and you're done!![]()
Want it without the login.![]()
Ron.
Thanks, with some research, trial and error I've found it.TheHogNL wrote:Just edit the lighttpd.conf for that.
Ron.
Hi, could somebody please share with me the content of the /mobile folder? Or can it still be found somewhere? For some reason, the mobile access wasn't working for me when I rooted my Toon. So I checked the content of the /mobile folder and saw that index.html was completely blank. I deleted all the files in the folder so now I have to get them back somehow. Thank you!
https://github.com/ToonSoftwareCollective/mobileRon_nl wrote:Thanks, with some research, trial and error I've found it.TheHogNL wrote:Just edit the lighttpd.conf for that.![]()
Ron.
Hi
Today I updated my toon and fixed the connection problem with the toon mobile app.
Also entered the beta team for the app and got its last update on google play store
In the app I now see what I used for electrical power today on the bottom left and gas today on the bottom right of the screen.
As I see the power readings are displayed the gas readings are not, athough both are connected smart meters and on the toon itself I can read the gas usage perfectly
When I call the graphics I also do not see the gas usage but do see the electrical graphics
Somehow the readings do not get transfered to the mobile app.
I thought I would report that here so you can check that out.
P.S. when I check the version number of the toon app it says versie 0.5.7 ??
I'm on IOS and connected to my Toon. Is there a way to control also the lights from the mobile site?
- Administrator
Not by ToonMobile. Maybe a different way, domoticz or HomeAssisant for example.Stampre wrote:I'm on IOS and connected to my Toon. Is there a way to control also the lights from the mobile site?
That's a bug, I'm working on it.estate wrote: As I see the power readings are displayed the gas readings are not, athough both are connected smart meters and on the toon itself I can read the gas usage perfectly
Totaal nieuw. Nu ook water, zonnepanelen, gas, teruglevering en zelfs slimme stekkers in de mobiele app.
Hallo Oepi Loepi,
Ik gebruik ook de mobile login maar zie maar 2 tabbladen ipv 3 op de Toon 2
Op mijn Toon1 heb ik 3 tabbladen.
Op beide heb ik Zon op Toon aan staan.
Vandaag heb ik ook een slimme stekker gekoppeld en die pagina laat hij wel zien.
Maar de Solarpagina is niet zichtbaar.
Ik heb al in de json file gekeken maar kan geen vreemde dingen zien.
Als ik IP/mobile#solar in typ dan laat hij de zonne pagina wel zien.
Heb je enig idee waar het aan zou kunnen liggen?
Mvg Gert
Mvg Gert
